Old 26th December 2008, 15:23   #1
Awaiting Email Confirmation
Default Help regarding wiring kit
Well this is going to be some effort from you guys.
I am looking for the cheapest possible wiring kit for my amplifier installation. The amplifier is yet to be bought but I am sure I'll get this Kenwood KAC-8401 for its SQ (Budget is the major constraint actually )
I can procure the stuff from India but I am little skeptical about the authenticity.
My friend is right now in the US and can easily buy the stuff from there. SO I was wondering what could be the best bet in sub 40$ kit.
I looked at amazon and found a plethora of options. Could anyone amongst you help me decide one ?
Here is the link:
Amazon.com: Car Electronics - wiring kit / Amazon.com: Electronics
I liked this one but not sure if it will work with the setup. Seems to be nicely priced.
Amazon.com: Scosche E400 400-Watt Amplifier Wiring Kit: Electronics
nitin.dangayach is offline   Reply With Quote
Old 26th December 2008, 15:43   #2
greenhorn's Avatar
Thanked: 1,314 Times
finolex wiring for power, and MX for the RCA's
greenhorn is online now   Reply With Quote
Old 26th December 2008, 15:58   #3
I am always confused on this. How will be manage to get those small tits bits that are part of the complete wiring kit, I mean those small things, washers, holders etc.
Still, If I am to get one, which one should it be, from amazon. My main criteria is minimum price without compromising the quality.
Please suggest greeny.
Old 26th December 2008, 15:59   #4
abhibh's Avatar
Thanked: 33 Times
Nitin E400 is good enough but i would suggest E1000 if you plan to upgrade later on.
Amazon.com: Scosche E1000 1000 Watt Single Amplifier Kit: Electronics
Rest greenhorn suggestion is the cheapest alternative.
Old 26th December 2008, 16:10   #5
Ok two questions branch from this:
1)Wont I be able to add in an amplifier later if I get E400 ? I am planning to add an amp at some point later. Might be JBL GT5 12". If there is not an issue, I'll buy E400.
2)Are the Power cables so easily available ? I mean say 4 gaughe Finolex. What'd be the probable pricing ? I assume the ground cable can be made of the same power cable.
Another few points that are coming to my mind.
*There are few cheaper wiring kits that boast of 2AWG wiring in less than 40$. Any good ?
*Will it be easy to get the connectors like those washers we see in the wiring kit, in the after market ? I can then follown the Greeny's suggested way and wil buy only good RCAs.
Old 26th December 2008, 16:23   #6
adityamunshi's Avatar
Power cables are easy to buy if you locate the dealer in your city, they may not be available at every electrical shop.
The connectors/lugs should be available at any car accessory shop, i got them for Rs. 50.
It'll be the best and most VFM if you get good RCAs from there and buy the Powercable from here.
adityamunshi is offline   Reply With Quote
Old 26th December 2008, 16:30   #7
So shall I buy only 2 RCA cables ?
Old 26th December 2008, 16:44   #8
greenhorn's Avatar
if you dont know where to source the bits , then get a full kit from there, whatever you can afford , and get some thicker gauge power cable locally
Old 26th December 2008, 16:56   #9
But then I think whats the use, why not get that 2GA kit in just 38$. No hassels will be there. But I am not sure about the quality and dont want unnecessry hummind and noise.
See this: Amazon.com: Power Acoustik KIT-2G 2-Gauge Amplifier Wiring Kit: Electronics
Old 26th December 2008, 17:21   #10
manikjeet's Avatar
Thanked: 109 Times
don't know why but the wiring kit you have posted looks alot like desi boss
i would recommend scosche wiring
i am using their 4 gauge dual amp wiring kit for about 4 months now and it works beautifully
btw even the 8 gauge wire would be enough for a 8401 and anything above that would fit
manikjeet is offline   Reply With Quote
Old 26th December 2008, 17:26   #11
O nahin nahin bai ji.
The cheap one must be the Amazon.com: Power Acoustik KIT-2G 2-Gauge Amplifier Wiring Kit: Electronics
I think I should get the Scosche E400 for 20$ and a pair of stereo RCAs. I guess I should be good.
I assume, i'll be able to work with 8401 or JBL 504 and will be able to add a Sub later, without any need to change the kit.
This is what I've nearly finalised: Amazon.com: Scosche E400 400-Watt Amplifier Wiring Kit: Electronics
Old 26th December 2008, 17:41   #12
abhibh's Avatar
Thanked: 33 Times
Nitin there wont be a problem with E400 kit but I will still suggest you get E1000.
Don't worry i know people who are running 2 MONO amps with DESI BOSS wiring without any problem so E400 should not be a problem running 8401 or 504.
Old 26th December 2008, 17:49   #13
Considering the price, I think I am going with the E400. Just assure me if this will work for my purpose. I am buying that.
Also shall I get the RCAs from the US or get it from India ?
Old 26th December 2008, 19:36   #14
Ok guys, just a quickie. Finalised these:
1) Scosche E400 400-Watt Amplifier Wiring Kit - E400 - Buy.com
2) Scosche EFX Audio Cable - A12G2BL - Buy.com
Shall I place the order now ?
Old 26th December 2008, 19:51   #15
manikjeet's Avatar
Thanked: 109 Times
yup it looks nice combo theses are the same rca that came with my kit and they are working great
yes bhaiji i was talking about this one
yup you will be able to run a sub at a later stage
Wiring kit comparison :) nitrous In-Car Entertainment 19 27th December 2016 21:09
Zen MPFI wiring manual/wiring diagram IndrojitSircar Technical Stuff 1 27th February 2012 00:21
Fake Wiring kit Sam Kapasi In-Car Entertainment 133 24th December 2010 20:03
need help regarding wiring and installation gandolf_thewise In-Car Entertainment 2 29th January 2008 16:26
Ground Wiring Kit 1self Technical Stuff 6 25th August 2007 08:38
