Old 17th February 2009, 18:10   #1
Awaiting Email Confirmation
Default Amplifier Installation Help: For DIYer
Finally got my stuff from a fellow TBHPian (ABHIBH - THE SAVIOUR). Yeah ! My wait for the Kenwood KAC 8401 is over now. I did it
Now the next step is the installation.
Well have two ideas in my mind: 1) Got to the installers (Driven/Gyro) or 2) DIY (my way)
I am terribly inclined on making it a DIY so I'll try to do a DIY first.
This thread is simply intended to gauge my capability to do it myself. If I find that I wont be able to do it better, I'll any way get hold of the GURUS.
The Gear:
I have already bought Sosche E1000 wiring kit for this day Just need your help to get one more RCA interconnect cable (Suggestions needed for under 600 bucks RCA cable)
The Kenwood KAC 8401 will be with me in a week's time.
I guess, I don't need anything more than that.
Amplifier Placement:
I am still unsure about the right place. It essentially depends on the RCA cable length I get finally. If its 6ft, It'd have to go below the front seat else in the boot. (Suggestions ???)
The Wiring:
This is what I am little unsure about. Although I installed my HU and speakers myself, but here in this case things are not so easy, it seems :P
I'd require some brief pointers on how to go about this, the key contact points and what key things to take care of. (Instructions )
The Tuning:
This one is little subjective and is a pretty iterative process, as I take it. There already is thread stickied about this, but I am including this one in this thread since there might be some personalized things that'd be required (after I finish the install).
Last edited by Technocrat : 17th February 2009 at 18:23. Reason: only two smilies per post allowed
nitin.dangayach is offline   Reply With Quote
Old 17th February 2009, 19:03   #2
live2drive's Avatar
Thanked: 25 Times
Hmm nitin if you are keen on installing the stuff yourself, Just go to an installer, install the stuff yourself there so that the installer can guide/correct you. This would be the safer option rather than doing a DIY at home. Coz then you can get proper tools to work with at the installer's place.
Scosche RCA cable costs Rs550/- available at Driven.
live2drive is offline   Reply With Quote
Old 17th February 2009, 19:07   #3
Well actually I am at gurgaona and dont want to waste a day to go to delhi and get the stuff installed. If I dont't get into the BLING factor, thats hardly an hours job (not counting the TUNING time) :P
BTW that Scosche RCA is plain or twisted ? I need a twisted pair RCA. Can someone confirm ?
Old 17th February 2009, 19:10   #4
live2drive's Avatar
Thanked: 25 Times
No, the scosche RCA is non-twisted.
I think the Stinger RCA is a twisted pair RCA. Costs around 900.
Old 17th February 2009, 19:12   #5
vibhu_f430's Avatar
Thanked: 67 Times
Hi man , let me help you with a few pics,
In my swift, there are 2 amps.. each mounted under the front seats, All the wiring ( RCA, Power cable etc ) go through the transmission tunnel ..
Amplifier Installation Help: For  DIYer-dsc01506kkk.jpg
Amplifier Installation Help: For  DIYer-dsc01505kkk.jpg
Amplifier Installation Help: For  DIYer-dsc01601kkk.jpg
Just taught i can help you with some ideas..
Cheers !
vibhu_f430 is offline   Reply With Quote
Old 17th February 2009, 19:16   #6
Any other RCA, Twisted of course, under 600 ?
Old 17th February 2009, 19:17   #7
Attachment 101968
Attachment 101969
Attachment 101970
Cheers !
This is grt. You installed in under the seat. I was just thinking of placing it on the floor under the seat. Thanks for this man.
Old 17th February 2009, 21:34   #8
abhibh's Avatar
Thanked: 34 Times
nitin you should edit your signature now
And take it to GYRO. They will do it professionally and tune it the way you want it.
Old 17th February 2009, 21:38   #9
Sure sir ! Anything for you
Old 18th February 2009, 16:30   #10
Ok I have bought the AMP from ABHIBH and it will reach me on Tuesday. Till then, I am hunting for a good RCA. ANy suggestions ? Can anyone ship them to me ?
Old 24th February 2009, 13:20   #11
Default Update: 24/02/09 (Partial Install done)
Got the Amplifier. Wiring Kit was already there. RCA cables are in transit.
