Closed Thread
Old 17th March 2009, 14:24   #61
nishantgandhi's Avatar
Thanked: 151 Times
Originally Posted by frankmehta View Post
...i'm responsible for quite a few of them.. HEHEHE!
And is that why you are absconding to Goa?
nishantgandhi is offline
Old 17th March 2009, 15:08   #62
Technocrat's Avatar
Thanked: 2,589 Times
Cool so we know whom to blame if the HU doesnt perform as per the now high expectations
No wonder the prices went up on Amazon by $10
Technocrat is offline
Old 17th March 2009, 15:13   #63
frankmehta's Avatar
Thanked: 2,334 Times
if the unit is good, the xxxx no of people who bought it are pooling in 10-10 rupees and getting me a Steg amplifier. DEAL?
frankmehta is online now
Old 17th March 2009, 15:19   #64
Thanked: 151 Times
Economics. Pure demand and supply equation. In fact, it is now 'de-activated' on NewEgg.
Unless Frank is some kind of market maker/breaker and rigging the show.
AFAIK, not more than 5 people on TBHP are buying this HU. What will Rs 50 fetch you FM?
you forgot other tech forums!!! the amount of dhindora i have beaten about this head unit! god bless me if its bad!
Aahh, no wonder its disappearing so fast! And I was thinking that I would be among the few crazy ones to get it!
Old 17th March 2009, 15:21   #65
frankmehta's Avatar
Old 17th March 2009, 15:43   #66
Technocrat's Avatar
I am sure others who have ordered are thinking the same
All the best Frank
Old 17th March 2009, 15:54   #67
Hehe... I have already lost $10, need to order before it goes out of stock!
santosh.s is offline
Old 17th March 2009, 15:56   #68
Technocrat's Avatar
Btw Nishant has your HU arrived ?
Old 17th March 2009, 21:06   #69
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by santosh.s View Post
... then it is also likely that processing is done only for select channels and not for others. That is my concern. ...
Santosh baba, simplify, simplify, life will be more beautiful!
After finishing all the jugglery with codec, DAC and source switching and all, there is a block just before the take-off point of the Pre-out - which actually does the signal processing (no matter what the source) to manipulate the final signal. This can be a block external to the controller (dedicated SP chip), or the DSP of the controller itself. What one specifies via front plate controls gets saved as the configuration used by this block.
DerAlte is offline
Old 17th March 2009, 22:43   #70
Thanked: 21 Times
Originally Posted by DerAlte View Post
One would have thought the "full speed" iPod link would be appearing in the same route. Doesn't it? "Full speed" doesn't make sense if iPod's codec is in the picture, whereby one is routing the analog signal from the iPod (there are pins for it in the iPod connector) to the HU.
Sir, If the iPod was being decoded in the HU, how do AAC lossless and WAV files play on the iPod when clearly the HU doesn't have AAC lossless or WAV support.
Even when you use the "USB direct" medium to play an iPod on such HUs, its possible to play ALAC and WAV off the iPod when clearly the HU doesn't supoprt them. So that rules out any decoding being done in the HU, right? If so then how does this so called "digital medium" work here? The iPod couldn't be streaming PCM into the HU's main DAC could it? If it would, then why would there be a marked difference in WAV on CD Vs WAV on iPod?
You are right! The manual says it can play WMA upto 320Kbps, and MP3/AAC upto 320Kbps-VBR. BTW, doesn't' WMA has something like VBR?
Yes, WMA does have VBR. I use the Q98 VBR setting.
Gunbir, are you sure that this HU plays alteast WAV files as a lossless option from both CD and USB/iPod? I am asking because it's manual doesn't say anything about WAV as such.
Yup. While some of the current Pioneers play WAVs off CD-R, most other HUs (barring some models from Kenwood and JVC) don't do WAV. I don't think this HU does WAVs from USB or CD-R. I suggested ripping your music to WAV, and then down-converting to FLAC / WMA / MP3 or whatever.
If you add WAVs from iTunes into your iPod, they will play on any ipod player, through any medium... external iPod interface or direct USB.
gunbir is offline
Old 17th March 2009, 23:21   #71
Oh no! I thought this HU would give me at least one option to play lossless CD quality music from USB drive. I think there is no question of FLAC here, the best looks like 320Kbps-VBR with either AAC/WMA/MP3. Is this true even for the most "high-end" HUs, don't they have flexibility to play lossless from USB drives?
Do Pioneer/Kenwood/JVC that you mentioned support WAV through USB drive as well?
Old 17th March 2009, 23:31   #72
Yes, and if I could completely ignore it, then life would be nothing but bliss Life was indeed beautiful when I had very very simplified assumptions- that this HU will have at least one lossless option though USB drive (minimum WAV), and that all the processing will be uniform regardless of source. But, the DAC thing triggered the unrest, raising many more doubts!
Instead of getting simplified, to me it looks like another set (or sets!) of ADCs and DACs now!
Old 18th March 2009, 00:49   #73
While going through USB section of the manual, I came to know that this HU supports USB "Digital media streaming" using "Media Transfer Protocol (MTP)" from a supported media player! Can somebody put it in the right perspective for a layman- what exact capability does it provide me with? As somebody rightly said, the problem with standards is that there are too many to choose from! In any case, I am sure that "supported player" here is not an USB hard disk.
Old 18th March 2009, 11:24   #74
Thanked: 151 Times
No. My friend is not yet confirmed his date of travel.
AFAIK, the MTP protocol enables the HU to recognize any USB mass storage device. Thats why this HU does not have/need a separate iPod adapter. You can connect using the stock iPod USB cable and it shall play perfectly.
Btw, the current lowest price is $125 (DotBestShop - Clarion DXZ 785USB - radio / CD / MP3 player / USB flash player)
Old 18th March 2009, 11:52   #75
Originally Posted by nishantgandhi View Post
That link doesn't mention anything about shipping cost, even when I tried to "add to cart". How much is it?
Closed Thread
Clarion Vs Alpine Vs Pioneer Vs Kenwood EDIT - Its a Clarion DXZ 785 USB Invinsible In-Car Entertainment 797 2nd June 2012 20:49
Clarion DXZ785USB Review: shrivz In-Car Entertainment 32 10th January 2011 21:31
Its Clarion's small brother with +bonus! ( Clarion 576 usb ) Dhams In-Car Entertainment 51 28th February 2010 23:25
Advice on Clarion DPX11551 Mono Amplifier kiran1103 In-Car Entertainment 26 3rd October 2009 19:08
Clarion vs Kenwood: Help needed with ICE jonnyonline In-Car Entertainment 8 29th December 2007 15:56
