Old 2nd June 2009, 15:52   #301
chiragh_bir's Avatar
Thanked: 70 Times
Ok my box is ready for sub..
its 2 cu feet of 0.75 inch of MDF board and is ported !!
Also picked L&T power cable 35mm2 for my --------amp
chiragh_bir is offline   Reply With Quote
Old 2nd June 2009, 19:39   #302
abhinav.gupta88's Avatar
Thanked: 310 Times
2 cubic feet.
Damn that's big.
Hmmm 2 gauge?
Nice nice. I think i know what's coming
Old 2nd June 2009, 20:40   #303
Thanked: 70 Times
its 1.75 cu feet to be more precise ..
will be using 3M sealant to seal the joints tomorrow morning !!
Old 2nd June 2009, 21:21   #304
frankmehta's Avatar
Thanked: 2,334 Times
good stuff man. take some photos of the box. want to see a LARGE 1.75 cu ft box in the boot.
Old 3rd June 2009, 11:50   #305
panky12345's Avatar
Thanked: 149 Times
use gorilla glue to seal the joints..
Gorilla Glue - Home
Old 3rd June 2009, 12:05   #306
Thanked: 70 Times
thanks for the link!!
are these available in India?
Old 3rd June 2009, 13:14   #307
karankapoor's Avatar
I don't think it is available in India you can use araldite to seal the joints this will work. By the way which sub will be going in this enclosure.
karankapoor is offline   Reply With Quote
Old 3rd June 2009, 13:54   #308
Thanked: 70 Times
same blaupunkt v spl 15 inch
Old 3rd June 2009, 16:46   #309
DerAlte's Avatar
Thanked: 2,879 Times
Gorilla Glue should be used only at the time of box construction. Used later, it will have no effect. If Fevicol has been used in the joints before putting screws, that should suffice for sealing the joint.
If the box is already made, one has to use something that will stay flexible over time. If the 3M sealant you mentioned is the common bathroom grout or glass sealant (tube applicator), adhesion to the MDF might be a problem - vibration will spoil the seal. The common carpenters' sealant for this is Fevicol mixed with sawdust, pressed into the joint.
Old 3rd June 2009, 17:02   #310
sonirohit's Avatar
Chirag - Have a suggestion for you - there are some enclosure calculators available online - which will help you determine what's the size of the box you should be building along with the frequency/power curve and some will go to an extent of specifying the various dimensions for your box...depending upon the size of your boot... try googling them out...
Finally you got a 2GA cable kya? From where??? What about the Fuse Box? Will you be using the same fuse box?
sonirohit is offline   Reply With Quote
Old 3rd June 2009, 17:28   #311
Invinsible's Avatar
Thanked: 60 Times
I have always used silicon sealant inside on the lines and on the outer joints onced it's screwed and than put the carpet on it after it has dried i.e. overnight. They work better and easier to use. A lot of experts recommend to use it.
Invinsible is offline   Reply With Quote
Old 4th June 2009, 13:34   #312
panky12345's Avatar
Thanked: 149 Times
.. better still use M-seal!
Old 4th June 2009, 13:47   #313
Are you sure one can use M-Seal on the joints, What i know M-Seal becomes hard once it is dries won't this will be a problem.
Old 4th June 2009, 14:28   #314
panky12345's Avatar
Thanked: 149 Times
Yes.. have used it myself a couple of years back on a sealed box, p-e-r-f-e-c-t even after 4 years!
Old 4th June 2009, 14:46   #315
sonirohit's Avatar
mseal - tends to stick quite well to wood - once while we were in college someone broke a wooden chari's backrest - mseal was used - and it held up very well for the next 4 years... But one would need to be extra careful not to miss small patches from where air could leak...
Once upon a time, a Qualis was ICED. (Again!) speedzak In-Car Entertainment 106 3rd April 2009 03:31
Damn, a good install makes a difference!! My OHC Vtec ICED again GTO In-Car Entertainment 60 17th July 2008 12:39
Esteem ICEd...Work begins.. FATAL3RROR In-Car Entertainment 30 14th October 2007 14:33
Old Model Beetle being modded and ICED blueraven316 Super-Cars & Imports in India 47 9th August 2007 18:55