Time for some action now.
I stripped off packing of the Amplifier and the Wiring Kit. The amplifier is sure a beauty. But the wiring kit amazed me. Damn those wires were too heavy, too thick. I wondered if we actually need them but later realized, I bought a wiring kit which is pretty much an overkill for the TRANSISTOR (Panky's favourite) errr.... KAC 8401.
I was confused to see those different types of wires but then started working on them, one at a time.
Splitted the Power cable into two parts (to fit in the fuse). The next step was fixing all the lugs/or whatever they are called, to the wire ends. That was definitely a task. Spent like an hour to do 6 ends :P. But the results were satisfying.
Then there was time to enclose the power cable with that black sleeve. Took 10 minutes (could have taken much less had it been done before fixing the connector ends.)
Then was the time to fit in the Power cable, One RCA into the car. This one was terribly challenging. I started with the Power cable. Opened the bonnet and removed that rubber thing to let the power cable move into the car cabin. That was easy. The tough part was to route the cable into the boot. Had to take out a number of fixtures on the right side of the car to put in the power cable. The portion where it was really painful was routing the cable, lying upside down on your back, under the steering wheel and to move the think wire ensuring that it doesn't get in the way of the Accelerator, Brake or Clutch. Took me just 20 minutes but they were really painful.
Next was to open up the Stereo Chasis to hook in one RCA interconnect cable that came with the wiring kit. That was easy so was just a breeze. another 10 minutes and I laid down the RCA cable (through the left side of the car to the back.)
Now the power cable was done and one RCA was done.
Next was fixing the Earthing connector. I searched for some bolts that I could take out and hook in the grounding wire. Took out the stepney to locate some. Located one bolt which was on the rear left end of the car and was about a feets distance from the prospective place of the Amlifier seating. But since I did not have any spanner of the right size, I could not turn it out. Tried hard with a plier but failed
Then changed the strategy and found another hole nearby and rubbed the paint on the surface, to allow better grounding. But again I did not have the screw/bolt of the right size to fix the ground cable.
By this time, I was little tired and it was time to have the breakfast so left the things in the very messed up state, they were.
Will try to work more on it tomorrow. I am hopeful that by that time, I'll have the other RCA with me. Also I'll go to some mechanic ang will try to get one screw that will fit in the grounding hole that I have chosen.
Here are some of the pics:
The package
Closeup
Pandoras Box
The Thing
View 1
View 2
The DIY Mess
Ground Cable (LOL, for the fingers are actually in focus)
Fuse Block
Will post more pics tomorrow.
Old 24th February 2009, 13:25   #12
abhibh's Avatar
Thanked: 34 Times
Nitin use thimbles for power and ground wire in amp terminals. Don't just put the cable directly in the terminals.
Old 24th February 2009, 13:37   #13
Yeah man. Using them. I didnt know that those things are called thimbles.
Had a hard time fixing them on wires. And they a little big for the amp. I had to break small chips of the bakelite body, at the amp, in order to accomodate them.
Old 24th February 2009, 13:59   #14
noidaboy's Avatar
Thanked: 260 Times
Congrats buddy! Diy have begun? Keep us updated with pic's
noidaboy is offline   Reply With Quote
Old 24th February 2009, 14:18   #15
Thanked: 294 Times
You have to use correct type so that you need to alter the amp terminal. One would require this tool to crimp them properly to get the best use of the thimble else it would not function properly. Here are few pics of the same...
Hydraulic Crimping tool
Good crimping result
Bad Crimping result
In this wire will not hold in the thimble and will come out resulting in loose connection and it might result in some major consequences like fire, amp damage etc...
Tools for a DIYer kvish DIY - Do it yourself 1892 19th July 2018 13:37
Amplifier Installation Fuse Question aseem In-Car Entertainment 13 18th November 2010 15:12
Pls help me Urgent: Help me to connect ipod classic to amplifier vasudeva Gadgets, Computers & Software 2 5th October 2009 17:14
Help: Setting amplifier amit_sound In-Car Entertainment 11 9th March 2007 09:15
Help me with my amplifier WILDTHING In-Car Entertainment 1 2nd January 2005 11:32
