Old 14th July 2009, 16:18   #526
Thanked: 39 Times
Thanks Panky and Techno, I'd be more comfortable with the glovebox option as I'm looking to add a portable USB HDD (160GB). And this is my second concern- how well will an HDD take to big shocks in a car (monsoons = big craters and potholes on Delhi roads).
greenh0rn is offline   Reply With Quote
Old 14th July 2009, 16:52   #527
Invinsible's Avatar
Thanked: 60 Times
That's a great idea to have Port. HDD. The best I can think of to protect it from shocks, you could make a cover for it and fix it in your glovebox with help of velcroy. That should keep it shock-free.
Invinsible is offline   Reply With Quote
Old 14th July 2009, 18:33   #528
live2drive's Avatar
Thanked: 25 Times
Or just enclose the HDD with 0.5 inch thick foam all over. Will provide some resistance to shocks.
Today i did the activity of resetting the Verna's ECU. Removed the negative terminal from the battery, drained the current by pressing the brake pedal and tightened the terminal back after 15 minutes.
Switched on the Clarion, and to my surprise all settings on the HU (TA, EQ, etc) except the clock were intact & unchanged. Another feature where the Clarion excels.
live2drive is offline   Reply With Quote
Old 14th July 2009, 18:37   #529
Didn't it ask once again to choose speaker configuration (normal, 2-way, 3-way) as it does when powered initially?
santosh.s is offline   Reply With Quote
Old 14th July 2009, 18:38   #530
abhinav.gupta88's Avatar
Thanked: 310 Times
You may buy a Solid State hard disk.
It will be expensive but well worth it.
Old 14th July 2009, 18:40   #531
live2drive's Avatar
Thanked: 25 Times
Nopes.
Twenty chars.
Old 14th July 2009, 19:08   #532
ghpk's Avatar
Thanked: 193 Times
Modern equipments/devices use a button cell to keep the settings saved even if main power is removed. These cells just help "EEPROM Chip" to keep the settings and clock saved.
There should be a "RESET" button or Key combo if you need the HU to get back to factory settings.
Old 14th July 2009, 19:13   #533
Technocrat's Avatar
Thanked: 2,589 Times
Not really, mine did reset when I gave it for service.
Probably there is some time till which it retains this settings through caps & not a button cell.
Old 14th July 2009, 19:31   #534
Technocrat, then let me repeat my question, did it show speaker configuration option in your case?
Old 14th July 2009, 19:44   #535
ghpk's Avatar
Thanked: 193 Times
I am getting inclined to get one, (i know its quite late) but This HU seems to be another HIT here after Keny6539 (ah i remember those model numbers now).
anyway i found a store still having DXZ785USB
Shipped thru Fedex Intl. Economy is costing 214 USD (150 + 64shipping)
what say ?
Old 14th July 2009, 20:30   #536
live2drive's Avatar
Thanked: 25 Times
@Techno: Yes, maybe the settings are retained for some time only after plugging out the power source. In my case the clock time was found to be retarded by 25 minutes or so. But all other settings were the same.
@ghpk: Dont forget that custom duty will only add to the cost.
Last edited by live2drive : 14th July 2009 at 20:30. Reason: Missed out on some info.
Old 14th July 2009, 22:22   #537
mustang89's Avatar
Finally!!!
Mine has arrived too,cost me something around 8k,feeling so excited!!
mustang89 is offline   Reply With Quote
Old 14th July 2009, 22:25   #538
Thanked: 310 Times
Congrats Abhinav.
What's the other stuff you have?
Old 14th July 2009, 22:57   #539
ghpk's Avatar
Thanked: 193 Times
Originally Posted by mustang89 View Post
Finally!!!
Did someone brought it for you from US
or its purchased from India itself ?
is there any place in delhi/gurgaon where this can still be available ?
Old 14th July 2009, 23:10   #540
mustang89's Avatar
Originally Posted by abhinav.gupta88 View Post
Congrats Abhinav.
you mean to say on paper?
bro,my cousin got it for me from states.
Worthy replacement to Clarion DXZ 785 USB nishantgandhi In-Car Entertainment 19 22nd November 2011 13:07
2011 i10 Asta A/T - its Korean, its new, its fast, its red, and its coming. nirupesh Test-Drives & Initial Ownership Reports 1 8th January 2011 10:45
Its Clarion's small brother with +bonus! ( Clarion 576 usb ) Dhams In-Car Entertainment 51 28th February 2010 23:25
ICE done for Getz. Got Clarion 785 Bapu In-Car Entertainment 26 4th December 2009 10:58
Illusion Electra 4.1 in Alto - Upgraded with Clarion DXZ 785 USB HU + 6.5 mid bass Technocrat In-Car Entertainment 110 11th September 2009 13:34
