Old 17th May 2009, 14:00   #286
Gill's Avatar
Thanked: 12 Times
looks like LBM visited the town!
So know the mids are in phase or out?
Gill is offline   Reply With Quote
Old 17th May 2009, 14:20   #287
chiragh_bir's Avatar
Thanked: 69 Times
yes he was here only for few hours but extremely busy!!
Mids are definetly better now!!
chiragh_bir is offline   Reply With Quote
Old 17th May 2009, 15:25   #288
Gill's Avatar
Thanked: 12 Times
Shed some light- what was done to make them sound better?
Old 17th May 2009, 16:01   #289
Thanked: 69 Times
Wiring was wrong from amp it self, actually my installer did wrong wiring , +ive terminal was engaged with -ive wire and vice versa!!
But LBM could make out in 2 mins ( I donno how ) he corrected it tuned the amp and bass was improved by 15-20% but no change in treble & vocals.
The gains were pretty high on JBL 1004 & i could not cross the volume level of 14 (top is level 40), now after reading & discussiing with fellow members am able to touch level 40 without any clipping & overloading the compos & Setting on HU is flat , HPF is selected to 90 . This makes me happy !!!
Man i just can't wait for my MONO !!
I will be using 2 different power cables from Finolex + fuse from Ichibahn for both the amps ( Now please don't start a war for Power cables )cause i found much simple to that way & not using power distribution block !!
Old 17th May 2009, 17:05   #290
Gill's Avatar
Thanked: 12 Times
Chiragh, From where are you sourcing Fuse holder and fuse as well?I looked around and found boss!No other options!
Good to read!that your setup is sounding better!
Old 17th May 2009, 17:25   #291
abhinav.gupta88's Avatar
Thanked: 310 Times
For Ichiban Fuse, Contact Smokin/LBM.
  • MANL60
    Chrome Plated Mini ANL Fuse 60A (Pack of 4) Rs. 350
  • IMANL100
    Chrome Plated Mini ANL Fuse 100A (Pack of 4) Rs. 590
  • IMANL150
    Chrome Plated Mini ANL Fuse 150A (Pack of 4) Rs. 790
  • IMANL200
    Chrome Plated Mini ANL Fuse 200A (Pack of 4) Rs. 990
P.S. I aint sure if these are new prices.
Contact them for the same.
Old 17th May 2009, 17:30   #292
Thanked: 69 Times
contact LBM , he can send 2 in one shipment and we can share shipping
I have already told him for mine !!
Old 17th May 2009, 18:30   #293
Gill's Avatar
Thanked: 12 Times
Thanks for the price of fuses,Abhinav!
What about price of fuse folder?
Old 17th May 2009, 18:54   #294
Thanked: 310 Times
  • ICMANL48
    Inline Capsule, Mini ANL Fuse Holder, 4/8GA in, 4/8GA out Rs. 450
  • IFH10M
    0/4GA input & 0/4GA output Mini ANL Fuse Holder w/2 Fuses Rs. 1,790
  • IFH10MD
    Digital 0/4GA input & 0/4GA output Mini ANL Fuse Holder w/2 Fuses Rs. 5,490
Again Not sure whether prices are same now.
Old 17th May 2009, 20:57   #295
Thanked: 39 Times
Originally Posted by akshay4587 View Post
you near ambala?
thats my hometown,you can audition my bulls here first -more VFM
Hi Akshay, I'll be passing by Ambala enroute from Delhi-Simla. Thanks for your offer mate, but two things- I've already auditioned Bull, and secondly, I'll be traveling with some friends and they'll surely beat me blue if I tell them to wait while I audition several set-ups on our way!
Originally Posted by chiragh_bir View Post
yes green horn you must try bulls first then you can easily make out how good are MTX from Bull !!
Man I have already auditioned Bulls, but didn't find them very impressive, perhaps because it was a super basic install and they were running minus an amp, tweeter position was not the best.. Maybe I'll audition them again in a better install, but that'll have to wait until i come back to Delhi!
greenh0rn is offline   Reply With Quote
Old 18th May 2009, 09:38   #296
Thanked: 69 Times
sure you just gimme a buzz if you need to audition them !!
Old 22nd May 2009, 16:09   #297
Thanked: 69 Times
am thinking for reverse mounting of sub in MDF box ... or free air mounting like manan's civic i don't know whether it is possbile or not in small getz..
also the board in trunk will be converted to plywood and covered with black mat & filled with foam so that it doesn't vibrate , this is because the woofer is heavy and original ply or plastic tends to bend from center and is getting spoilt which i don't want
Old 23rd May 2009, 09:33   #298
DerAlte's Avatar
Thanked: 2,879 Times
... plywood and covered with black mat & filled with foam so that it doesn't vibrate ...
Why would you want to fill with foam? Are you talking of the parcel shelf or the hatch doorpad?
I doubt if the parcel shelf is supported well enough (it is supported only on the shorter side edges) to carry the weight of the sub. A free-air sub is going to work there, but the output is likely to be muddy.
The main issue is controlling the sag of the parcel tray in the center of the long sides. It has to be made *very* stiff. Do the following:
* Use 1/2" treated ply and cut to the parcel tray profile first
* Get a frame made of 1" L or T shape steel angle
* Screw the ply on top of this frame
* Lay down fiber glass on the underside of the ply, about 5-6 layers. You could do this yourself or get some one to do it. Alternatively, stick 2 layers of fiber sheet (used to cover gates etc.) to the underside with Araldite
* After trial mounting the sub, cover the whole thing with the mat material
Old 23rd May 2009, 16:40   #299
Infractions: 0/1 (10)
Who is manan? Is it m4ugr8? If yes, then his subs aren't free air, they are in INFINITE BAFFLE. Bole to the the baffle of the sub gets infinite air. It's not exactly equal to to free air. It's very very much complicated. So much that beyond this I don't know anything about it.
bharti22shresth is offline   Reply With Quote
Old 23rd May 2009, 17:24   #300
hydrashok's Avatar
Yep, Manan is m4ugr8.
His subs look like they are in a Trunk Baffle/Infinite Baffle setup, but they are actually just mounted in reverse, firing into a sealed box.
Once upon a time, a Qualis was ICED. (Again!) speedzak In-Car Entertainment 106 3rd April 2009 03:31
Damn, a good install makes a difference!! My OHC Vtec ICED again GTO In-Car Entertainment 60 17th July 2008 12:39
Esteem ICEd...Work begins.. FATAL3RROR In-Car Entertainment 30 14th October 2007 14:33
Old Model Beetle being modded and ICED blueraven316 Super-Cars & Imports in India 47 9th August 2007 18:55
