Old 22nd June 2009, 23:50   #451
abhinav.gupta88's Avatar
Thanked: 310 Times
Originally Posted by abhinav.gupta88 View Post
Also i feel that this method may not be always correct considering the speed of sound is 340 in free air but in a car, the sound has to travel with objections in between.
Legs for that matter.
LBM paaji, any comments on this?
Old 23rd June 2009, 08:12   #452
panky12345's Avatar
Thanked: 149 Times
Also, say in a sedan.. how the distance from sub is calculated, the shortest distance between ear and the sub assuming that there are no rear seats/obstructions? how?
Old 23rd June 2009, 09:27   #453
Thanked: 310 Times
usually yes panky ji. However this obstruction is what i am doubtful about. Should i calculate it without considering the obstruction. Or just by listening.?
Old 23rd June 2009, 10:00   #454
chiragh_bir's Avatar
Thanked: 70 Times
i tried doing TA of sub.. there was not much major difference
but on speakers it was noticeable difference even after changing location by 5 inches so i think will use inch tape to measure distance from speakers to my ears !! But again one more confusion the distance of mid bass or tweeters to be measured ?
chiragh_bir is offline   Reply With Quote
Old 23rd June 2009, 10:11   #455
panky12345's Avatar
Thanked: 149 Times
I asked the same question to LBM and his answer was from midbass!
Old 23rd June 2009, 11:54   #456
Thanked: 310 Times
yes it's the mid bass.
Having time alignment in a passive setup is as good as not having one. It's an active setup where the time alignment can be put to best use.
Old 23rd June 2009, 11:58   #457
Thanked: 70 Times
i surely need to catch abhibh on this now.. he was the one encourging me for 8850 and i missed 6539 !! :(
i spent extra for time alignemt and if that thing doesn't sound perfect some one will get killed by me ( kidding )
can my setup be converted to active without adding DSP and all ? am ready to do this but it should make world of diffference in sound !!
Old 23rd June 2009, 12:45   #458
Thanked: 294 Times
This shows you have lots of money to spend. Keep the setup like this for a while Let the speakers burn-in. Wait for a month and so after that decide.
But I know you will not wait and go ahead.
Old 23rd June 2009, 13:09   #459
Thanked: 70 Times
this time i have to wait .. no M to go further
But can 8850 work as active head like P80 rs?
Old 23rd June 2009, 13:16   #460
akbaree's Avatar
Thanked: 50 Times
I am surprised because TA, if done properly, should have created improved sound stage. But it depends how far is the sub in your present setup. What formula you are using for doing TA?
I don't know if your HU has ability to store presets. If it has, my suggestion would be that you can TA based on tweeters and mid basses and store the two presets. And then on extended listening sessions, you can see which works well for you.
akbaree is offline   Reply With Quote
Old 23rd June 2009, 13:16   #461
Thanked: 310 Times
did you try calculating distance and did you keep the sub at 0 delay.
If yes, then try the 2nd method i mentioned and see the difference.
Old 23rd June 2009, 13:17   #462
DerAlte's Avatar
Thanked: 2,879 Times
... Having time alignment in a passive setup is as good as not having one. It's an active setup where the time alignment can be put to best use.
And why so? One would think the only difference with a passive setup is that one is limited to -ive gain (attenuation) with passive components. Otherwise, for the same filter profile either will produce the same effect.
Are we confusing 'controllability' with 'inherent ability'?
Old 23rd June 2009, 15:29   #463
Thanked: 310 Times
You are still not able to align the tweeters as close to the mid bass. With 2 dedicated channels to the tweeters, one will be able to make maximum use of the time alignment..
Old 23rd June 2009, 16:30   #464
abhibh's Avatar
Thanked: 34 Times
But that doesn't means that TA in a passive setup is as good as not having one.
Are you running active or passive ?
Nope it cannot!
Old 23rd June 2009, 16:41   #465
mustang89's Avatar
sorry for the ignorance,i dont want to disturb the intersting thread going on here,but as i am new-
can somebody please explain whats the difference between active and passive?
please post some links for my knowledge.sorry for the interruption.
mustang89 is offline   Reply With Quote
Once upon a time, a Qualis was ICED. (Again!) speedzak In-Car Entertainment 106 3rd April 2009 03:31
Damn, a good install makes a difference!! My OHC Vtec ICED again GTO In-Car Entertainment 60 17th July 2008 12:39
Esteem ICEd...Work begins.. FATAL3RROR In-Car Entertainment 30 14th October 2007 14:33
Old Model Beetle being modded and ICED blueraven316 Super-Cars & Imports in India 47 9th August 2007 18:55
