Old 26th December 2008, 20:00   #16
abhibh's Avatar
Thanked: 34 Times
Originally Posted by nitin.dangayach View Post
Ok guys, just a quickie. Finalised these:
1) Scosche E400 400-Watt Amplifier Wiring Kit - E400 - Buy.com
2) Scosche EFX Audio Cable - A12G2BL - Buy.com
Shall I place the order now ?
Yes nitin E400 will server your purpose and get the scosche RCA too.
Old 26th December 2008, 20:42   #17
Awaiting Email Confirmation
Ok done. Buying the stuff. Thank you guys.
nitin.dangayach is offline   Reply With Quote
Old 26th December 2008, 20:43   #18
DjNik's Avatar
Just make sure you get the 17/20 ft Rca cable if you are going to put the Amp in the boot.The link over here is for the 12ft rca which wont be enough from the HU to the boot.
DjNik is offline   Reply With Quote
Old 26th December 2008, 20:57   #19
O is it ? I guess in ALto it will suffice.
See if I buy un-ncessarily long RCA, signal will have to move longer and thus more chances of picking up interferance and more resistance to the flow. ANother thing is the 12ft is 2 dollars cheap.
I bought a spindle of 20ft speaker cable and I still have some wire left so i takes close to 9ft. I think it should be fine.
Anyone ?
Old 26th December 2008, 21:36   #20
abhibh's Avatar
Thanked: 34 Times
Anyone ?
Nitin i have used the same Scosche RCA in swift and zen and its always in access. The Scosche RCA is big enough to be used in Safari where amps were installed in the boot.
Old 27th December 2008, 11:08   #21
Finally ordered this:
Amazon.com: Scosche E1000 1000 Watt Single Amplifier Kit: Electronics on Abhibh's advice.
But got myself into big issue and finally haven't ordered the RCAs yet.
ANother thing now.
Can I get quality RCAs from here. what will be the price in India ?
I can see now that all the RCAs I can get here are above 1K INR now.
If in that price I can get good RCA in Indida, I'll prefer those.
Please reply.
Old 27th December 2008, 12:55   #22
gigy's Avatar
Thanked: 42 Times
So you got the same kit i told for half the price, good you have kept upgrade options.
Old 27th December 2008, 13:07   #23
O yeah. Bought the 1000W kit. Will definitelt be an overkill for me but actually got it with free shipping and was just 7 dollars more than the one I wanted (because for that shipping was extra).
Any suggestions about the RCAs ? Can I get them in India ? I mean the good ones, not exorbitantly priced
Old 27th December 2008, 13:13   #24
gigy's Avatar
Thanked: 42 Times
i saw you using two RCA already, need more?
6. RCAs – Ground Zero x 2 (GZCC 5.3 5m RCA triple shield) – Rs 1,190
twister comes for 600-700 i think if it is considered good for that price
Old 27th December 2008, 13:39   #25
Hey I guess you are misunderstanding me for someone. I have no RCA right now. Only the one which will come with the Wiring kit.
I need one more. My HU has two 3 RCA outs, will be using two first.The sub will come later.
Old 27th December 2008, 13:53   #26
gigy's Avatar
Thanked: 42 Times
Yes buddy, my mistake i mistook "nishantgandhi " as you. signs of ageing i guess.
I bought twister cables 1 year back for that price (600-700) and have no issues with it. You can also buy genuine MX cables from local market , they are also good. there is fake MX also in market. check build quality to know if original. fake has the plastic sticking out at various sides of connector.
If two Ground Zero GZCC 5.3 5m RCA comes for 1,190 its better deal.
Old 27th December 2008, 14:03   #27
Old 27th December 2008, 16:05   #28
manikjeet's Avatar
Thanked: 110 Times
i would suggest you order two more RCA as your hu has 3 pre outs and you mention that you will add a sub later
two RCA will be required to run two pair of speaker and one will be require to run the sub if you get another amp or decide on a mono amp
manikjeet is offline   Reply With Quote
Old 27th December 2008, 21:03   #29
abhibh's Avatar
Thanked: 34 Times
Nitin Scosche E1000 comes with 1 RCA. 1 Scosche RCA in india will cost u between 500-700 (not sure about the current prices but it was 500 i think last time i checked). You can contact Blueraven he deals in Scosche products.
Old 28th December 2008, 01:29   #30
hellspawn's Avatar
Infractions: 0/1 (10)
You can look for scosche rca's.They cost rs400 for two rca's.
hellspawn is offline   Reply With Quote
Wiring kit comparison :) nitrous In-Car Entertainment 19 27th December 2016 21:09
Zen MPFI wiring manual/wiring diagram IndrojitSircar Technical Stuff 1 27th February 2012 00:21
Fake Wiring kit Sam Kapasi In-Car Entertainment 133 24th December 2010 20:03
need help regarding wiring and installation gandolf_thewise In-Car Entertainment 2 29th January 2008 16:26
Ground Wiring Kit 1self Technical Stuff 6 25th August 2007 08:38
