Old 5th January 2009, 20:34   #1
Default problem in running speakers on my amp
i want to run the following speaker on my amp..
kicker DS600.2
6-1/2" 2-way Component System
Power Handling:
  • Peak: 120 watts
  • RMS: 60 watts
Impedance: 4 ohms
3/4 Titanium Dome Tweeter
UV-treated ribbed surround
Neodymium tweeter magnet
Heavy duty voice coils
3-Level Tweeter attenuation circuit
4000Hz 12db crossover
Grilles included
Frequency Response: 35-21,000 Hz
Sensitivity: 90 dB
the amp is a kicker ZX200.4
specs
4-Channel ZX-Series Power Amplifier
Low Impedance Operation
SORT Protection Circuitry (Short circuit, Over-voltage, Reverse polarity, Thermal)
MOSFET Power Supply
KickBass: 0-12 dB @ 40 Hz
Built-In Electronic Crossover: 12 dB High or Low-Pass operation (80 Hz)
High & Low level inputs
Custom tooled gold plated connectors
SAMS (Stereo And Mono Simultaneously) bridged mono load and a stereo load at the same time
Cast Aluminum EndKaps
RMS Power Ratings:
  • 35 watts x 4 chan. @ 4 ohms
  • 50 watts x 4 chan. @ 2 ohms
  • 100 watts x 2 chan. @ 4 ohms
Input gain control: Low Level (125mV - 5V), High Level (250mV - 10V)
Dimensions: 10-1/4"L x 9-5/8"W x 2-1/8"H
i tried to install them myself but the front speakers cracked a lot and i the hissing sound was very dominant..
please help...
fiorano88 is offline   Reply With Quote
Old 6th January 2009, 08:54   #2
arpandiv's Avatar
Thanked: 27 Times
Looks like a grounding problem to me.
What wiring are you running ?
Have you given ground/earthing to the amp properly?
What RCA cables are you running.
arpandiv is offline   Reply With Quote
Old 6th January 2009, 11:26   #3
navin's Avatar
Thanked: 4,286 Times
fiorano, who is the installer. this is an install problem. check all wiring, loose contacts, shorts and also all settings on the amp. let us know.
Old 6th January 2009, 12:56   #4
the instal was done by autozone..
can u suggest some place in delhi where i can get it done "properly"..
i live in punjabi bagh..
fiorano88 is offline   (1) Thanks Reply With Quote
Old 6th January 2009, 13:10   #5
ramie2400's Avatar
Thanked: 58 Times
Contact Low_Bass_Maker or Gunbir on the forum,they will help you out in solving the probs.
My reccomendation:
Just check the RCA cables if its fixed properly and probably try grounding them,set the HPF "ON" from your amplifier and play around with the "Gain" and "HPF" frequencies,do try to tune the crossover by shuffling the wires to get the correct phase of Input/Woofer/Tweeter done!!!
Ramie
Philips India launches Daytime running lamps & an In-cabin Air purification system GTO Modifications & Accessories 144 30th December 2015 12:09
Swift Vxi & Swift Vdi - Ownership/Service/Running costs dcetech Hatchbacks 4 26th October 2009 22:28
Another pavement, Another Car running over it & a few more deaths esteem_lover Shifting gears 39 26th December 2007 21:52
6 Months & 5 Lakhs Penalty for Running over People on the Pavement: UPDATE: Now 3 yrs esteem_lover Shifting gears 34 14th September 2007 15:38
Best & Cheap HU & Speakers For Zen ? prakash2757 In-Car Entertainment 6 14th July 2006 09:31
