Old 24th January 2009, 01:13   #1
ethanhunt123's Avatar
Thanked: 318 Times
Default Which Mono amp under $300 from US ?
My current ICE setup in my Cedia is as follows :-
Kenwood 7539U
JBL Power Series 6.5" comps
Stock Rear fill
1 X JL Audio 12w1 Sub
Infiniti 475a 4 channel amp ( currently giving 90W*2 (2 ohm) + 180W*1(4 ohm) )
I want to get a dedicated mono amp from the US under $300 along with 4AWG wiring kit and add another 12" JL sub. The Infinity amp will then power the comps unfront and rear fills.
As 2 JL 12W1 subs can handle upto 500W comfortably, i am looking for a Mono amp which can deliver around 500W at 2 ohms. I have shortlisted the following options :-
JL A1400 (500W @ 2 ohms) - $280
JL G1700 (700W @ 2 ohms) - $280
Zapco i-600 (600W @ 2 ohm) - $295
RF Power T500 (400W @ 2 ohm) - $300
Diamond Audio D3 800.1 (600W @ 2 ohms) - $300
Audison SRX 2S (600W @ 4 ohm) - $300
I almost ordered the JL A1400 amp in dec but my friend's india visit got postponed and now further research had widened my options and confused me further.
What would you guys suggest ? Especially between the 2 JL amps and the Zapco one. Also, Audison amp is not stable at 2 ohm , so can i run 2 subs off it ? or i have to run the two subs in stereo mode without bridging in which case its probably out of the reckoning.
I am looking not for SPL but more for SQL.
ethanhunt123 is offline   Reply With Quote
Old 24th January 2009, 01:15   #2
abhibh's Avatar
Thanked: 34 Times
Choose between JL / Audison. You wont regret it. JL A1400 is $220 on sonic.
Audison is 2 ohm stable in stereo mode AFAIK.
Old 24th January 2009, 01:18   #3
Thanked: 318 Times
JL A1400 is on backorder on sonic, couldnt find it for less than $280 on other sites.
For Audison, even the audison site says clearly not 2 ohm stable at bridged and so does woofersetc.com
Old 24th January 2009, 01:20   #4
abhinav.gupta88's Avatar
Thanked: 310 Times
JBL 7001 gives 700W @ 2 ohms
Its a good amp.
Haven't heard about stuff like Zapco before.
Old 24th January 2009, 01:27   #5
frankmehta's Avatar
Thanked: 2,334 Times
zapco is a very reputed brand!
anyways, JL audio makes very good amps, and so does audison.
but the JL G1700 (700W @ 2 ohms) - $280 looks the best bet!
frankmehta is online now   Reply With Quote
Old 24th January 2009, 01:30   #6
abhibh's Avatar
Thanked: 34 Times
Go for JL then. They are good amps. If you are going for 2 subs better get JL G1700 and it fits your budget perfectly
Old 24th January 2009, 01:54   #7
Thanked: 294 Times
JL G1700 is a better amp go for it.
Old 24th January 2009, 10:14   #8
navin's Avatar
Thanked: 4,284 Times
without listening to these amps I cant comment in detail but there is a lot of good stuff said about the JL G series on the other forums.
Old 24th January 2009, 11:02   #9
manikjeet's Avatar
Thanked: 110 Times
I had recently got a kenwood mono 9104d for about $187 i am loving it
Kenwood KAC-9104D Amp: Mono
it has got smooth bass and is performing flawlessly
as your budget is more i would suggest
Kenwood Excelon KAC-X1R
Kenwood Excelon KAC-X1R Amp: Mono
manikjeet is offline   Reply With Quote
Old 24th January 2009, 12:20   #10
superbhikari's Avatar
Thanked: 146 Times
Just go for Eclipse XA-1000. 300W @ 4 ohms and 480 W @ 2 ohms. Superb amp, lovely bass, You will get it for $150.
I got in Nov. 2008 from US at $150 from crutchfield.com.
superbhikari is offline   Reply With Quote
The 250/300 War! Ninja 300 vs CBR250 vs Hyosung GT250R jkdas Motorbikes 27 30th December 2013 19:14
Which sub-woofer for JBL 601.1 Mono? jagrocks7 In-Car Entertainment 19 12th April 2010 12:37
Polk Momo C 500.1 Mono Block AMP freakrz In-Car Entertainment 24 3rd June 2006 11:12
Returning from US-Advice needed on Mono-amp speedofreak In-Car Entertainment 8 7th April 2006 11:15
