Old 21st June 2009, 11:16   #436
m4ugr8's Avatar
Thanked: 123 Times
that is more than the cost of my entire car stereo system!
IF that is expensive, somebody I know recently bought a Car HU for 1.2L. Now that is double the cost of your setup.
BTW What setup do you have?? I am sure all TBHPians would like to know the setup of the ICE Guru on TBHP.
m4ugr8 is offline   Reply With Quote
Old 21st June 2009, 12:50   #437
chiragh_bir's Avatar
Thanked: 70 Times
1.2L ??
What head is that , post in your thread man !
chiragh_bir is offline   Reply With Quote
Old 21st June 2009, 13:00   #438
zerocritical's Avatar
Nice setup there chirag!!! Congrats!!!
zerocritical is offline   Reply With Quote
Old 21st June 2009, 13:01   #439
Even i'm wondering what HU is that!!!
Old 21st June 2009, 13:51   #440
Thanked: 294 Times
Wow...News travel very fast. I do not know how it got leaked but anyways let us see what happens next.
Originally Posted by chiragh_bir View Post
@ LBM .. Polarity was tested this time .. and compos are playing very well.. Actual fault was in car's original wiring , now am using all new cables so no issues with that.
Nice to know that, Enjoy ICE !!!!
Old 21st June 2009, 18:38   #441
DerAlte's Avatar
Thanked: 2,879 Times
"Chor ki dadhi mein tinka" case kya, bhai LBM?
Old 21st June 2009, 19:11   #442
m4ugr8's Avatar
Thanked: 123 Times
That news cant leak out, Lets not hijack this thread. That Install will be posted on TBHP soon.
Old 21st June 2009, 23:44   #443
Invinsible's Avatar
Thanked: 60 Times
Could it be Pioneer D7RII with RSP90 or may be a McIntosh???
Invinsible is offline   Reply With Quote
Old 22nd June 2009, 00:22   #444
Thanked: 294 Times
Bro I was not talking about your install. Enjoy.
Old 22nd June 2009, 18:23   #445
Thanked: 70 Times
what should be ideal distance of FR / FL and Sub from head for time alignment ..
Currently i have set to FR- 20 inches FL- 40 Inch and Sub- 50 inch
Old 22nd June 2009, 19:05   #446
abhinav.gupta88's Avatar
Thanked: 310 Times
You can do the TA by two ways.
1. Calculating the Distances.
2. Listening and Adjusting.
  • A. Calculating the distances
    Calculate the following distances
    1. Between You and the left mid bass = a
    2. Between You and the right mid bass = b
    3. Between you and the sub = c
    Now, the sub will get 0 delay, because it is the furthest from you.
    The delay for the left mid bass would be (c-a)
    and the delay for the right mid bass would be (c-b)
  • B. Setting to it by listening.
    Give your subs 0 delay.
    Bring your fader up front and the balance to the left.
    Not gradually increase the distance and listen and stop at the point where you find the sound integrating properly with the sub.
    Now bring the balance to the right and repeat.
    What you will have is sub 0 delay, left mid bass at x delay and right mid bass at y delay where y>x
Hope it helps
Old 22nd June 2009, 19:11   #447
Thanked: 294 Times
Abhinav he has a HU which has TA done with distance but you have one with Time delay. So doing the one with distance would be a bit different.
Chiragh read the manual you will understand from it easliy it is in plain layman english or you have Abhibi by your side of the town.
Old 22nd June 2009, 19:15   #448
frankmehta's Avatar
Thanked: 2,334 Times
LBM.. as far as i know, the first method is common for both. in fact Abhinav hasnt mentioned how to convert this distance to time in milliseconds. what is the difference between the distance and milliseconds method?
Old 22nd June 2009, 21:43   #449
Thanked: 310 Times
LBM Paaji, i have not converted the distances to time.
Frank.
Once you calculate the distance, take it into metres to convert it into time.
Delay for front mid would now be (c-a) meters / 340 metres/second =
(c-a)/340 seconds.
and similarly for right mid bass.
Convery it into miliseconds accordingly by multiplying 1000.
EDIT: Usually 340 is used but i guess the speed of sound is 343m/s so for more accurate result you may take 343m/s.
Also i feel that this method may not be always correct considering the speed of sound is 340 in free air but in a car, the sound has to travel with objections in between.
Legs for that matter.
Gurus ? Any Comments. Is this assumption true?
Old 22nd June 2009, 23:28   #450
Thanked: 294 Times
No Abhinav you were correct but the HU iinterface of Pioneer TA is of Distance and of Ecillpse is of Milliseconds. Thats why I said it. You are correct bro...
Once upon a time, a Qualis was ICED. (Again!) speedzak In-Car Entertainment 106 3rd April 2009 03:31
Damn, a good install makes a difference!! My OHC Vtec ICED again GTO In-Car Entertainment 60 17th July 2008 12:39
Esteem ICEd...Work begins.. FATAL3RROR In-Car Entertainment 30 14th October 2007 14:33
Old Model Beetle being modded and ICED blueraven316 Super-Cars & Imports in India 47 9th August 2007 18:55
