Closed Thread
Old 6th March 2009, 16:43   #31
Technocrat's Avatar
Thanked: 2,589 Times
Nishant which site are you ordering it from & for how much ?
Technocrat is offline
Old 6th March 2009, 16:47   #32
frankmehta's Avatar
Thanked: 2,334 Times
I think friend sending from usa or some one carrying it down. So Nishant. Lock kiya jaaye? ;-)
frankmehta is online now
Old 6th March 2009, 16:49   #33
Technocrat's Avatar
Thanks to Nishant I am getting Ideas too
Old 6th March 2009, 17:02   #34
nishantgandhi's Avatar
Thanked: 151 Times
My friend is flying down soon. He would be getting it for me.
Thanks to Nishant I an getting Ideas too
Thanks to Frank that I got to know about this HU
Technocrat - How are you planning to get it?
nishantgandhi is offline
Old 6th March 2009, 17:16   #35
Technocrat's Avatar
Well someone is traveling this month but I am not sure which website has one available :(
Old 6th March 2009, 20:41   #36
JPL
Newegg.com - Clarion In-Dash CD Receiver/CeNET Control Model DXZ785USB
JPL is offline
Old 16th March 2009, 17:31   #37
Thanked: 151 Times
One question - Is the 24 Bit D/A converter used for processing sound from iPod and USB as well?
Old 16th March 2009, 20:15   #38
Technocrat's Avatar
So does that mean you have ordered it?
Old 16th March 2009, 20:47   #39
abhinav.gupta88's Avatar
Thanked: 310 Times
From USB and Ipod ( If using the iPod adapter) then it should be the same.
Not sure though.
abhinav.gupta88 is offline
Old 16th March 2009, 21:12   #40
Thanked: 21 Times
Not really. In case of the iPod it depends on your method of interface. With an external interface or "full speed" cable (like in Alpine) the DAC of the iPod is what comes in play. In case of USB, usually the inbuilt DAC on the USB receiver chip is used.
gunbir is offline
Old 17th March 2009, 00:41   #41
That doesn't sound good at all
You meant to say when we change audio sources, internally it is one of many analog channels that gets selected (like one for CD, one for USB and likewise), each having it's own DAC? In that case unless each DAC is equally good, quality of a given audio file will vary depending upon whether it is played though a CD or USB drive??
Logically, I would think all the switching to happen in digital domain, which finally gets fed to a single DAC. But that doesn't seem to be a fact then?
santosh.s is offline
Old 17th March 2009, 00:52   #42
Thanked: 21 Times
Right on. That's what one does expect. But for whatever reason manufacturers make such choices, the Radio, Aux in, USB and CD seem to be switched in the analog domain.
Simple test: try burning the same mp3 onto a CD-R and compare that with the same file on a thumb drive. More often than not, the file on the CD will sound better.
gunbir is offline
Old 17th March 2009, 01:08   #43
My guess is most likely for cost or some "legacy" reasons in their design process.
Exactly my worry! I am going to get the same HU, thinking CDs are more or less getting obsolete, and that I will mainly use USB drives. (Now that these disks are quite cheap, even for size in TB range, I am hopeful of creating a lossless WMA collection which this HU is supposed to play)
But I am still hopeful (I have to be) that there should not be significant difference between CD and USB. Radio is a different matter, can be left alone!
Old 17th March 2009, 10:02   #44
Thanked: 21 Times
AFAIK currently no HUs support WMA Lossless... I suggest sticking to WAV files.
gunbir is offline
Old 17th March 2009, 10:06   #45
DerAlte's Avatar
Thanked: 2,879 Times
... But for whatever reason manufacturers make such choices, the Radio, Aux in, USB and CD seem to be switched in the analog domain ...
My guess is most likely for cost or some "legacy" reasons in their design process. ...
The switching has to be done in one domain - either analog or digital (byte stream). Since the byte switch is costlier than the analog switch (more silicon real estate), and the fact that analog sources would then have to be converted to digital before switching (even more cost), analog switch is the most obvious choice.
Is there really a problem if analog signals are switched?
DerAlte is offline
Closed Thread
Clarion Vs Alpine Vs Pioneer Vs Kenwood EDIT - Its a Clarion DXZ 785 USB Invinsible In-Car Entertainment 797 2nd June 2012 20:49
Clarion DXZ785USB Review: shrivz In-Car Entertainment 32 10th January 2011 21:31
Its Clarion's small brother with +bonus! ( Clarion 576 usb ) Dhams In-Car Entertainment 51 28th February 2010 23:25
Advice on Clarion DPX11551 Mono Amplifier kiran1103 In-Car Entertainment 26 3rd October 2009 19:08
Clarion vs Kenwood: Help needed with ICE jonnyonline In-Car Entertainment 8 29th December 2007 15:56
