Old 3rd April 2009, 11:40   #166
abhibh's Avatar
Thanked: 34 Times
Originally Posted by chiragh_bir View Post
What is the correct way to power 2+2 Ohm sub with JBL 1004?
any pic or diagram will help !!
Series Connection
In a series connection you simply connect the positive terminal of COIL 1 to positive terminal of the amplifier. Then you connect the negative terminal of COIL 1 to the positive terminal of COIL 2. Then you connect the negative terminal of COIL 2 to the negative terminal of the amplifier. The total impedance will be 4 ohm in the case of the above mentioned sub.
Old 3rd April 2009, 11:42   #167
navin's Avatar
Thanked: 4,282 Times
+ve = red
-ve = black
wire both coils in series. connect the amp the the +ve of coil 1 and the -ve of coil 2. then connect the -ve of coil 1 to the +ve of coil 2.
Old 3rd April 2009, 11:44   #168
DjNik's Avatar
Here you go, a series connection.
DjNik is offline   Reply With Quote
Old 3rd April 2009, 11:46   #169
Congrats on your new DVC. Do post the cost
ameenmaj is offline   Reply With Quote
Old 3rd April 2009, 11:51   #170
frankmehta's Avatar
Thanked: 2,334 Times
hi chiragh congratulations! a monster 15" in your getz!?!! brilliant! thats my boy. anyways, we need more pics. and HOW do you intend to power a 600W RMS DVC sub from 2 channels of the 1004? OR is another 1004 coming in the mail? hee hee hee..
Old 3rd April 2009, 11:54   #171
Thanked: 294 Times
There are many ways to wire a 2+2 Ohms dvc sub but the question arises how loud you wanna play.
Old 3rd April 2009, 12:10   #172
abhibh's Avatar
Thanked: 34 Times
May i also know those many ways in question here ?
Old 3rd April 2009, 12:12   #173
karankapoor's Avatar
2+2 ohms can either be wired @ 1ohm or 4 ohms or there are other ways also.
karankapoor is offline   Reply With Quote
Old 3rd April 2009, 12:59   #174
Thanked: 294 Times
I think of 3 possible ways...how many you guys think of ?
Old 3rd April 2009, 13:07   #175
i know only 2 possible ways,which are technically right.
tell us the 3rd way to wire a 2oh dvc sub .
Old 3rd April 2009, 13:31   #176
Thanked: 294 Times
If we consider a 4 channel amp and a DVC sub there are 3 possibilities...
Old 3rd April 2009, 13:33   #177
chiragh_bir's Avatar
Thanked: 70 Times
as loud & low it can go ..
tell me LBM ( bhai ) what you suggest
@ frankmehta for time being 15inch sub will be played through JBL1004 and i think that you update me that it produces 350rms @ 4 ohms , it is sufficient for woofer running in , what say?..
Search for mono is going on and that will be surely the next upgrade!!
chiragh_bir is offline   Reply With Quote
Old 3rd April 2009, 13:39   #178
abhibh's Avatar
Thanked: 34 Times
Well 3 ways are possible but chirag is using 1004 to power the compos too.
KK 3rd way is just like maverick555 setup. In which channels are bridged and each coils is powered by bridged channel.
huh ? Specs says:
3 channel mode: 2 x 100W RMS Components + 200W RMS for sub
Old 3rd April 2009, 13:43   #179
this a different thing,each coil to be powered by 2 channel bridged.
Old 3rd April 2009, 13:45   #180
abhibh's Avatar
Thanked: 34 Times
Check this. http://www.team-bhp.com/forum/sound-...-loving-2.html
Though you might have to be a bit careful.
Once upon a time, a Qualis was ICED. (Again!) speedzak In-Car Entertainment 106 3rd April 2009 03:31
Damn, a good install makes a difference!! My OHC Vtec ICED again GTO In-Car Entertainment 60 17th July 2008 12:39
Esteem ICEd...Work begins.. FATAL3RROR In-Car Entertainment 30 14th October 2007 14:33
Old Model Beetle being modded and ICED blueraven316 Super-Cars & Imports in India 47 9th August 2007 18:55
