Old 26th December 2008, 10:33   #46
Thanked: 28 Times
Pls also advice me on the foll gurus,
1.Dual functionality- how to use.
2.Surround sound -should be it on?
Someone adviced that use of centre speaker(alpine small unit) reduces the bass and surround function usage ...........
Totally confused.
PRADEEP KUMAR is offline   Reply With Quote
Old 26th December 2008, 11:23   #47
navin's Avatar
Thanked: 4,286 Times
Originally Posted by PRADEEP KUMAR View Post
I am confused how to adjust the parameters like speaker distance
I also have included a centre speaker
The best way is by ear. First set up your front speakers, then set up the sub so it feels like it is integrated to the front speakers. then set up the center and lastly the rear.
Old 26th December 2008, 11:58   #48
valhallen.282's Avatar
Thanked: 164 Times
1. NO twin coil subs are just as good and at times a LOT better than their single channel counterparts.
2. NO using the center channel will NOT affect your bass level or quality. it is basically adding a surround sound 'FIELD' to your car. this is to give movies a realistic experience. but in cars it also makes things in music clearer and better 'staged'. It has not much to do with bass. In your setup that is primarily your subs job.
valhallen.282 is offline   Reply With Quote
Old 26th December 2008, 12:09   #49
Thanked: 28 Times
I am confused how to adjust the parameters like speaker distance etc etc,Is it when a DVD is the input or if it is a cd as the source.dont seem to get them o the menu
Old 26th December 2008, 15:12   #50
dinu2506's Avatar
Thanked: 349 Times
Speaker distance is a kind of time alignment. If the HU has the feature, it should be available when a CD is playing. It does so in the AVX800.
dinu2506 is offline   Reply With Quote
Old 26th December 2008, 16:02   #51
dinu2506's Avatar
Thanked: 349 Times
One more query on the frequency adjustment dial in the JBL GT5 A604 and JBL GTO3501. Probably Sam can help. Pardon me if I sound silly.
The rotary dial in the 604 shows a min of 32Hz and max of 320Hz with no frequency value markings in between. Can we assume it is a linear scale? Which means can we assume the frequency value at the center is around 175Hz. I think it is not a linear scale but there is no way to find out. Can gurus comment?
Old 26th December 2008, 17:34   #52
Thanked: 164 Times
Sam would be the best to comment. but IMO it is linear and is in 10hz increments. so you can assume it to be that much but let your ears be your guide.
I don't believe any question is silly it could have been anybody's doubt.
@Pradeep speaker distance adjustment is universal to the system and only needs to be done once.
Last edited by valhallen.282 : 26th December 2008 at 17:39. Reason: Added text and responses
Old 26th December 2008, 17:47   #53
dinu2506's Avatar
Thanked: 349 Times
I saw pictures of lot of other amps where more markings are there, but it is not linear. For eg mid point is around 60 Hz in a 32 -320Hz range. Hence the confusion.
Old 26th December 2008, 17:56   #54
greenhorn's Avatar
Thanked: 1,519 Times
heh, was just thinking after going through this thread - beggars cannot be choosers. you guys should have pity on me - my HU doesnt have an LPF for the sub out , and my amp has only a fixed 80hz LPF !
Old 27th December 2008, 10:51   #55
navin's Avatar
exactly! it is decade scale with a log pot.
Old 27th December 2008, 22:12   #56
Thanked: 164 Times
NAVIN sir can you please explain to me what you said. it seems to have gone over my head.
Old 27th December 2008, 22:21   #57
greenhorn's Avatar
the scale is not linear because it is logarithmic
http://en.wikipedia.org/wiki/Decade_(log_scale)
Old 28th December 2008, 00:40   #58
Thanked: 164 Times
AH yes thank you sir for the kind timely reminder. i had forgotten all about it.
Old 28th December 2008, 03:50   #59
rohan_fonseca's Avatar
Could i butt in with my query? My amp's set at hpf:80hz lpf:80hz
HU set at hpf:63hz lpf:63hz(i.e sub)
Will this result in missing frequencies?
rohan_fonseca is offline   Reply With Quote
Old 28th December 2008, 09:07   #60
dinu2506's Avatar
Thanked: 349 Times
I guess you will lose the 63Hz to 80Hz range. You can lower the HPF at the amp to 63Hz which should take care of this.
Frequency range chart in reference to Various Musical Instruments pranava999 In-Car Entertainment 3 16th April 2010 21:25
Radio Frequency Car Keys Not Perfect mithun Technical Stuff 24 13th August 2009 15:57
What is resonance (tuned) frequency? m2avg In-Car Entertainment 18 30th November 2008 10:06
Are low frequency sounds hazardous to kids satish_appasani In-Car Entertainment 28 9th October 2006 10:56
