Old 27th January 2009, 16:45   #1
vigsom's Avatar
Thanked: 604 Times
Default Custom Sub Box - Your Views Please
The 10" sub I currently have(Philips 200WRMS) is in a sealed MDF wedge shaped box (don't have the recommended box enclosue for this sub)
Length 11"
Width 11"
Height1 6.5"
Height2 7.5"
Discounting the thickness of the MDF,that amounts to approx 0.35cu.ft
This box was custom made to be accommodated under the center seat of my Versa,but got made in a hurry esp when I was a novice in ICE.
It sounds decent with the engine in idle,but with the car in motion,some of the bass gets cut out.
Having tried all kinds of combinations and even moving the box upfront(I posted on this in the DIY forum),I am contemplating a revision as under:
Length 17"
Width 14"
Height1 6.5"
Height2 7.5"
That translates to 0.6cu.ft(after discounting the MDF thickness).
Please advise on the following so that I can take a call.
1.Will the sub sound better in this enclosure(I read that typically,sealed enclosure subs require 0.6-1.2cu.ft to perform best)?
2.In case it has to be ported, any special points to be noted?
3.This box will have the sub off center viz. the 10" opening will be created towards one end of the box and not in the center - that should not matter will it?
Request Help Sirs
Old 27th January 2009, 17:07   #2
Bass&Trouble's Avatar
Thanked: 71 Times
Make the bigger box. The efficiency should improve. Off-center sub is not a problem, in fact it's better that way.
Old 27th January 2009, 18:13   #3
condor's Avatar
Thanked: 4,903 Times
@Ajay, do you think specifying a volume will help vigsom better ?
Old 27th January 2009, 18:23   #4
Thanked: 71 Times
Most 10s like 0.6 - 1 cu. ft. It should atleast be better than what it sounds like with the 0.35 cu. ft., which is actually even lesser because he is not accounting for driver displacment (i.e. useful air space consumed by the subwoofer's magnet, basket etc.
Old 27th January 2009, 18:37   #5
Thanked: 294 Times
0.6 cu.ft is a good start...like Ajay Bhai (b&t) suggested a little bigger will be better. Like in tune of .8 cuft.
Old 27th January 2009, 23:15   #6
Magma's Avatar
if its a 10 incher i would try to see if i can accomodate 1cu ft and then get a ported box
Magma is offline   Reply With Quote
Old 27th January 2009, 23:17   #7
Thanked: 54 Times
Do you know the Thiele/Small parameters for the sub ? maybe you can find them from the net using the model number ?
Using the T/S parameters you can easily find out what box would be best for the speaker .
techn0l0gist is offline   Reply With Quote
Old 28th January 2009, 00:01   #8
WasavaTyres's Avatar
Thanked: 255 Times
I second technologist, I spent a sunday making one as per LBM,Navin and Sam's guidance and I've never been a happier soul. Check this http://www.team-bhp.com/forum/ask-gu...enclosure.html
WasavaTyres is offline   Reply With Quote
Old 28th January 2009, 13:08   #9
vigsom's Avatar
Thanked: 604 Times
Thanks Ajay and Paaji ; I used the data sheets of an Alpine and a JBL sub - both 10" to estimate that 0.6-0.7cu.ft would be reasonable for the Philips 10"
Thanks Magma.I have never auditioned a set up using a ported box but feel a sealed one would be ok for me.Also can't trust the box manufacturer here to build a "professional" ported box.Thirdly,the box would go under the seat and can't put in more than 14"x17"x7.5"
tried a lot - the model no. is ASW1000but got nothing on it except some viruses
Old 6th February 2009, 13:41   #10
vigsom's Avatar
Thanked: 604 Times
Eventually got a bigger box made.Dimensions were selected to make it a good fit under the center seat . The internal volume is now 0.74cu.ft and the bass is a shade better than what it used to be.
Till I post pics,just one question - the 8401 amp channel B has a +6dB bass boost switch.Would you recommend putting this on?
Also,is it worth introducing a 1.5" port in a box of this volume ?I am a little unsure of the results;hence did not get a port made.
Old 6th February 2009, 13:49   #11
Thanked: 294 Times
NO to the bass boost. And if happy with sealed why go ported ?
Old 6th February 2009, 17:42   #12
vigsom's Avatar
Thanked: 604 Times
Badshao,
Thoda sa pharak pada hai ; frankly I expected greater improvement with volume going up almost double
I tried the bass boost and felt the bass was becoming too prominent and "disturbing" the sound stage ,hence switched it off.
Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2 Endeavour333 Modifications & Accessories 130 11th September 2017 01:24
Honda Unicorn - Cosmetic and Performance mods - please give your views (Pics on Pg 9) rider60 Motorbikes 155 29th August 2013 14:02
Top Gear's Attempt at Killing a Toyota Hilux Truck - Please share Your Views vasanthn21 The International Automotive Scene 15 21st April 2010 22:20
Used May 2006 Toyota Corolla - Your views please carbaliga Sedans 14 20th July 2008 09:05
