Closed Thread
Old 27th February 2009, 16:35   #106
frankmehta's Avatar
Thanked: 2,334 Times
great great!! congrats! is this the final upgrade or is there anything else in the pipeline ;-)
frankmehta is offline
Old 27th February 2009, 16:39   #107
navin's Avatar
Thanked: 4,282 Times
Originally Posted by abhinav.gupta88 View Post
The problem earlier was that my subs need 1000w each ( = 2000wrms) while JBL gives 1500w rms at 2 ohms.
So the subs were underpowered.
What makes you say you subs were underpowered?
Could you hear the sub hit their Xmax? or the effects (dynamic range compression especially on impulse).
A sub that can absorb 1500W or even 750W at 30hz has to have a very nice suspension. At 300Hz the same is not a problem. Subwoofer ratings are for their thermal limits. However in most cases subwoofers tend to be more limited by the abilties of their spiders, surrounds, etc..
navin is offline
Old 27th February 2009, 16:55   #108
Thanked: 294 Times
Navin Ji the problem Abhinav was facing that the Sub-woofer amp used to reduce the output when pushed hard. Earlier it was running at 2 ohms and now he is running it at 4 ohms. So the output is better when driving at 4 ohms. Earlier I think the subs were not getting full power so that the XMAX was not reached but not it will be a problem as whole power would be diverted to one sub. Now a little tuning will be required including a HPF also.
low_bass_makker is offline
Old 27th February 2009, 17:03   #109
navin's Avatar
Originally Posted by low_bass_makker View Post
the Sub-woofer amp used to reduce the output when pushed hard. Earlier it was running at 2 ohms.
This is why I do not like pushing amps at 2 ohms even if they are rated so. Keep them in safe limits and they perform better.
navin is offline
Old 27th February 2009, 18:00   #110
Thanked: 294 Times
Totally agreed. It is better for the sub also it will get cleaner signal and result in better sound.
Old 27th February 2009, 20:09   #111
abhinav.gupta88's Avatar
Thanked: 310 Times
Back to the 2 ohm currently.
Need to save some money for the upgrade.
Thanks for the help guys.
Thanks Frank , Karan.
abhinav.gupta88 is offline
Old 27th February 2009, 20:50   #112
JBL 14001 x 1 @ 4ohms each ?
if yes then good choice !
VOiLA is offline
Old 27th February 2009, 22:02   #113
Thanked: 310 Times
2 JBL 14001.
Giving 1200w rms @ 4 ohms and 14.4 v each.
Old 28th February 2009, 00:43   #114
Invinsible's Avatar
Thanked: 60 Times
2 JBL 14001.
WOW! with 2 of them at that given output would be 2400 RMS. GOD! am sure it's gonna shatter lot many glass windows around. What's the SPL gonna be 150+.. makes me wonder.
Invinsible is offline
Old 28th February 2009, 00:52   #115
Thanked: 310 Times
I dont think it will reach 150.
Expecting around 140-141 or something.
Rest lets just wait for figures.
Old 9th March 2009, 13:13   #116
Thanked: 310 Times
Ding.
Guys
tested the 14001 again.
Its lowering the volume after 30 volume.
Suggest me some more amps ~2200w rms at 2 ohms or 2 ~1200w rms at 1/4 ohms.
Help.
I am ready to spend around 35000 on the amp. ( after selling my 14001 that is)
Old 9th March 2009, 13:18   #117
karankapoor's Avatar
hehe you are back again with the same thing....
go for steg 2.04 think that is 1200 x 2 @1oh
karankapoor is offline
Old 9th March 2009, 13:29   #118
Thanked: 310 Times
No steg for me. ( too costly)
called up LBM , he said it might be due to the excess power supplied to the sub
Will get it checked by him and lets hope things go well.
Old 9th March 2009, 13:42   #119
good luck bro
don't forget to call me when you upgrade
Last edited by Jaggu : 9th March 2009 at 14:04. Reason: Smilie usage restrict to 2 per post
VOiLA is offline
Old 9th March 2009, 14:55   #120
Invinsible's Avatar
Thanked: 60 Times
Great so you are back to square one.
Well to start with if you can source one from the US, may be this would interest you.
Hifonics BXI 2610D - Hifonics 2400W 1 Channel Mono-Block Amplifier
SPL FX1-4000D - SPL 4000 Watt Class D Monoblock Amplifier
or may be the JBL GTO24001
Closed Thread
Difference between a Monobloc and 2 Channel Amplifier for the Subwoofer? frankmehta In-Car Entertainment 52 21st November 2011 17:23
Advice needed for performance upgrade for the 1.3 Ikon Dragonov Modifications & Accessories 5 4th June 2006 12:43
Budget Car Audio Advice Needed Guys thief In-Car Entertainment 22 26th January 2006 14:59
advice needed: car audio in hyundai accent amit_baghe In-Car Entertainment 273 25th December 2005 00:04
Repainting & "Sumo to Sumo victa" conversion. Advice needed. nitrous Modifications & Accessories 0 21st November 2005 12:57
