Old 5th March 2009, 23:01   #76
nisarg86's Avatar
Thanked: 12 Times
sdh. but will it work with Swift Diesel ? eager to know the result. as i want to buy OBD tool which supports in CF. Let us know the result ASAP.
Thanx.
nisarg86 is offline   Reply With Quote
Old 5th March 2009, 23:02   #77
gigy's Avatar
Thanked: 41 Times
how much did you get this fm receiver for? i have just ordered it. had i known you were going for it, i would have waited for your review about its reception and compatibility with CF.
Old 5th March 2009, 23:38   #78
Thanked: 41 Times
i dont think ki OBDII scanner works with Swift DDsi with ELM scanner
monty9991 is offline   Reply With Quote
Old 6th March 2009, 05:56   #79
sdh
Bought at Amazon in US and someone hand carried it. So price is same as waht you got, but cheaper shipping.
sdh is offline   Reply With Quote
Old 6th March 2009, 08:40   #80
sdh
Update:
GPS:
Installed and working perfectly
ELM Scan:
Connector found, located below stearing close to centre console
Scan tool connects and rx/tx leds blink nicely
No data displayed in Elm provided as well as CF.
ADS FM Radioi:
Oult of the 3 drivers it is supposed to install, one of them is not getting installed on the car PC.
So 33.33% success today morning.
Old 6th March 2009, 19:21   #81
sdh
Update from evening:
No luck with Radio and OBD. Radio refuses to find stations, only hissing. OBD connects, rx/tx links blink on both ends, still no data in software. Tried various baud rates without luck. Swift had K line on pin 7 as expected by OBD II, so not sure what the issue is.
Any guidance?
Old 7th March 2009, 02:02   #82
ibm_jennifer's Avatar
Thanked: 7 Times
No luck with Radio
Radio should work, Try to move near the window or outdoor unless you have the MCX Di-Pole Antenna.
ibm_jennifer is offline   Reply With Quote
Old 7th March 2009, 02:50   #83
nisarg86's Avatar
Thanked: 12 Times
Any guidance?
SDH. Are you trying to get info only in CF ? Do try other software. OBD tool comes with CD.
Old 7th March 2009, 10:37   #84
sdh
Tried various softwares on CD.
AT DP command returns AUTO, ISO 14230-4 KWP (fast init)
this indicates 14230 protocol is selected where as I read somewhere that it is ISO 9141. Tried selecting this protocol and got bus error.
The tried Scanmaster ELM tool. Asked him to auto detect com port and protocol.
Detects right comport, 384000 baud, connects to tool,protocol detection says unknown protocol and then it disconnects. Tried forcing to ISO 9141, and got bus error.
I have searched around and found no hints so far. Will keep trying some more things in the mean time and home some one will give the clue to resolve the issue.
Old 7th March 2009, 22:07   #85
Thanked: 41 Times
OBDII doesnt works with most of the marutis. tested on ALTO n swift DDsi by me tested with no results. and on baleno tested by someone on teambhp.
Old 8th March 2009, 06:52   #86
sdh
I put serial port sniffer and saw that data is exchanged between PC and OBD. I read somewhere that suzuki does not follow standard PIDs. May be that is culprit for no data.
Old 8th March 2009, 11:34   #87
sdh
As per ELM documentation, I did some tests and here is the results:
Command: AT DP
Response: AUTO, ISO 14230-4 KWP (fast init)
I read some where that this is protocol used by suzuki in new cars, so must be ok.
Command: 0100
Expected response: 41 00 followed by id's of supported PID's, each indicated by a byte
Response from my car: 7F 01 11
Command: AT MA (monitor all data)
Response:
00 00 00 7F 00 00 00 00
00 3E 00 00
00 12 72 15 E0
00 12 D9 15 E0
00 12 D9 15 E0
08 40 00 <DATA ERROR
00 00 00
00 13 5F 15 E0
00 13 5F 15 E0
00 13 5F 15 E0
00 13 CF 15 E0
00 13 CF 15 E0
00 14 5B 15 E0
00 14 5B 15 E0
00 3E 00 00
00 14 CB 15 E0
00 14 CB 15 E0
00 15 53 15 E0
00 00 00
00 15 53 15 E0
00 15 53 15 E0
00 15 D1 15 E0
00 15 D1 15 E0
00 16 66 15 E0
00 16 66 15 E0
00 16 F3 15 E0
This looks like a repeating pattern and observed that rows ending on E0, have different values based on throttle position, so should be some how related to engine RPM. if I translate 16 F3, the last values above, it comes to 1469 rpm, which looks reasonable.
So my guess is that the softwares on the CD do not show data as the PID's are not matching. According to Standard OBD spec, PID for rpm is OC, and the command to read is 01 0C and the response should be 41 OC followed by 2 bytes for RPM value.
I will investigate further. I am pretty sure I dont want to waste my $200 investment :-)
Old 9th March 2009, 18:55   #88
gigy's Avatar
Thanked: 41 Times
all maruti have only the connector which is obd ll.
Old 9th March 2009, 21:22   #89
sdh
Some more inputs:
when I send, 0100 to read capabilities of PID 01xx, the response is 7f 01 11
This basically translates to 'capabilities service 1: none'
I will check 0200, 0300 etc to find what is possible.
Old 10th March 2009, 17:42   #90
Thanked: 41 Times
this is really a good work.. but i really dint get what those numbers are.. lol
anyways all the best for your research and do let us know if it works or any help you need.
Win 7 + Office 10 installation computer shops in Bangalore MC Mayank Gadgets, Computers & Software 11 4th August 2010 07:56
Thinking Car Computer! zuch In-Car Entertainment 2 8th June 2008 14:57
Computer designed car breaks speed record! katalyst Int'l Motorsport 0 24th August 2006 16:21
Computer system for integrating car electronic devices harishsegar Technical Stuff 1 2nd June 2006 19:36
