Old 23rd June 2009, 16:52   #466
shreyasma's Avatar
Originally Posted by mustang89 View Post
sorry for the ignorance,i dont want to disturb the intersting thread going on here,but as i am new-
can somebody please explain whats the difference between active and passive?
please post some links for my knowledge.sorry for the interruption.
In active setup, the mid bass, highs and lows are split at the HU itself. In passive setup, an external crossover is used (same as what we get with the copmonent set).
shreyasma is offline   Reply With Quote
Old 23rd June 2009, 16:56   #467
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by abhinav.gupta88 View Post
You are still not able to align the tweeters as close to the mid bass. ...
In the US, at almost all restaurants one is told 'the lobsters are from Maine, the potatoes are from Idaho, the pork is from New York, the salt is from California ...' or something to that effect. Most Americans I have discussed this with, have told me that almost always everyone agrees that's special because "if they say that it must be so, I can't tell the difference anyhow". Another (childhood) story that comes to my mind is "Emperor's new clothes"!
Humour apart, does the TA system ask you whether you are driving the speakers active or passive? Or does it ask you "Are the mid-bass and tweeter sound like sitting on each other now with the current settings"?
I guess if we are trying to achieve so much precision as 'closeness of tweeters to the mid-bass', we have to use the same amount of precision in the complete ICE thought process, including instrumentation to confirm hypotheses. Otherwise, like the Emperor in the story, the low and mid end will be 'revealed', the soundstage will shift to rear, and we will be left chasing illusions instead of listening to Illusions, right?
Old 23rd June 2009, 18:31   #468
abhinav.gupta88's Avatar
Thanked: 310 Times
Originally Posted by abhibh View Post
But that doesn't means that TA in a passive setup is as good as not having one.
Are you running active or passive ?
It was just an expression abhibh. . What i meant was one can get full advantage of the TA when there is a dedicated channel each for the midbasses and the tweeters.
Right now i am running passive but you never know.
Lol.
But then when you are active you can fiddle around with the TA for the tweeters as well.
When you have 4 dedicated channels for the front - 2 for the mid basses and 2 for the highs, then you can align all the 4 channels seperately while when you have only 2 channels, one for the left(mid+high) and other for the left, you cannot individually align the tweeters and the mid basses.
I might be wrong though.
I am just a learner.
Old 23rd June 2009, 19:01   #469
DerAlte's Avatar
Arrey Gupta-ji, 'fiddleability' is no indicator of certainty of obtaining good results. Most things follow the KISS principle.
Old 23rd June 2009, 19:05   #470
Thanked: 310 Times
the KISS principle?
By the way in your opinion, isn't TA better applicable in a setup with seperate channels for all mids and highs than a passive one.
Old 23rd June 2009, 21:48   #471
Thanked: 39 Times
Sorry to interrupt, DA and Guptaji, your nice discussion (I'm following it closely and learning many things)- but here's a basic question on TA- does it always, invariably and inevitably create just one sweet spot for listening, or can we manipulate the system somehow to create at least two sweet spots, if not four?
greenh0rn is offline   Reply With Quote
Old 23rd June 2009, 22:01   #472
Thanked: 310 Times
I don't think.
TA is done to make all the sound come to the ear at the same time.
I don't think it can reach 2 different points at the same time.
Old 23rd June 2009, 22:58   #473
Infractions: 0/1 (10)
Default back to the topic now!
Ok now, before you guys go deep deep deep into the TA world talking about what not, things that goo absolutely above my head. Only thing that does sound correct is that sound should be heard by ears. Not the brain. Hear it, fiddle with it, hear it again, fiddle with it again, and then again keep on hearing and fiddling till you are satisfied.
I, Chirag, Abhi, Rushi(friend) met today to TUNE chirag's system. Armed with just a screw driver and 4 pairs of ears, boy we did a good job. (Yes I'm boasting. ). Don't ask about the tech stuff from me because I haven't a clue, but, do ask about the sound because that I do know something about. And for everyone saying TA doesn't make this difference then and this difference then, go listen to Chirag's car. Once with TA, once without. It's like differentiating a peacock from a hen. Chirag my friend, you got an amazing kit of stuff there. Hold on to it. HEAR it. Do not hear to what the OVER TECH world confuses you about.
By the way, change the sub box to sealed or else you'll seriously end up sending a Saree or two flying with the shear amount of AIR from that sub.
Abhi, do me a favor, post the video of the little pod dancing.
cheers
bharti22shresth
P.S. (Chirag's neighbors came out running just to heard what the whole ruckus was about, and we hadn't even turned the mono "on" then)
bharti22shresth is offline   Reply With Quote
Old 23rd June 2009, 23:48   #474
Thanked: 310 Times
Thats really nice to hear that he is enjoying the music.
Its not that TA doesn't make a difference.
It does.
Great amount of it especially to bring the sub up front and integrating it with the front stage.
But i wanted to say that a TA on a setup with dedicated channels for mids and highs would be better than the one in a passive setup.
Old 24th June 2009, 12:23   #475
DerAlte's Avatar
the KISS principle?
Keep It Simple, Stu...! No better example than what/how @bharti22shresth wrote.
By the way in your opinion, isn't TA better applicable ...
No, since IMHO I wouldn't be able to tell the difference. TA is about time of arrival at the ear, not innate high frequency qualities. If the tweeter response is (relatively) shrill, it will stay shrill (bright), and not become less bright, nor make the wave appear with any more accurate delay.
Originally Posted by bharti22shresth View Post
... sound should be heard by ears. Not the brain. Hear it, fiddle with it, hear it again,fiddle with it again, ...
Actually, it is your brain that is making you do the fiddling! If you just hear it (like they say "with you heart") you will go along with the lyrics, rhythmics and notes of the song without trying to split hair. If you want to listen to music, let your brain rest.
... just a screw driver and 4 pairs of ears, ...
Of course you should boast! Shabash, that's the spirit!!!
By the way, how did you 4 agree with each other? THAT is the most surprising thing.
Old 24th June 2009, 12:45   #476
panky12345's Avatar
Thanked: 149 Times
United Punjabi Spirit..
Keep it up guys..well done!
Old 24th June 2009, 13:30   #477
Thanked: 294 Times
So how do you find if you compare Abhihb and Chirag setup which one would you like more ?
Old 24th June 2009, 14:18   #478
sonirohit's Avatar
This calls for another TBHP meet @ Chd... Shreshth - Please do the honors
sonirohit is offline   Reply With Quote
Old 24th June 2009, 17:12   #479
I and abhi have near identical taste for music, chirag and rushi have similar taste for music. Hence we just tuned the setup so that it can go BOOM when the occasional "kida" comes up and rest of the time sing melodiously. Though it will be more to my liking if the tweeter position is dealt which it will be. Soon.
I'd have to say Abhi. Why? Because I'm not much of a fan of a back massage.
AHA! Well said. OK, CHDbhpians, Rohit sir's giving us all a treat at BARBEQUE NATIONS this weekend. Anyhow, he will have to because most of us are broke anyways so, might as well be "besharam".
Old 24th June 2009, 17:43   #480
Thanked: 294 Times
If we take the case of the fronts....
Once upon a time, a Qualis was ICED. (Again!) speedzak In-Car Entertainment 106 3rd April 2009 03:31
Damn, a good install makes a difference!! My OHC Vtec ICED again GTO In-Car Entertainment 60 17th July 2008 12:39
Esteem ICEd...Work begins.. FATAL3RROR In-Car Entertainment 30 14th October 2007 14:33
Old Model Beetle being modded and ICED blueraven316 Super-Cars & Imports in India 47 9th August 2007 18:55
