Old 24th February 2009, 00:22   #1
abhinav.gupta88's Avatar
Thanked: 310 Times
Default dB Changes
Hi Gurus.
Was just thinking about my ICE when this thought came to my mind.
Why is it that when i was doing my dB test after keeping the sub ON for 15-20 mins produce lesser dB rating than when i tried it after not playing the sub for 1 hour or so.
Also does dB rating depend on the song and the bitrate of the song?
Abhinav
Old 24th February 2009, 00:50   #2
nitrous's Avatar
Thanked: 285 Times
Electronics,bro! The amp heats up and starts losing its efficiency.
Old 24th February 2009, 00:55   #3
noidaboy's Avatar
Thanked: 260 Times
Yep yep!
If you run the testones for too long or stress the voice coils too much you might end up blowing them up.
SPL test need to be done with precaution if serious SPL figure's are anticipated.
noidaboy is offline   Reply With Quote
Old 24th February 2009, 01:24   #4
Thanked: 294 Times
Very simple. Sub woofer if played hard even with undistorted signal will tend to get heat up becasue the energy given by the amp has to end up in some place. In a sub woofer it goes majorly in three places...
  • Sound output
  • Heating of the Voice coil
  • Mechanical movement of the Voice coil, Spider etc...
In a SPL setup a lot of power is given to the sub so the VC gets heated up. And a conductor when heat its resistance increases. The same thing happens here. If played hard even for few mins the VC resistance increases and the SPL output decreases. Sad but true. Thats why when ever going for a SPL test keep your setup cool.
Old 24th February 2009, 10:24   #5
navin's Avatar
Thanked: 4,282 Times
using aluminum formers a voice coil can be kept pretty cool. anodised aluminum is great becuse the anodised layer does not transfer electricity but is a transfers heat well.
Old 24th February 2009, 10:28   #6
Thanked: 294 Times
Yes. Also the SPL subs have bigger Voice coils so that there thermal rating is improved and we have larger surface area to disipate heat. Like few SPL subs I have seen have 4 inch VC and that is quite massive one. 2 inch would be a normal sub.
Old 24th February 2009, 15:30   #7
navin's Avatar
these subs also have a vented pole piece to help disappate the heat.
Old 24th February 2009, 17:02   #8
Thanked: 294 Times
Sorry I forgot that part.
Old 24th February 2009, 20:38   #9
Thanked: 310 Times
So what would be the range of drop in dB levels if suppose i continuesly play sub for 10-15 mins ( mix of full and medium bass) and then immediately do a dB test.
P.S Thanks for the explanations guys.
Old 25th February 2009, 00:46   #10
Thanked: 294 Times
1 or 2 db can be more...
Old 25th February 2009, 11:04   #11
navin's Avatar
more than 3db is considered a bad design. most of the stuff I've used limit loss to 1db or so.
Perfect gear changes satish_appasani Technical Stuff 33 27th May 2014 10:41
Major changes at Overdrive and the Indian magazine industry GTO The Indian Car Scene 50 28th May 2013 15:40
changes in Euro-3 cars with respect to Euro2 speedsatya The Indian Car Scene 13 12th October 2009 11:24
Rule Changes in WRC Tom Int'l Motorsport 6 3rd June 2004 14:56
