Old 3rd January 2009, 09:01   #1
greenhorn's Avatar
Thanked: 1,518 Times
Default Bi Amping using HU and Amp: Feasible ?
was just wondering, if you have an HU with a high quality internal amp, why let it go to waste when you get your system amped ?
Advantages:
1. higher output possible, possibly higher than the sum of each because the amp can play with a bit higher , since the higher harmonics wont reach teh tweeter , and the tweeter doesnt sip a lot of power from the HU
2. the internal amp enjoys a direct path to the source, and the HU is closer to the tweeter than the amp from most install locations, so lesser chance of noise
3. Everybody would love to have an active bi amped setup
Problems
1. HU will still lose power amplifying frequencies that wont be used by the tweeter
2. All comps cant be bi amped
3. when I was discussing this with hydra, he pointed out that the volume change curve may not be the same for the internal amp and pre outs
4. need to have a good HU
Anything else ?
Old 3rd January 2009, 11:29   #2
nitrous's Avatar
Thanked: 285 Times
I did something like this and blew the HU.
Old 3rd January 2009, 11:43   #3
frankmehta's Avatar
Thanked: 2,334 Times
very adventurous! but looks like a bummer, simply because the maximum power you can harness from the best HU in the market will be about 18-22 RMS. i mean, it makes sense to have a more powerful amp than to compromise on the longevity of the head unit that will be continuously running at its full potential and theres a chance of it blowing!
Old 3rd January 2009, 11:57   #4
greenhorn's Avatar
how come ? if the HU can drive the entire comp, why not the tweeter alone?
note that this works only for speakers which are bi ampable - ie the crossovers have separate tweeter and woofer inputs or seperate crossovers for each
Usually the power dissipation in a tweeter is a fraction( not sure about this , but 10~20%?) of the power dissipated by the woofer. for systems with upto 100WPC, i think the HU should provide enough drive to the tweeter.
The HU will actually be running at a much lesser load than it would be if it were driving the whole comp
Old 3rd January 2009, 12:32   #5
Flying Bong's Avatar
WRT bi-amping, think this is what you're referring to:
http://www.team-bhp.com/forum/sound-...e-install.html
About reducing the load on the HU amp, I think the frequency division needs to happen BEFORE the amplifier stage. In case of passive bi-amping i.e. frequency division at speaker out level, each (HU) amp channel would amplify the ENTIRE full range signal and hence run at "full load" (not the correct technical term I know), its just that the power/energy corresponding to lower frequencies would be dissipated by the tweeter filter/crossover....gurus please correct me if my understanding is wrong.
Flying Bong is offline   Reply With Quote
Old 3rd January 2009, 12:38   #6
navin's Avatar
Thanked: 4,284 Times
I think you are suggesting using the HU with a passive HPF to drive the tweeter and then using an amp connected to the RCA out to drive the woofer.
It is bit adventurous. The likelyhood of engine whine (ground loop) will be higher. This only makes sense if your HU's amp is much better than the power amp. Remember of teh 10-15W the HU is producing you will be wasting 80-90% and only 1-2 watts will be used by the tweeter.
Old 3rd January 2009, 13:29   #7
greenhorn's Avatar
Originally Posted by Flying Bong View Post
in that install, One channel of the HU drove the tweeters, one channel drove the woofer. This is about using the HU to drive the tweeters and an amp to drive the woofer
Ideally that would be the best idea, but the problem is that , you cant control the RCA and speaker outputs independently in most HU's. if you HPF the fronts, the RCA output also gets HPF'd . so yes, the whole frequency range will be amplified by the HU. if the bass dominates , the HU will clip the treble - that is an issue.
exactly
if the crossover is a single unit and shares a common ground. if there are seperate crossovers for the woofer and tweeter , like in my hertz dieci, dont think that can happen, since there is no point of two seperate ground wires meeting
yup, thought of this for improving the quality in medium budget installs where 60~100WPC channel amps are used. And its far better to waste the HU's power - its going to be wasted anyway, than using an entire amp channel ( not feasible anyway)
Old 3rd January 2009, 14:30   #8
frankmehta's Avatar
isnt this turning out to be a case of much ado about nothing????
i mean HOW much power are we talking about here guys?
Old 3rd January 2009, 15:18   #9
greenhorn's Avatar
not much, but if we can get a small increase in SQ and SPL for free, why not do it
Old 3rd January 2009, 19:29   #10
DerAlte's Avatar
Thanked: 2,879 Times
1. No, the HU will not be wasting any power on the frequencies below the XO's lower cut off point for the tweeter, where the XO presents a high impedance to the amp
2. Ditto for the external amp when you use bandpass filter (the amp's HPF in conjunction with the XO's woofer section, or the XO is BPF itself for the woofer in your case)
3. BUT, the main issue is level-setting for tuning - as hydranup rightly said, the gain profiles for the HU and amp would be different, which might do more harm to your cause than good. Forget SQ / SPL, you might land up spending more time balancing the setup (4 variables now instead of 2) for fidelity than listening to music - perfect example of law of diminishing returns
DIY trip to Switzerland - feasible or am I just kidding myself ? nimbleguru Route / Travel Queries 32 8th December 2010 18:29
Planning Gurgaon-Manali-Leh-Srinagar in Ford Fiesta 1.6Zxi: How much Feasible? hridayjyoti Route / Travel Queries 27 10th August 2010 13:21
How feasible is tracking service engineers though GPS? Nikhilb2008 Gadgets, Computers & Software 15 19th February 2010 00:30
Bi-Amping / Triamping - Help pls Mi10 In-Car Entertainment 150 13th October 2009 11:03
Civic alloys on NHC CVT. Is it feasible? zakaaaaasss Tyre & Alloy wheel Section 5 28th June 2007 16:48
