Old 24th January 2009, 14:06   #1
shreyasma's Avatar
Default DIY: Bluetooth Handsfree in car for Rs 500
I always wanted to have bluetooth enabled in my car for easy use of mobile phone.
However, the readily available devices were way out of my budget. Then came this DIY.
The idea is very simple. I have used a buletooth handsfree like this
DIY: Bluetooth Handsfree in car for Rs 500-p100109_18.20.jpg
When the device is dimantled, this is what is inside. My idea is to connect the cut speaker wires to a 3.5mm jack and then into the AUX-IN of the music system.
DIY: Bluetooth Handsfree in car for Rs 500-p100109_18.3001.jpg
After attaching the cable for a 3.5 mm jack. Sorry, actually forgot to take the pic after attaching the jack
DIY: Bluetooth Handsfree in car for Rs 500-p240109_10.27.jpg
The place where the device is stuck using double sided glue tape.
DIY: Bluetooth Handsfree in car for Rs 500-p240109_12.40.jpg
After finished......
DIY: Bluetooth Handsfree in car for Rs 500-p240109_12.4101.jpg
DIY: Bluetooth Handsfree in car for Rs 500-p240109_12.4201.jpg
My problem now is charging the device. I have to use the existing USB port that always has my USB stick when driving. A USB hub doesnt work as per the pioneer manual. I did a lot of thinking and found out what are the 4 terminals in a USB and which one is for the power. For now i am charging with the USB port normally. In the next couple of days i will connect the power terminals of the existing USB port to a new USB port. And, can use the new port for charging.
Cost of the bluetooth handsfree was Rs 500/- as per the box in which it was packed. But i was lucky to get it free when i bought my phone.
Now when I get a call, I change the source on the headunit to AUX-IN and Answer the call
Any ideas and inputs from your end???
shreyasma is offline   (3) Thanks Reply With Quote
Old 24th January 2009, 14:11   #2
greenhorn's Avatar
Thanked: 1,518 Times
else you can use the 12 v output and use a seperate adapter for that
Old 24th January 2009, 14:19   #3
navin's Avatar
Thanked: 4,283 Times
Fantastic. Although I have never had the use for talking while driving this is a great idea for all the young ones out there.
navin is online now   Reply With Quote
Old 24th January 2009, 14:25   #4
jkdas's Avatar
Thanked: 1,436 Times
Brilliant one my friend. TBHPian of the day!
Old 24th January 2009, 14:45   #5
Thanked: 149 Times
oui!! me dumb, but what is the thing in the first pic??
Means - a better description would be appreciated!!!
Old 24th January 2009, 16:09   #6
badboyscad's Avatar
Thanked: 172 Times
@shreyasma : A very innovative idea. I never would of that anything like this. Install looks clean.how is the bluetooth headset's mic's reception. Is the person on the other side(the caller or call receiver) able to hear you clearly?
badboyscad is online now   Reply With Quote
Old 24th January 2009, 16:29   #7
hydrashok's Avatar
Great DIY! Hats off to you, shreyasma!
@backseatdriver, that is a bluetooth headset (the kind we use with a cellphone) in the first pic.
Old 24th January 2009, 17:54   #8
Thanked: 160 Times
Good work Shreyasma the job is nicely done, did you think of any other place to keep the Mic for a better reception
gowda79 is offline   Reply With Quote
Old 24th January 2009, 18:36   #9
shreyasma's Avatar
Thanks everyone. Am more than happy to see so many posts in just few hours
There are no issues with the reception of the microphone. And it is also stuck in such a place that the mic's facing the driver.
Few mins ago my wifey and i were speaking to a relative. And the other side person was able to hear both clearly.
I had called my friend during the test fit and asked him how different my voice was. His reply was - I am feeling you are in a closed silent room. are you in the bathroom???
shreyasma is offline   Reply With Quote
Old 24th January 2009, 18:57   #10
mnhegde's Avatar
@ shreyas : thats a fantastic one man. May the tribe (DIY) increase. It was very nice of you to share this experience. Thank you friend for such an economical and simple solution. cheers:
mnhegde is offline   Reply With Quote
Old 24th January 2009, 21:22   #11
leadf00t's Avatar
Thanked: 12 Times
shreyasma,
nice work dude.. brilliant idea. How does the whole volume level matching happen.
i.e. is the volume level correct or u need to pump up or pull down the volume when u select aux1.
How does the name BLUETOOTH show when u select aux1. is it a setting that u can rename source name in the HU
leadf00t is offline   Reply With Quote
Old 24th January 2009, 21:34   #12
vebmetal's Avatar
Thanked: 15 Times
So do you answer the call with your phone, or with the bluetooth headset? Either way, isn't it inconvenient?
vebmetal is offline   Reply With Quote
Old 24th January 2009, 21:54   #13
devarshi84's Avatar
Thanked: 119 Times
awesome DIY work. Should help many with spare Bluetooth headsets around. BTW I wonder how you start the calls? using the phone or the Bluetooth headset? is it convinient pressing the button behind the steering wheel?
devarshi84 is offline   Reply With Quote
Old 25th January 2009, 02:30   #14
frankmehta's Avatar
Thanked: 2,334 Times
absolute stonker of a DIY!
one of the best and most useful DIYS ive seen. congrats and keep up the good work, very inspired to do the same.
only one question. does it mean one has to switch from music listening mode to the aux mode as soon as the phone rings"?
Old 25th January 2009, 03:44   #15
This DIY is simply brilliant. I am sure gonna try the same process in my car
Maxthor is offline   Reply With Quote
Bluetooth car kit or Bluetooth HU? thefreak In-Car Entertainment 53 24th November 2009 12:59
Inspired DIY bluetooth handsfree for DXZ 785USB the_maassk In-Car Entertainment 3 15th August 2009 11:55
In-car Bluetooth Handsfree Earfree Kit Suggestions ? manveet Gadgets, Computers & Software 12 19th December 2007 22:54
