Old 4th February 2009, 14:07   #16
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by chiragh_bir View Post
... MODS DELETE THIS THREAD. ...
so thread moves on as navpreet bhai said..
@Chiragh_bir, if you are apprehensive of misdirected comments on your install, just ask for the thread to be locked and unlocked when you want.
Originally Posted by navpreet318 View Post
... Changes happen to most of us.
... don't spend any more on this system.Use it for about 6 months and then upgrade.
... Don't buy anything of which a dealer is not giving you a demo.
Very noble and wise thoughts, one must say.
Old 4th February 2009, 19:27   #17
abhinav.gupta88's Avatar
Thanked: 310 Times
Get a 1004 .
I looked for it for 3 months and had to go with a 1004 in the end!
Old 4th February 2009, 20:20   #18
chiragh_bir's Avatar
Thanked: 69 Times
what is the best way to mount 1004 in boot.. i don't want to fit on back of the seat !
chiragh_bir is offline   Reply With Quote
Old 4th February 2009, 20:34   #19
frankmehta's Avatar
Thanked: 2,318 Times
you can make a custom ventilated area for your amp near the spare wheel. dunno how much one can do in a getz. also, the 1004 can be fitted ON the spare wheel cover?
Old 4th February 2009, 20:41   #20
Thanked: 310 Times
See this. Specefically for Getz. This is how KPZEN mounted it in his Getz.
http://www.team-bhp.com/forum/attach...t-dscn5320.jpg
And A Few more
http://www.team-bhp.com/forum/attach...d-dsc01314.jpg
http://www.team-bhp.com/forum/attach...-rear-seat.jpg
Old 4th February 2009, 20:58   #21
Thanked: 69 Times
idea of kpzen is good but that amp is very small infront of 1004
other two are on the back seat which am not in favor of
Old 4th February 2009, 21:06   #22
Thanked: 310 Times
If you look carefully , the one in KPZEN's ride is also on the back seat.
Otherwise you can flush mount it in the sides. If there is some space.
Or by putting a MDF board and mounting on that like. :
http://www.team-bhp.com/forum/attach...l-dsc02376.jpg
http://www.team-bhp.com/forum/attach...l-dsc02379.jpg
Old 4th February 2009, 21:09   #23
frankmehta's Avatar
abhinav, yaar teri pari DEVIL se bhi badi hai! the boot accomodates too much man :-)
poor getz wont be able to fit 1004 on the sides without extreme modification..
Old 4th February 2009, 21:17   #24
Thanked: 310 Times
Woh to hai Doc.
He can do it on the rear seat or a flush mount.
Like
The boot mat. -> Put the amp. -> Create a MDF type thing done by Gunbir in his installs -> Glass covering the amp.
Old 4th February 2009, 21:22   #25
DjNik's Avatar
Why are you against installing it on the back seat?
I think it is the best location for the 1004 in the getz.
DjNik is offline   Reply With Quote
Old 4th February 2009, 22:05   #26
frankmehta's Avatar
i think chiragh bir has the same problem as me.. he has to keep it 'stealth' :cracking laughter:
stealth, from parents!
Old 4th February 2009, 23:43   #27
arpandiv's Avatar
Thanked: 27 Times
Install it on the seat. then make a frame of MDF OVER the amp. The frame will be away from the amp by 1/2 inch. Cover this frame with a black cloth.
arpandiv is offline   Reply With Quote
Old 4th February 2009, 23:45   #28
frankmehta's Avatar
and then get led.in.dickey.itis......
Old 4th February 2009, 23:53   #29
ramie2400's Avatar
Thanked: 58 Times
Getz rear seat is double fold so you need to have some techie wiring install so that even after mounting the amps the seats should double fold,if you use the rear seat folding option then its a bad idea to install over it.The best is you can install it on one of the side on a MDF board.
Old 5th February 2009, 10:15   #30
Thanked: 69 Times
yeah you right franky!!
ramiee bro some pics will be appreciated
abhinav.. you are right kp has it on back seat.. i have to seriously sit down and think about how to mount amp on side pannels .
75.4 can easily be mounted on side pannels ( saw in one of the threads) but donno about 1004..
arpan your idea is also not bad but i have to make ported cover so that air keeps on passing and amp doesn't overheat !!
Once upon a time, a Qualis was ICED. (Again!) speedzak In-Car Entertainment 106 3rd April 2009 03:31
Damn, a good install makes a difference!! My OHC Vtec ICED again GTO In-Car Entertainment 60 17th July 2008 12:39
Esteem ICEd...Work begins.. FATAL3RROR In-Car Entertainment 30 14th October 2007 14:33
Old Model Beetle being modded and ICED blueraven316 Super-Cars & Imports in India 47 9th August 2007 18:55
