Old 6th January 2009, 10:21   #46
navin's Avatar
Thanked: 4,284 Times
Originally Posted by lynx View Post
you might find investing in a Yuin PK-2 which cost about $100.
I believe the HR2 are even smoother than the PK2. Also for the PK1/HR1 you will need a amp boost - even a simple chip amp (headroom, ordanance, etc...) will help. For the next step up try a 6922 powered Beyer 880 the 880 is half the price of the 650 or 701 and almost as good. back to car audio....
Given your budget any HU more expensive than the 9886 wil eat up too much of the budget. Why not start with a 9886 and a good pair of components then you can add a sub and amp later. Unfortunately most of the better speakers are 2-3 db less sensitive than their cheaper counterparts which means you system will be SPL limited and maybe bass definition will not be as good as it could be.
Like B&T said before each speaker manufacturer has different testing techniques so comparing the tech specs across manufacturers might mislead you. Your ears are by far the best judge.
navin is online now   Reply With Quote
Old 6th January 2009, 16:05   #47
lynx's Avatar
Is that the MylarOne? I have only read reviews. I haven't had a chance to try Beyer either. I loved my RS1 and HD600 though. The grado was simply the best ever.
After a lot of help from hydrashok, that is what I have decided too. For now, it will be either a 9886 with b&w or 9887 grey and Rainbow SLX265 for the components. If it is not loud enough or lacking without the amp, the components would change to Image Dynamics CTX65. Hopefully one of the four combination would sound best at the time of audition.
Yeah, I realized pretty much every one is quoting a sensitivity of 90 dB. Anyway, thanks, hope it would all go well. I would also get the front doors damped this time around.
I would add an amp or two, wiring and the sub after a few months.
Thanks everyone for all the invaluable suggestions! You guys are the best!
lynx is offline   Reply With Quote
Old 6th January 2009, 18:04   #48
Thanked: 294 Times
Having Hydra helped you with some basic stuff, I would suggest you to audition some few more brands before finalizing the stuff. Also since you stay close to Banglore which is approx 180 kms from your town. Give visit to few of the T-Bhp members for the same...
As Hearing is believing....
Old 6th January 2009, 18:12   #49
panky12345's Avatar
Thanked: 150 Times
+1
Audition as many brands as you can BEFORE buying and try NOT to get carried away by mere recommendations!
"In Pursuit of Happiness" - The Journey of a True Audiophile Mi10 In-Car Entertainment 389 13th January 2012 10:17
Which (ICE Component) will make the most difference in Sound Quality? low_bass_makker In-Car Entertainment 43 7th April 2008 10:00
Sound Quality not good on new ICE setup. Help! maverickzCar In-Car Entertainment 24 28th December 2007 15:15
