Old 14th March 2009, 12:35   #91
abhinav.gupta88's Avatar
Thanked: 310 Times
Good option. Its just required sometimes and as far as i believe you will need it only when someone is sitting in the back. Not everyone will be able to differentiate between them.
Old 15th March 2009, 19:07   #92
ankit_chd's Avatar
Thanked: 28 Times
hi nice clean setup ... man congrats
Will be upgrading soon too .........
Can u give your reviews regarding the component sets ??
ankit_chd is offline   Reply With Quote
Old 15th March 2009, 19:37   #93
Thanked: 310 Times
Generally Asking.
Does your HU have 3 preouts?
Old 15th March 2009, 19:52   #94
frankmehta's Avatar
Thanked: 2,334 Times
i think it has only 2 pre outs abhinav. i can see from the pics on the 2nd-3rd page. its the stock verna HU. honestly notorious phaaji, naya head unit LE HI LO.. whatsay?
Old 15th March 2009, 19:56   #95
Thanked: 310 Times
I too would recommend that Jaspreet.
I would advice you to go in for something with 3 preouts , TA etc.
TA is definitely a great feature to have. Will completely change the feel of your Musique.
Old 16th March 2009, 11:03   #96
panky12345's Avatar
Thanked: 150 Times
Notorious, how about a detailed review and an audition?
Old 19th March 2009, 16:56   #97
NOTORIOUS's Avatar
Thanked: 89 Times
Sir Ji , Have Exams Till 15 april + Car is banged very very badly , will get it on sunday
NOTORIOUS is offline   Reply With Quote
Old 19th March 2009, 19:18   #98
abhibh's Avatar
Thanked: 34 Times
what happened to the car ? I hope everything is fine.
Old 19th March 2009, 19:31   #99
NOTORIOUS's Avatar
Thanked: 89 Times
Everything is fine , there is only me in the car. rest later .
Proof
Old 19th March 2009, 20:26   #100
live2drive's Avatar
Thanked: 25 Times
Hey Notorious, that looks ugly..
How the hell did this happen?
live2drive is offline   Reply With Quote
Old 19th March 2009, 23:25   #101
white_vdi's Avatar
Thanked: 18 Times
thats sad jaspreet!!
waiting to hear what happened. repairing her wont be a problem, thou it hurts i know.
anyways all the best for your exams!
white_vdi is offline   Reply With Quote
Old 20th March 2009, 00:15   #102
Thanked: 294 Times
Proof
Sad to hear that you car got busted....But is the ICE safe and working properly ?
Old 20th March 2009, 07:26   #103
sk456's Avatar
Thanked: 7 Times
It should unless he had speakers /amps installed in the headlights
sk456 is offline   Reply With Quote
Old 20th March 2009, 09:40   #104
panky12345's Avatar
Thanked: 150 Times
.. no problem notorious, it just happens.. glad to notice that you're safe! just ensure that the dealer doesn't have the access to your expensive ICE.
Old 20th March 2009, 10:54   #105
navin's Avatar
Thanked: 4,286 Times
ICE is pretty hardy.
flashback to 1989 (I know this is getting tedious to most of you). I had a Contessa 1.8.
The car's ICE at that time
1. Alpine 7385 (HU with no power amp)
2. Sony D160 on dash CD player mounted on the dash on a spring suspension.
3. Homebrew 4 x 35W rms amp
4. Home brew 200W 8ohms amp made using IPL power amp chips similar to this photo below modified to dump about 1000W to 2.8ohms (pushed bias point lower and added extra pair of output transistors and upgraded power supply)
200W POWER AMPLIFIER MODULE
5. Front and rear speakers 6" 3 way using Polk MM 6500 woofer, 2" LPG dome mid and 1" LPG dome tweeter (removed both faceplates and mounted both on a single custom faceplate made from 3mm aluminum) with my own crossover
6. subwoofer 3 x 10" 8ohm woofers in a Transmission line. The woofers were custom made by a compay called Dhawni Audio in Valsad Gujrat using parts they had revieced as samples from Eminence USA.
I was returning home after dropping a friend's father to the airport (the bags were put in the rear seat). The road I was on was in the process of being concreted and the workers had left huge 12" x 12" x 6 foot long concrete blocks on the road as a divider between the north and south going lanes.
I was going south, a taxi going north hit one of these blocks that spun and moved right into the path of my car. I hit the block pretty hard. So hard that my car was now suspended on the block and the steering colum had colpased (saving me) and the 4 wheels of my car were now not on the ground.
The impact was severe but the CD player did not skip a beat. Even as I was suspended on top of this block of concrete the CD player was still belting ourt Bonjovi's "Dead or Alive".
I reached a phone at an open Indian Oil office and called a friend and eventually got the car towed to the garage. The suspension, exhaust and atleast one axle had to be replaced but the ICE lived!
Iced up my Verna CRDI monochrome In-Car Entertainment 27 1st December 2009 00:56
Hyundai Verna ICED! live2drive In-Car Entertainment 50 22nd June 2009 09:35
Notorious Modification of an Automobile SirAlec The International Automotive Scene 3 28th March 2009 19:26
Hyundai Verna the beast iced mohitd In-Car Entertainment 24 23rd January 2009 12:58
