Old 4th November 2009, 18:51   #736
Originally Posted by Bass&Trouble View Post
and the fact that any of the DSP settings cannot be saved as presets.
It does allow storing up to 3 presets for these settings- "P.EO ON/OFF", "X-OVER", "T ALIGNMENT', "SPEAKER GAIN".
Additionally there is "INITIAL" setting also, so effectively 4 presets. The caveat is that it is not available in normal speaker mode, only in 2-way or 3-way. Another one- for parametric EQ, only on/off status is stored not details of 3 bands!
santosh.s is offline   Reply With Quote
Old 4th November 2009, 19:16   #737
Bass&Trouble's Avatar
Thanked: 71 Times
So you mean to say it is possible to save 3 different time alignment settings as presets? It's rather strange to not allow this facility in normal mode.
Old 4th November 2009, 19:22   #738
I felt the same way, whatever that can be applicable to normal mode should have been ideally provided. For whatever reason, they have simplified things in normal mode (forcing me to use 3-way mode), may be for non tech-savvy customers!
Old 8th November 2009, 18:03   #739
Hi guys....
i was following this thread intently for quite some and then it ran into 50 pages (making it a tough task to resume reading from where i left !! ;-) )
I have few quick questions to ask:
Do we still all consider the DXZ 785 the VFM buy inspite of some of the limitations that might have showed up here and there during the course of 50 pages !??
Am planning on asking someone to get this from the US...given the lack of any immediate alternative, can i agnostically go ahead and have this one ordered ??
Vinayak
vinayak007 is offline   Reply With Quote
Old 8th November 2009, 18:24   #740
shreyasma's Avatar
Considering the fact that the 785 allows TA, 3-way/2-way active mode, the SQ, 6v pre-outs, 24bit DAC..
Yes! its surely VFM. As I have mentioned in my earlier posts, I never regret the decision to invest in this HU. Same is the case with most of the people here
shreyasma is offline   Reply With Quote
Old 12th November 2009, 12:31   #741
Technocrat's Avatar
Thanked: 2,589 Times
I tried "All Seats" option yesterday, when you switch it "On" the TA is 'off' or atleast that's how it sounds & when you switch it back "Off" TA is 'on' again no issues
Old 13th November 2009, 01:08   #742
Invinsible's Avatar
Thanked: 60 Times
But I Noticed it, it works well if you have rear fillers and have set the TA parameters. Without it, it doesn't work at its best.
Invinsible is offline   Reply With Quote
Old 18th December 2009, 15:45   #743
SPARKled's Avatar
Thanked: 407 Times
So how many of you DXZ785USB owners are using this HU in active mode? Any noticable improvment in SQ after going active?
SPARKled is online now   Reply With Quote
Old 18th December 2009, 16:53   #744
Dhams's Avatar
Well not big brother 785 but having amazing company of small brother 576 Clarion since last 6 months. Yeap, I got it @6000rs. thru' dubai friend. 576 carry all features similar to 785 except TA but with compensation of direct front usb slot & Magna Bass features.
Dhams is offline   Reply With Quote
Old 18th December 2009, 17:09   #745
I would have any day traded off sound-restorer and digital-z-enhancers for this, but it was not possible. How useful/effective is it?
BTW, another advantage for you is that it will tune to any available FM station (if you ever listen to radio that is!).
Old 18th December 2009, 23:08   #746
Invinsible's Avatar
Thanked: 60 Times
Am not to sure if many here are running their drivers in active. But, I have a 4 way active setup on it's way, will be doing it next month. Onething i would have preferred is 24db slope instead of the limited 18db slope 785 provides. active gives more flexibility over the system than passive as long as the drivers used are above avg.
Currently running passive can give accurate feedback as will be running the same drivers on active.
Old 19th December 2009, 12:10   #747
Dhams's Avatar
Surely Magna Bass makes a note over even DigitalZhancer. Mostly I use DigitalZhancer at 2. GTx693Blaupunkt strong enough to run this show. I'm in dream how's effect when i go for subwoofer.
Yeap, i was listening all FMs in Ahmedabad during my last visit. Here, in Jamnagar there r no any FM due to defence headquarters
BTW, Answer to topic, overall am proud owner of clarion. Only trying to reduce sharpness coming out from front THx401 Blaupunkt
Old 21st December 2009, 12:26   #748
SPARKled's Avatar
Thanked: 407 Times
Just wondering if this unit 4 way active capable?
Old 21st December 2009, 12:38   #749
Technocrat's Avatar
hmm I too thought that it can only do 3 way active.
How are you planning to achieve 4 way active setup?
Old 21st December 2009, 13:14   #750
Dhams's Avatar
regret me if this sound hiking u guys-Technocrat & Sparkled but i am anxious to know about 2 way & 3 way active. I assume mine setup : 6x9 rear & 4"coax front runs by hu is 2 way?
Worthy replacement to Clarion DXZ 785 USB nishantgandhi In-Car Entertainment 19 22nd November 2011 13:07
2011 i10 Asta A/T - its Korean, its new, its fast, its red, and its coming. nirupesh Test-Drives & Initial Ownership Reports 1 8th January 2011 10:45
Its Clarion's small brother with +bonus! ( Clarion 576 usb ) Dhams In-Car Entertainment 51 28th February 2010 23:25
ICE done for Getz. Got Clarion 785 Bapu In-Car Entertainment 26 4th December 2009 10:58
Illusion Electra 4.1 in Alto - Upgraded with Clarion DXZ 785 USB HU + 6.5 mid bass Technocrat In-Car Entertainment 110 11th September 2009 13:34
