Old 6th May 2009, 00:40   #91
nisarg86's Avatar
Thanked: 12 Times
Gigy. yet to source Jetway Dealer here. Let me know if you know anyone in Bombay. Could you ask for Jetway JNC92-330-LF ?
@Binz. Thanx
nisarg86 is offline   Reply With Quote
Old 6th May 2009, 03:57   #92
gigy's Avatar
Thanked: 41 Times
i think rashi handles jetway components in mumbai. you can try contacting them. i would recommend going for the gigabyte atom board. i consider gigabyte is better than jetway in build quality since i have motherboards of both. that gigabye runs atom stable at 2ghz
Old 7th May 2009, 16:36   #93
nisarg86's Avatar
Thanked: 12 Times
Yup that is the reason why I am waiting. confirmed with Gigaybyte People today. Dual Core Atom mobo is hitting the retail market in a month.
Old 7th May 2009, 18:42   #94
tush's Avatar
@nisarg86
Nice setup. Congratulations for your carputor. Regarding your motherboard stuff. Go for Gigabyte as they have dual bios feature or else go for Asus. These two brands are very overclock friendly. Asus is known to already have overclocked the FSB(Front Side Bus) by around 5%. So even if you dont want to overclock its already done with factory defaults and you should get a very good performance in the carputor.
Regarding the boot problem with your Intel Board. Intel Boards are always a no no when you are customizing your PC(in your case carputer) is my personal experience.
tush is offline   Reply With Quote
Old 8th May 2009, 00:17   #95
nisarg86's Avatar
Thanked: 12 Times
tush. Thanx.
Gigabytes' mobos are damn stable. I dont find Any Asus Dual Core Atom Board on their site.
Old 14th May 2009, 21:15   #96
ST7677's Avatar
Thanked: 45 Times
Congrats on your carputer!
Why don't you try Zotac motherboard, it is leading right not in mini-itx form factor.
Gigabyte is good but not in mini-itx.
My personal choice would be a Zotac 9300 with a E7400 core2Dou 2.8ghz. It doesn't heat as much as you think.
CPUAnd MoBo would not consume more than 75-120 watt, depending on the load and it will be able to do everything you can today think off.
ST7677 is offline   Reply With Quote
Old 15th May 2009, 00:28   #97
nisarg86's Avatar
Thanked: 12 Times
Thanx ST7677.
Yes ZOTAC has launched Dual Core Atom MINI ITX. which has loads of features. And at full load 45W TDP. which is great. I find C2D setup is useless for carputer. coz most of the time I am going to run Centrafuse with navigation. which is working smooth even on my Single core Atom.
Zotac is launching Dual Core Atom in 3rd week of this month.
Old 15th May 2009, 02:09   #98
Ah, ok!
I intend to do audio tuning via PC using ASIO & VST plugins, so I would need a powerful processor.
You can look at Zotac Ion platform with Atom 330. (which is what you are talking about).
R18A is offline   Reply With Quote
Old 26th May 2009, 16:03   #99
nisarg86's Avatar
Thanked: 12 Times
Got my Andrea Mic and Rexus Case Fans. Will update on mic.
Old 8th July 2009, 23:12   #100
nisarg86's Avatar
Thanked: 12 Times
Well. Today i got the rest of the stuffs from crazypc(Fans, Y-Cables , Rocker Switch).
Now. Rocker Switch is not turning on my Mobo and PSU. I have connected the both + and - wire properly to Swicth as instructed here.
Rocker Switch Blue LED: CrazyPC Computers
I can see the Blue LED glowing.So connection is perfect. but it is not turning on my PSU and MOBO.
I am thinking to put this Rocker switch in one of the blank switch near A/C Fan control as you can see in the pic.
Now the Andrea Noise Crenelation Mic part.
Mic is just working perfectly with my PC and LAPTOP. but not with my carputer.
Problem is 2 USB Sound Cards in CentraFuse. Running CF with 2 Sound Card eats up my single core Atom. I get choppy sound from Remote caller.
Solution: Upgrade to DUAL CORE ATOM and Remove Creative X-FI USB 5.1 Card.
But overall Mic is just great. Noise Cancellation works pretty well.
I have also installed the 2 Rexus High CFM Fans. and Speed Fan reports 34C Ambient Temp. which is better than my previous reading. (48C).
Old 9th July 2009, 19:07   #101
gigy's Avatar
Thanked: 41 Times
Is that switch a ON/OFF or momentary ON one? Where have you connected it?
Led coming on means, i suppose its the master power on switch to pc, not the one on motherboard.
Check the wires from psu to motherboard, something must have gone loose.
Old 10th July 2009, 12:19   #102
nisarg86's Avatar
Thanked: 12 Times
GIGY. it is ON/OFF switch. have connected it directly to battery's + and -
It is the master power switch to on the PC.
Old 10th July 2009, 12:44   #103
Can you draw a wiring diagram of how you have wired the switch to the carpc.
shldn is offline   Reply With Quote
Old 10th July 2009, 16:22   #104
ghpk's Avatar
Thanked: 193 Times
I am sure the "+ve and -ve" are going into switch only for L.E.D.
The circuit which switch will ON/OFF will have only one wire i.e. +ve.
there should be only two Large Points (connectors) on the switch which will toggle connectivity with switch position on/off.
EDIT: How many pins you have at the back of switch ?
If it has 3 in all, 2 goes to LED (+ve and -ve )and one goes to output taking current from One Terminal shared from L.E.D.
Old 10th July 2009, 16:46   #105
srikant's Avatar
Thanked: 9 Times
Guys me and my friends are planning to install a carputer for my friends swift petrol. I have some questions on that.
1. Can we use his existing desktop for the project?
2. The existing SMPS shows 400 watts, isn't it on the higher side for carputer?
3. What modification should i do to drive the desktop CPU from car and what change should be made to SMPS?
Srikant
srikant is offline   Reply With Quote
Maruti Swift : DIY Carputer And ICE'D! ACMohan In-Car Entertainment 10 14th August 2012 19:39
Clarion, Alpine, Illusions, JBL & Sony and a Carputer too (trying to add) esteem_lover In-Car Entertainment 71 29th April 2011 23:00
Carputer for Swift - ROAD KING VS SSAS-SUZUKI1003 - Need Advice!!! johnruben In-Car Entertainment 10 12th November 2010 15:46
Carputer/LCD installation required varunj In-Car Entertainment 1 25th September 2009 07:51
