Closed Thread
Old 10th March 2009, 11:53   #136
Thanked: 294 Times
Originally Posted by frankmehta View Post
The LOWEST bass maker in North India has spoken. The windows have been shaken(literally) and everyone has been silenced :-) Waah lbm paaji!!
Thanks Franky..It is my commercial involvement with the brand which is stopping me from declaring the win.
Firstly your question should really be how many time will you listen to 140db+
My answer would be exactly once. After that you'd be deaf.
However there are 2 reasons for having that capablity.
1. A system that can produce 140db+ cleanly will be do a very good job of 100 db as well as it will be working well withing it's limits.
2. in LBMs case; you see my dear Invisible, our friend LBM is a true believer of Newton's 3rd law of motion. By facing the cones of his subwoofers towards the rear of the car he is able to propel the car forwards just by turning on his stereo system. :-)
Thanks Navin Ji for your kind words. SPL is not that easy as it looks. You need to work very hard to achieve it.
low_bass_makker is offline
Old 10th March 2009, 12:03   #137
Invinsible's Avatar
Thanked: 60 Times
Paaji I am sure you might be making those subs dance to tune surely. Something like this
Just in good Humour
Invinsible is offline
Old 10th March 2009, 12:11   #138
karankapoor's Avatar
Just in good Humour
this is happening becouse the camera is not goog enough to catch it
mods sorry for double post .
karankapoor is offline
Old 10th March 2009, 12:11   #139
m4ugr8's Avatar
Thanked: 123 Times
dB Numbers are something very surprising, that is what i experienced at the dB Drag which happened in Delhi recently, Some setup numbers were very low compared to the amount of Bass they were producing and some setup numbers were like
A Single Sub in somebody's car getting numbers more than two woofers in another setup.
@Abhinav: You did not get the 1400.1 installed till yet, I thought it was complete by now, dont think to much add another Monoblock and it would be fine
m4ugr8 is offline
Old 10th March 2009, 12:34   #140
Invinsible's Avatar
Thanked: 60 Times
Default World record from a single woofer
Digital Design subs can do wonders single handedly by achieving 180db from their single woofer and amp. Ofcourse to get these there many more things which are involved more batteries, alternators, better electrical wires and system, tons of deadening and many more. Which can turn out to be more expensive than just buying the sub and amp.
World Record 180.5 dB From a Single Subwoofer [audiojunkies]
Old 10th March 2009, 13:54   #141
abhinav.gupta88's Avatar
Thanked: 310 Times
Not yet manan.
That single sub is running on full potential and the car is very small compared to my car.
I havent done the install yet. The money is almost ready. The only thing is the final check , if it goes fine, it will come soon and another surprise ( Non ICE is coming soon too).
abhinav.gupta88 is offline
Old 10th March 2009, 13:56   #142
Thanked: 294 Times
I am here guys...
About the above install in question the who idea was to get the max efficeny out of the enclosure and the car acoustics. In the above install only at one freq it will peak rest it will be quite less. And it will not be musical sounding as it is for only for SPL. But there is another genre of SPL lover for those there is BASS RACE and it is quite challenging also...
Old 10th March 2009, 15:12   #143
Congrat LBM on your db drag win. With all humility I never thought I'd meet a man madder than myself until you appeared.
Karan, to achieve 140+db cleanly it not diffcult but you have to observe many rules of car audio and understand their limitations. The car needs to be damped, the car's power supply needs to be capable, the subwoofer boxes need to be correctly designed, the amps and processors need to be tuned and set to be operating within the safe working limits, ...the list is quite long.
thanks navin!!!
but aren't this all applicable to a sq system,say no proper damping result to viberation,enclosure size and tuning,proper cabling.
and can't a sq setup acheive big figure's say 145 db or +
Old 10th March 2009, 15:37   #144
navin's Avatar
Thanked: 4,282 Times
Originally Posted by karankapoor View Post
thanks navin!!!
sure the demands to set up a good SQ system are not that different from a good SPL system
navin is offline
Old 18th March 2009, 22:22   #145
@abhinav i don't know whether you know about this or not.
blaupunkt vpa11500 rated 1500x1@4ohms & 2200x1@2ohms i think they are overrated
Old 19th March 2009, 19:29   #146
Thanked: 310 Times
Oops. I should have updated the thread
I have decided on my amplifier.
Thanks for the suggestion Karan.
@ Mods if required please close the thread.
Old 19th March 2009, 19:48   #147
Please let us know on the amp you have selected.
ameenmaj is offline
Old 19th March 2009, 20:19   #148
jagrocks7's Avatar
Thanked: 7 Times
Hey Abhinav,
Which amplifier have you decided? Or you planning to give us a surprise.? Do let us know..
jagrocks7 is offline
Old 19th March 2009, 20:32   #149
abhibh's Avatar
Thanked: 34 Times
Oh Thank god atlast the decision is taken. Spill the beans
abhibh is offline
Old 19th March 2009, 20:47   #150
Thanked: 310 Times
I'd like to keep it a secret till it comes.
It ain't that big but then i've changed one and will add another later.
Closed Thread
Difference between a Monobloc and 2 Channel Amplifier for the Subwoofer? frankmehta In-Car Entertainment 52 21st November 2011 17:23
Advice needed for performance upgrade for the 1.3 Ikon Dragonov Modifications & Accessories 5 4th June 2006 12:43
Budget Car Audio Advice Needed Guys thief In-Car Entertainment 22 26th January 2006 14:59
advice needed: car audio in hyundai accent amit_baghe In-Car Entertainment 273 25th December 2005 00:04
Repainting & "Sumo to Sumo victa" conversion. Advice needed. nitrous Modifications & Accessories 0 21st November 2005 12:57
