Old 17th February 2009, 22:00   #46
Awaiting Email Confirmation
Looks awesome ! Very nicely installed.
nitin.dangayach is offline   Reply With Quote
Old 13th October 2010, 00:28   #47
Thanked: 33 Times
Hi All
Sorry to bump up an old thread but I also got a similar setup installed in my Honda City Gxi (NHC) today. The setup consists of :-
HU - Kenwood KDC X7016
Amp - Kenwood KAC-8404
Front Comps - Bull Audio CS650.75
Sub - Bull Audio SW-12 (in a custom ported enclosure)
(Rear Speakers - Stock OEM ones)
Wiring Kit - Scosche
The install was done at Driven.
While i am satisfied by the quality of install, the tuning has somehow left me longing for better (i did not have the good-fortune to get my humble setup tuned by the resident guru Gunbir ji, as he is out of station).
Being a newbie that i am with advanced ICE settings and tweaks (mind you - i managed with the stock ice setup for 6 years ) i am afraid to tinker with the amp settings (gain,hpf,lpf et al) but would really like to find out the best settings for my setup (i read up about the same on t-bhp and elsewhere, getting myself confused even more).
So my question to the gurus is - how do i go about tinkering with the above setup (i'd really not like to bother Gunbir ji just for tuning a humble setup like mine).
Thanks guys - in advance, in the meanwhile, i'm off to more reading and exploring the realm of ICE settings!
Puneet.S is online now   Reply With Quote
Old 13th October 2010, 05:18   #48
Originally Posted by Puneet.S View Post
Hi All
So still getting that Treble/Bright sound??
Piyush_Vroom is offline   Reply With Quote
Old 13th October 2010, 08:27   #49
Thanked: 33 Times
Yes, inspite of setting the treble down to minimum... Infact, after some of the tweaking done by a helpful brother (not you ofc) last evening, now the bass also seems to be a bit more boomier than punchy (it was sounding much better while u sat in the car - bass was perfect, only treble was on the higher side). My only concern is whether the gains have been set at an optimal point (if theres such a setting?) or not. Will experiment with HU settings a bit and update.
Old 13th October 2010, 13:05   #50
abhibh's Avatar
Thanked: 34 Times
Considering the equipment you have i would suggest turning up the HU volume at 26-27 set the gains for components at 11 on the gain knob amp and sub at 12 position.
HPF for components at 80 and LPF for sub @ 80. Also check the tweeter attenuation level on the xover is set to soft and not loud.
Old 13th October 2010, 15:47   #51
Thanked: 33 Times
Thumbs up
Thanks Abhi for precise tip(s) .
Made a quick trip to the parking and checked out AMP settings. HPF & LPF switches for compos and sub respectively were OFF - set the comps to HPF and sub to LPF positions and set filter dials @ ~80 as you suggested.
Have also set the sensitivity (gain) dials for comps at 11-o-clock position and 12-o-clock for sub. Tweeter attenuation on the XOs is set to soft.
Also found the Bass boost switch in the amp to be ON, turned it off.
Turned off all the HU eq. settings to 0 and had a quick listen, the treble seems to have subsided a bit and bass sounds tighter.. not really sure as lunchtime got over and couldn't try out different songs .
Old 13th October 2010, 16:57   #52
abhibh's Avatar
Thanked: 34 Times
You can set the HPF and LPF via HU. Press the audio know > detailed settings > speaker type > front and set the HPF to 80 from there. Same for Sub and rear speakers.
Old 14th October 2010, 04:50   #53
The Crossover is set to Soft for tweeters
Old 14th October 2010, 16:00   #54
Thanked: 33 Times
Incidentally those values were already set to 80 in the HU when i checked. The overall sound seems to be much more balanced after the settings you suggested . Thanks again for the help.
Will visit Driven again though in order to rectify a few loose ends and fit a subwoofer grille.
Old 15th October 2010, 22:38   #55
Thanked: 33 Times
Default Another issue?
Visited Driven today and got the woofer grille fixed.
On Mr. Rana's advise, turned the HPF & LPF switches on the AMP to OFF position (as he said that HPF/LPF are already being controlled by HU x-over settings).
Afterwards, while trying to adjust some HU settings, I found out that the Subwoofer works when the Balance is set to either LEFT or center positions but not when the balance is set to RIGHT! Is this normal? Please advice..
Old 16th October 2010, 02:42   #56
abhibh's Avatar
Thanked: 34 Times
Yes please use the HPF LPF settings from the HU than the amp.
Regarding balance thing its not at all right. Get it checked ASAP!
Old 16th October 2010, 13:24   #57
Thanked: 33 Times
Got it checked, wiring seems to be okay, but the stereo/mono switch (for the channel which subwoofer is connected to) on the AMP was set to mono, setting it to stereo seems to have resolved the L/R balance problem.
New AT in the Family - i10 Kappa Sportz Auto ( blushing red ) manishkapadia Test-Drives & Initial Ownership Reports 3 27th January 2010 01:27
This baby rocks my SX4! dharmana In-Car Entertainment 41 2nd January 2010 14:35
Blushing Red i10 AT booked. madhukar_n Test-Drives & Initial Ownership Reports 30 13th August 2009 22:01
Budget ICE for Blushing Red i10-Gurus pls help MontyKING In-Car Entertainment 4 9th January 2009 18:02
Bull + kenwood > DDIS and GETZ noidaboy In-Car Entertainment 32 2nd November 2008 22:25
