Closed Thread
Old 26th February 2009, 11:32   #91
abhinav.gupta88's Avatar
Thanked: 310 Times
Originally Posted by noidaboy View Post
The 700.1 is rated as
175w X 2 @4ohm's
325w X 2 @2ohm's
650w X 1 @1ohm
The 1200.1 is rated as
400w X 1@4ohm's
800w X 1@2ohm's
1200w X 1@1ohm
This is what noidaboy had mentioned on another thread.
P.S. why in the 700.1 i see 175*2 and 325*2, is that a typo?
abhinav.gupta88 is offline
Old 26th February 2009, 11:39   #92
Its a two channel amplifier the model number is 700.2
Autophile is offline
Old 26th February 2009, 15:10   #93
navin's Avatar
Thanked: 4,346 Times
Originally Posted by low_bass_makker View Post
Since yours is a D-Class I would take 75-80 % efficiency.
AB class it would be 50 % efficient
Originally Posted by Autophile View Post
Just in case you need help with the specs of your amplifier. Waiting for your expert insight on this.
May I jump in?
For Class A, B, and AB amps the efficeincy is determined by the quiescent current (also called bias) flowing through it's transisitors.
Class A amps that are the least efficeint in translating input power (from the power supply) into output power (at the speaker) have an efficieincy of about 50% (a little less in reality)
Class AB amp are about 65% and Class B amps are as high as 75% (theoretical limit is about 78%). Class D amps however do not use the same technology as Class A, AB, B. Class D amps use a switching supply which operates a very high frequency and hence can achieve efficiencies greater than 90% (theoretical limit is 100%).
but this is just the basics. there are other factors (heat sink size / fan cooling, number of stages, and atleast for tube amps the topology long-tailed-pair vs SRPP for example) that can determine the overall efficiency of the amp. Without a rigourous study of the amplifier's schematics and test bech results I would not hazzard a guess leave alone debate an amplifer's exact efficiency. Then again I am NO Guru.
navin is offline
Old 26th February 2009, 15:24   #94
noidaboy's Avatar
Thanked: 260 Times
Yes that was a typo.Apologies
noidaboy is offline
Old 26th February 2009, 17:10   #95
Thanked: 310 Times
I aint getting it.
was 700.2 the typo or the power rating at 2 ohms
If the typo was 700.2 , then how come 650 x 1 @ 1 ohms
and if it was the power rating type then how come 325 x 2 @ 2 ohms
I'm totally confused.
P.S. Whats the price of the 700.1 (/2)
Old 26th February 2009, 20:39   #96
frankmehta's Avatar
Thanked: 2,358 Times
leave the hassle. buy another 14001 and sleep a 'chain ki neend'
frankmehta is offline
Old 26th February 2009, 20:42   #97
Thanked: 310 Times
Chain ki neend wont come until i have another one in my car.
Trying my sub at 4 ohms tomorrow most probably and decide accordingly.
Old 26th February 2009, 22:03   #98
How much is the cost for JBL 14001 with and without b&w
ameenmaj is offline
Old 26th February 2009, 22:11   #99
noidaboy's Avatar
Thanked: 260 Times
I aint getting it.
Bhai mere the model is 700.2 (Its a 2 CH amp.)
Rest you can visit the website to get all its spec's
Oh are you preparing for the event by anychance?
noidaboy is offline
Old 26th February 2009, 22:14   #100
Thanked: 310 Times
Thanks for the clarification. Will check it out.
As for the event, not yet. Will do it tomorrow most probably.
Old 27th February 2009, 10:32   #101
navin's Avatar
that must mean 650x1 @ 4 ohms. Few amps can drive 1 ohm in bridged mode.
Image Dynamics Q 700.2 - Image Dynamics 2-Channel 700 Watt Amplifier
navin is offline
Old 27th February 2009, 10:40   #102
navin's Avatar
the website I visited did not have the specs of the 700.2 hence I had to quote woofersetc.
navin is offline
Old 27th February 2009, 11:18   #103
Thanked: 310 Times
Thanks for the link navin sir.
I was about to search it soon.
Old 27th February 2009, 15:14   #104
Thanked: 310 Times
Update : Checked the amp by wiring the sub at 4 ohms.
The problem earlier was that my subs need 1000w each ( = 2000wrms) while JBL gives 1500w rms at 2 ohms.
So the subs were underpowered.
Due to this, at high volumes, the amp used to reduce the volume / bass at higher volumes.
Now after getting it checked, JBL gives 1200w rms at 4 ohms(14.4v) to the subs which needs 1000w rms. There is no lowering of volume / bass at full volume too.
Thanks for the suggestion guys, i will buy another JBL 14001.
Old 27th February 2009, 15:59   #105
karankapoor's Avatar
finally you decided congrats !!!
karankapoor is offline
Closed Thread
Difference between a Monobloc and 2 Channel Amplifier for the Subwoofer? frankmehta In-Car Entertainment 52 21st November 2011 17:23
Advice needed for performance upgrade for the 1.3 Ikon Dragonov Modifications & Accessories 5 4th June 2006 12:43
Budget Car Audio Advice Needed Guys thief In-Car Entertainment 22 26th January 2006 14:59
advice needed: car audio in hyundai accent amit_baghe In-Car Entertainment 273 25th December 2005 00:04
Repainting & "Sumo to Sumo victa" conversion. Advice needed. nitrous Modifications & Accessories 0 21st November 2005 12:57
