Old 5th February 2009, 10:23   #31
abhinav.gupta88's Avatar
Thanked: 310 Times
Check out Sam_786's install
The last upgrade he had.
Plan out something like this.
http://www.team-bhp.com/forum/sound-...e-setup-8.html
Old 5th February 2009, 11:18   #32
chiragh_bir's Avatar
Thanked: 70 Times
that is a bit complicated ..
chiragh_bir is offline   Reply With Quote
Old 5th February 2009, 11:51   #33
gigy's Avatar
Thanked: 41 Times
If you dont want to put it behind seat and if there is no space on sides then cut a plywood of size boot floor area and place amp on it. place well crow behind it to stay fixed to floor. keep the junction box on a side wall. this will help if it is to be removed out.you can laminate it black but dont cover with cloth. you can also raise it also by 5mm to give air circulation.keep a handle to help in rising it in case a tyre removal is required.
or
go to a professional and give him your requirement, he should do it better.
Old 5th February 2009, 15:25   #34
Thanked: 70 Times
Illusions has to go ...
As they are not suitable for my taste !! (Sorry LBM ) i corrected wiring but it didn't made much difference .
Will pick some other compos.. But in the mean time i auditioned blaupunkt vpc 172 and i liked it perfect for my taste
Old 5th February 2009, 15:41   #35
abhibh's Avatar
Thanked: 34 Times
I thought you already had Blau V 172 compos in your car...
Old 5th February 2009, 15:56   #36
Thanked: 70 Times
i sold those and then picked illusions..
but i think i made a big mistake selling those !!
Old 5th February 2009, 16:08   #37
Thanked: 17 Times
What do you dislike in the Illusions?
What did you like most in VPC172?
This will help us understand more better.
Old 5th February 2009, 16:41   #38
Thanked: 70 Times
speedzak you have my pm
Old 5th February 2009, 19:01   #39
panky12345's Avatar
Thanked: 150 Times
I think it would be better if you post it here for everyone's reference..
Old 5th February 2009, 19:21   #40
Thanked: 310 Times
As far as i know , he wants the compos to be bassy & little crisp.
Old 5th February 2009, 19:30   #41
panky12345's Avatar
Thanked: 150 Times
Then go for GZs.. simple..
BTW, how were the illusions powered? off the HU or with Blau GT4?
Old 5th February 2009, 19:50   #42
Thanked: 310 Times
I would also advice the GZRC-16X if you want bassy and crispy.
@ Panky , you need to listen to them , you'll love them
Old 5th February 2009, 20:26   #43
Thanked: 17 Times
Thumbs up Me too!
I recommended him the same but he doesn't want to discuss that in open it seems.
Many people don't like the so called laid back tweeters in Illusions. JBL produces good on the face kinda tweeters and it really gives a live feeling to the overall music. Many prefer this.
As far as I understand, he likes Blau VPC172. I think he should install it and forget everything else.
What say?
All these guessing games weren't necessary if he could post his likes/dislikes here.
Old 6th February 2009, 00:34   #44
Thanked: 294 Times
Zak he is also having some wiring issues. In which he has wired the midbass out of phase. I have mailed him two separate files in which one is original and in the other I have reversed the phase, so that he can distinguish which one plays better. He tried and told me that the file which is out of phase gives more bass and the one with normal ones give good vocals. Which clearly shows wiring issue.
I think tunning and proper wiring makes a major difference.
Old 6th February 2009, 07:12   #45
panky12345's Avatar
Thanked: 150 Times
+1. If he likes those comps, definitely he should!
Once upon a time, a Qualis was ICED. (Again!) speedzak In-Car Entertainment 106 3rd April 2009 03:31
Damn, a good install makes a difference!! My OHC Vtec ICED again GTO In-Car Entertainment 60 17th July 2008 12:39
Esteem ICEd...Work begins.. FATAL3RROR In-Car Entertainment 30 14th October 2007 14:33
Old Model Beetle being modded and ICED blueraven316 Super-Cars & Imports in India 47 9th August 2007 18:55
