Old 3rd April 2009, 13:50   #181
karankapoor's Avatar
ya i know this is not recommended one channel pop the sub out and the other pushes it in,one has to be careful doing this
karankapoor is offline   Reply With Quote
Old 3rd April 2009, 13:55   #182
frankmehta's Avatar
Thanked: 2,334 Times
i said 320W RMS. it produces 320W RMS @ 4ohm
abhibh where did you read it produces 200W bridged? its definitely not 200W
Old 3rd April 2009, 14:00   #183
abhibh's Avatar
Thanked: 34 Times
Care to explain a bit ? I am confused how it gives out 320W RMS
Specs are:
100 x 4 @ 4 ohm
150 x 4 @ 2 ohm
225 x 2 @ 4 ohm
3 channel mode 100 x 2 @ 4 ohm and 200 for sub @ 4 ohm
http://caraudiosecurity.com/shop/pro...s_id/8038.html
EDIT: Just checked sonic it says:
Bridged RMS Power 300 watts x 2 channels
Confusing...
Edit:
confusion cleared
JBL site says
100W RMS x 4 Channels at 4 Ohms; 150W RMS x 4 Channels at 2 Ohms; 320W RMS x 2 Channels at 4 Ohms
Old 3rd April 2009, 14:02   #184
chiragh_bir's Avatar
Thanked: 70 Times
its 320w @ 4 ohms bridged sorry franky !
so what rule to be followed bhai log ( friends) for wiring
box is ready for sub !!
chiragh_bir is offline   Reply With Quote
Old 3rd April 2009, 14:06   #185
frankmehta's Avatar
JBL Car & Marine Audio
why believe other companies when it says 320W bridged on the company website. yeti man, please correct me if wrong :-)
Old 3rd April 2009, 14:07   #186
abhibh's Avatar
Thanked: 34 Times
Wire the sub in series as you are using the other 2 channels for components. That gives the best power 320 @ 4 OHM.
Old 3rd April 2009, 14:12   #187
akshay4587's Avatar
Thanked: 1,686 Times
that was quick
chalo lets have a IC'Y meet in hot weather tommorow.
Bull's are here so need to fit them too.
il call all u guys in the evening.
Old 3rd April 2009, 14:17   #188
all the sites say 100x4@4oh and 320x2@4oh what about 3 way.
Old 3rd April 2009, 14:31   #189
Thanked: 294 Times
Everybody hyper active....
The three possible combinatnios are wire the sub in parllel give a 1 ohm (but not stable with the amp), Second is series the sub and give 4 ohms to the amp , third is put each coil to the each bridged channel.
If you want to extra max from the setup you need to run in the last mode....And make the enclosure as big as possible in terms of 4-5 cuft to extract max from the setup any smaller it will sound very bad and will not go low and loud. (And I am serious about it)
Any details of the sub as cannot find any...??
Old 3rd April 2009, 16:06   #190
abhibh's Avatar
Thanked: 34 Times
Sub details:
Blaupunkt - 扬声器 - Velocity系列 - V-SPL 15"
@ akshay let us know the plan of meet.
Chirag clarify whether you have 1 or 2 GTO 1004 ?
Old 3rd April 2009, 16:09   #191
ankit_chd's Avatar
Thanked: 28 Times
Hi
U bought this from Puri Autos sec 28 ??
I saw this with him last week , i guess . Was giving a gud deal on it ;p
ankit_chd is offline   Reply With Quote
Old 3rd April 2009, 16:22   #192
Thanked: 294 Times
Originally Posted by abhibh View Post
Sub details:
Blaupunkt - ‰声™ - Velocity系ˆ— - V-SPL 15"
Thanks Abhibbib...I cannot read anything as it is in Chinese Something in English would be much better.
Old 3rd April 2009, 16:29   #193
abhibh's Avatar
Thanked: 34 Times
Looks like you are trying to pronounce my TBHP handle in Chinese and still you state u can't understand it
Jokes apart. Let me translate
1400 Watt Max Power
600 Watt RMS
20-1.500 Hz - Frequency range
SPL - 2.83 V/1 m 93 dB senstivity
fs (Hz)30
Qts 0,41
Qes 0,45
Qms 4,9
Vas (l)110
Xmax (mm)+/- 10
Old 3rd April 2009, 16:41   #194
Thanked: 70 Times
Sub details:
I have just have one 1004
Old 3rd April 2009, 16:44   #195
This would be more than sufficient when you use the method no.3 mentioned by LBM.
ameenmaj is offline   Reply With Quote
Once upon a time, a Qualis was ICED. (Again!) speedzak In-Car Entertainment 106 3rd April 2009 03:31
Damn, a good install makes a difference!! My OHC Vtec ICED again GTO In-Car Entertainment 60 17th July 2008 12:39
Esteem ICEd...Work begins.. FATAL3RROR In-Car Entertainment 30 14th October 2007 14:33
Old Model Beetle being modded and ICED blueraven316 Super-Cars & Imports in India 47 9th August 2007 18:55
