Old 27th April 2009, 00:13   #256
abhinav.gupta88's Avatar
Thanked: 310 Times
It is not stable @ 2 ohms when bridged.
Minimum impedance when bridged is 4 ohms.
See : Features and Specs subhead on
JBL GTO1004 Multi-channel Amps Car Amplifiers Car Audio and Video - Sonic Electronix
Old 27th April 2009, 08:55   #257
ScarySkulls's Avatar
Thanked: 19 Times
Originally Posted by low_bass_makker View Post
Hmm...my bad...was confused with the older 75.4 .as it was 2 ohms stable..
Please enlighten on the 2ohm stable part.
ScarySkulls is offline   Reply With Quote
Old 27th April 2009, 10:01   #258
panky12345's Avatar
Thanked: 149 Times
I dont think 75.4 is stable at 2 ohms in bridged mode.. but in stereo mode, it is and probably this is what LBM meant
Old 27th April 2009, 10:03   #259
chiragh_bir's Avatar
Thanked: 70 Times
Sub is 4 ohm stable !!
I won't go for 2 subs now i sat down yesterday and did the calculations & it blowed me away :P
I think one sub powered nicely is more than enough as even when it is not playing on full potential it was much bassier than 2 JBL & 2 Pioneer.
Also saw that box is weak so i need to replace the box to much stronger one
ok here's the further plan
Convert the Sub Box to good quality MDF BOX
Am confused between Ported or Sealed Box cause ported boxes makes the bass go high but in sealed it played much more clean
Damp the boot
Power the sub with 1004
Pick a used 4 channel Amp to power compos( JBL or panasonic)
75.4 is for my sub as 1004 is beter for more compos as it plays cleaner
WIRING DIAGRAM FOR SUB PLEASE !!
chiragh_bir is offline   Reply With Quote
Old 27th April 2009, 10:37   #260
Thanked: 294 Times
Damp the boot
Wait for a day and your plans will be changed...which is a usual for you !!!!
What calculations you did ? Let us also know maybe we all here at T-Bhp help you raise your budget.
What happened you made a new box and it is already weak ?
A good designed ported box will sound equally good as a sealed box. But a incorrect ported box will sound bad, very bad.
I would say power the speakers through a 75.4 and wire the sub through 1004. I find 75.4 better sounding than 1004, but it is me you use both the amps and choose what you like the best.
Old 27th April 2009, 10:51   #261
Thanked: 70 Times
Bro box was designed correctly but the wood used by the guy is bad, the wood is ok for small subs. So i will get a free replacement from him
I think this time it will be a sealed box , do i need to use glass wool in box?
let me finalise with the amp and all going to have a look at 75.4 today which is lying with some one , or else i will pick JBL 604 or 644 brand new grey for compos
and lastly my plans change for 2 reasons 1 is I get bored with stuff very quickly and all this upgrades are done by my saved up money and not my earning so i have to run about to get good deals !!
Old 27th April 2009, 11:59   #262
ramie2400's Avatar
Thanked: 58 Times
There is no difference between the two amplifiers,when you open them they are same,604 is available in grey and 644 b&w (atleast in Mumbai)
GT5-604/644 SQ wise its not that great amplifier but will sound ok,as tried and tested you can and get the Infinity reference 475a,I think this amp is 2ohms table will deliever 75W-RMS comfortably or if you can get the kicker KX300.4 you would be drooling over it.
Ramie
Old 27th April 2009, 17:48   #263
Thanked: 70 Times
Ramie
my pocket doesn't allow me to buy high end amps
i will see if i can find some good used Amps
Old 5th May 2009, 11:44   #264
Thanked: 70 Times
Picked up Blaupunkt GTA 280 2 channel Amp for my compos
75x2 at 4 ohms
110x2 at 2 ohms
I think more than enough for my compos !!
Old 5th May 2009, 13:58   #265
Thanked: 310 Times
I would not agree LBM Paaji. But then its your opinion.
The 75.4 was a bit harsher as compared to 1004 for the tweeters atleast.
The mid bass is a bit more cleaner and more in the 1004.
However when powering the sub at 2 channels in bridged, the 75.4 is better than the 1004.
Don't think this should happen but that is my opinion on the basis of listening stuff.
The ones i was listening to was JBL 608c on both the 75.4 and the 1004.
Old 5th May 2009, 14:24   #266
Thanked: 294 Times
I do not challenge that..But again it is all about what you like...
Old 5th May 2009, 16:23   #267
Thanked: 70 Times
let' s see but now 75.4 is not coming the guy sold off his amp
Old 5th May 2009, 16:59   #268
zerocritical's Avatar
still looking for a 4 channel? go for a mono instead.. GTA for comps and mono for sub..
zerocritical is offline   Reply With Quote
Old 5th May 2009, 18:22   #269
Thanked: 310 Times
Even i respect your views. After all its your ears which are different than mine.
Different Preferences.
Some people find the Illusion Electras laid back and some don't.
Old 6th May 2009, 10:21   #270
Thanked: 70 Times
pulling my leg here
Once upon a time, a Qualis was ICED. (Again!) speedzak In-Car Entertainment 106 3rd April 2009 03:31
Damn, a good install makes a difference!! My OHC Vtec ICED again GTO In-Car Entertainment 60 17th July 2008 12:39
Esteem ICEd...Work begins.. FATAL3RROR In-Car Entertainment 30 14th October 2007 14:33
Old Model Beetle being modded and ICED blueraven316 Super-Cars & Imports in India 47 9th August 2007 18:55
