Old 31st January 2009, 23:49   #1
Default GTO 75.4 Power Up issue
Hi Gurus,
There is peculiar problem faced by me on my GTO 75.4 amp.
The main issue is as soon as I power my audio system, a cracking sound comes up from the components. some thing like "Tick Tick".
When I opened up the boot i found that when the system is powered on the Amp goes to the Safe mode (Red Led lights up) for a moment and then resets to blue (normal). The same time the cracking sound comes out.
This occasionaly happens when I power off also.
What could be the reason?
Other than this I dont see any other issues with the performance of the amp.
Help Gurus??
Nandan is offline   Reply With Quote
Old 1st February 2009, 23:36   #2
flipsyde's Avatar
Thanked: 62 Times
I had the same problem with my earlier 75.4. Luckily I had the problem almost immediately after installing it so I got it replaced. I am not sure what the problem is.
I ran into the same issue some months back with my replacement 75.4 but that issue was sorted out by itself after 2-3 hours of not using the amp.
flipsyde is offline   Reply With Quote
Old 2nd February 2009, 08:52   #3
Is it the problem with the amp or the Power Wiring??
Gurus Please Help
Old 2nd February 2009, 10:32   #4
navin's Avatar
Thanked: 4,282 Times
take the amp bakc to the dealer. i suspect this is from inside the amp.
Old 2nd February 2009, 11:41   #5
Thanked: 294 Times
Gurus Please Help
It can be of the terminations also. Check out the places where you have connected the power cables.
Old 3rd February 2009, 08:12   #6
Will check out the power wiring and let you know.
Is it normal for the JBL amps to go on to the safe mode during the initial power up (red LED) and then switch to the normal mode ??
Old 3rd February 2009, 10:55   #7
cyclops's Avatar
Thanked: 9 Times
Hi nandan,
I have got a gt5 A604 amp by JBL, while it gets switched on, the red LED lights up for a few moments and then the green LED turns on. I guess it is a normal process.
But for the noise you are getting, thats something different. Maybe you have set your gains way to high..
Hi Gurus,
Help Gurus??
cyclops is offline   Reply With Quote
Old 3rd February 2009, 14:11   #8
live2drive's Avatar
Thanked: 25 Times
Check for loose connections.. The culprit could very well be the Ground Wire.. Relocate it such that it has good contact with the metal part of the chasis..
live2drive is offline   Reply With Quote
Power steering issue in my Swift VDI DieselFan Technical Stuff 23 17th May 2013 00:15
Esteem Slow Power windows Issue Stig Technical Stuff 72 4th October 2010 12:55
Major error in Autocar March issue & Overdrive April issue as well Guna Shifting gears 20 11th May 2010 11:15
Power steering issue in Alto shirishindurkar Technical Stuff 6 5th January 2009 22:43
Installed screens in Safari, issue is they power on automatically when car starts xbox360 In-Car Entertainment 18 18th December 2008 19:37
