Old 21st January 2009, 15:34   #1
Thanked: 52 Times
Thumbs down Neeed Help from the ICE Gurus
The present ICE setup on my getz is as follows
HU Blaupunkt Hamburg MP 57
Rear Speakers Blaupunkt GTX 693
Front Component speakers Blaupunkt V 662
Sub woofer GTX 7
1 No 4 channel amp model no Blaupunkt GTA 4
1 No amp sony explod 2 channel to run the sub woofer
also have two nos tweeters installed flush on the door panels of blaupunkt.
my query to the gurus is no doubt the loudness of music is there but what i need i a better treble response as well better response to midranges. I mostly listen to rock , like doors dire starits pink flyod etc.Can the gurus help resolve this problem. Presently the budget is a constarint as recently have alo installed a custom made FFE , Tri Phase, NGKs etc.
sanjz is offline   Reply With Quote
Old 21st January 2009, 21:04   #2
frankmehta's Avatar
Thanked: 2,334 Times
what are the settings on the head unit? can you list them out for us here?
Old 22nd January 2009, 08:27   #3
Thanked: 52 Times
frank
the bass setting on the HU has been pt at 2 , the treble setting is at 7 , the gains and frequency settings are at the lowest , the preset EQ settings are off.The subout gain is at two , besides that have not really tinkerd with HU settings , these settings where provided by the blaupunkt engineer here
Old 22nd January 2009, 10:27   #4
navin's Avatar
Thanked: 4,282 Times
try this one at a time...
1. disconnect the extra tweeters. Use only those supplised with the components.
2. set EQ to flat.
3. upgrade front components to Infinity/Hertz Hi Energy/Blau ODc/THC etc.. set HPF for front components to 60Hz/12db or there abouts.
Old 22nd January 2009, 11:07   #5
DerAlte's Avatar
Thanked: 2,879 Times
I don't think there is anything inherently wrong with his equipment. Quite likely it has been tuned badly.
@sanjz, could you please list the model numbers of the speakers properly? I sense a problem of model numbers v/s description.
For example, do you have Vc662 or Vx662? You mention component speakers, but I don't think any Blau engineer would add another pair of tweeters. The other confusing part is "flush on the door panels of blaupunkt". Best would be if you could post a pic of the front door.
As Navin said, first set all the settable parameters to 0 (bass 0, treble 0, sub gain 0 etc.) at the HU. Don't change the gain setting at the amp (I don't think it is at 0), but set HPF to 80Hz for the front components. Increase volume a couple of points at the HU, play some familiar music and then tell us how it feels. Increase the gain at the Sony amp if you feel the sub is too soft.
Don't worry, you will be able to tune it yourself to your own liking.
Old 22nd January 2009, 12:38   #6
Thanked: 52 Times
Thanks navin, DerAlte
DerAlte what i meant was that the extra tweeters are Blau make as well, and are flush mounted on the front door panel . sorry for the typo.I shall try and do, as advised, but you will have to wait till the weekend for me retune and post results here .
ICE upgrade for OHC VTEC. Gurus please help. vishnuvijay In-Car Entertainment 47 30th September 2010 12:15
Budget ICE for Blushing Red i10-Gurus pls help MontyKING In-Car Entertainment 4 9th January 2009 18:02
Need help ICE GURUs : Possible Sync problems simply_sunny001 In-Car Entertainment 8 8th October 2007 14:45
Ice Setup Zen Ė Audio Gurus plz help nicejits In-Car Entertainment 14 20th September 2007 15:45
Need help ICE GURUs :- HU forgets the settings with every restart simply_sunny001 In-Car Entertainment 13 23rd August 2007 12:13
