Old 26th April 2009, 12:33   #241
abhibh's Avatar
Thanked: 34 Times
Which sub are you currently using ?
Old 26th April 2009, 12:45   #242
chiragh_bir's Avatar
Thanked: 70 Times
bhool gaya?
Am using the same Blaupunkt
chiragh_bir is offline   Reply With Quote
Old 26th April 2009, 13:16   #243
abhibh's Avatar
Thanked: 34 Times
Originally Posted by chiragh_bir View Post
bhool gaya?
I thought you sold that one. Well 2 x SPL in ported that too in getz i don't think they will fit, but i could be wrong. Have to check the box specs.
Also if you are going to use 1004 to power 2 subs then you have set gains perfectly on both channels else 1 sub will play louder than the other.
And i don't know why you want 2 subs ? You are already feeding the sub 300W RMS and its capable of 600W RMS. Get a MONO of atleast 500W RMS @ 4 ohm and feed the sub with it.
BTW yours is 2 OHM DVC. Is there a model with 4 ohm DVC ? If there is a 4 OHM DVC the ask Puri to swap this with 4 OHM DVC. Then u can power both the coils in bridged mode and feed the single sub with 600W+ RMS from 1004 and get a new amp for components.
- Buying MONO will set you back by 12K appx.
- Buying a SUB + new BOX + JBL A604/664 = 10K for sub & box + 5-6K for AMP that is 15-16K.
Better buy a MONO i would say
Old 26th April 2009, 17:13   #244
Thanked: 70 Times
how about JBL 75.4?
any problems with that amp?
Old 26th April 2009, 19:24   #245
abhinav.gupta88's Avatar
Thanked: 310 Times
There isnt any problem with the amp.
What are you planning to power off the 75.4?
The subs/the compos.
I liked Abhibh's suggestion.
If you can get it replaced by a D4, you can power it at 2 ohms and play the subs at nearly full potential.
Old 26th April 2009, 19:41   #246
frankmehta's Avatar
Thanked: 2,334 Times
@ abhibh: its a 4 ohm DVC.
so one can power one coil with 2 channels each. hence the 1004 can be given to the sub totally.
and you can get a good 2 channel or 4 channel for the fronts
Old 26th April 2009, 19:47   #247
abhibh's Avatar
Thanked: 34 Times
Now why u want 75.4 ? For compos or sub.
Frank the sub Chirag is using is 2 OHM DVC. If he can swap for the 4 OHM DVC then he can use 1004 to power both the coils of 4 ohm DVC.
Old 26th April 2009, 19:48   #248
frankmehta's Avatar
are there more varieties? i thought there is only a 4ohm available
Old 26th April 2009, 19:57   #249
abhibh's Avatar
Thanked: 34 Times
Well chirag told me his sub is 2 OHM DVC. The same is available in 4 OHM DVC as you have posted the pic below. We also have 8 OHM DVC in the market.
Old 26th April 2009, 19:59   #250
frankmehta's Avatar
chiragh can we have some confirmation on this? check the rear of the sub and tell us soon.
Old 26th April 2009, 20:06   #251
Infractions: 0/1 (10)
sorry posted in reply to an old post.
bharti22shresth is offline   Reply With Quote
Old 26th April 2009, 23:48   #252
Thanked: 294 Times
I think the 1004 is 2 ohms stable in bridged mode. And he can run a single sub with his 1004 like I mentioned when he first inquire how to wire the sub. But instead of running two subs on two 1004`s it is better to go for a minimum 1000-1500 watts rms mono amp.
And I think Chiragh has a 2 ohms DVC.
Old 26th April 2009, 23:53   #253
frankmehta's Avatar
Chiragh just confirmed to me that its 4Ohms. he went down and opened the sub.
LBM paaji, are you sure GTO1004 is stable @ 2 ohms when bridged? I really doubt that, since the specs on the JBL site dont mention 2 ohms bridged power anywhere
Old 27th April 2009, 00:08   #254
Thanked: 294 Times
Hmm...my bad...was confused with the older 75.4 .as it was 2 ohms stable..
Ok then it is 4 ohms DVC. then it is good
Old 27th April 2009, 00:10   #255
frankmehta's Avatar
yea, good no? i suggested he should use all 4 channels of the amp for one sub. 600+ watts of power will make his desire to get 2 subs vanish (for some time, its chiragh, nothing lasts for too long ;-P
Once upon a time, a Qualis was ICED. (Again!) speedzak In-Car Entertainment 106 3rd April 2009 03:31
Damn, a good install makes a difference!! My OHC Vtec ICED again GTO In-Car Entertainment 60 17th July 2008 12:39
Esteem ICEd...Work begins.. FATAL3RROR In-Car Entertainment 30 14th October 2007 14:33
Old Model Beetle being modded and ICED blueraven316 Super-Cars & Imports in India 47 9th August 2007 18:55
