Old 3rd March 2009, 11:58   #1
dr_know's Avatar
Default Budget Audio Upgrade
I am planning to upgrade my current stock setup, but on a very tight budget. I have a selected a few stuff from an online store and would be really grateful if the guru's can help me out. I am not sure if any or all of the items are compatible (cos I don’t know a thing with it comes to ICE other than enjoy it).
I have a 2006 Mazda 6 and dont want to be making modifications to fit these and these are the speakers/components recommended by the website.
If not these then please recommend something similar so that I can checkout the prices locally vice internet.
Componet:
Kicker KS5.2 (2 sets for front & rear)
5-1/4" 2-Way Component System!
Power Handling:
Peak: 260 watts per set / 130 watts each side
RMS: 130 watts per set / 65 watts each side
Curvilinear Injection Molded Polygraphite (CIMP) woofer
Santoprene surround
External 12 dB/Oct Crossver Included
1" Aluminum dome tweeter
High-Power Tinsel Lead Wires
High-Temp Polyimide Film Voice Coil Former
New Enhanced BAM (Basket and Motor) Assembly
Ferro-Fluid™ cooled tweeter voice-coil
Felt Damping Plug behind the Tweeter’s Diaphragm
Amplifier:
Jensen Power 760
Power Series 4-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 75 watts x 4 chan.
2 ohms: 100 watts x 4 chan.
Bridged, 4 ohms: 190 watts x 2 chan.
Max power output: 380 watts x 2 chan.
MOSFET power supply
Design Minimizes Distortion and Reduces Idle Current
High Current Bi-Polar Output Transistors
LED power, standby, and fault indicators
Pass-Thru RCAs
4/3/2 operation
Preamp RCA outputs
Short Circuit, DC-offset and Thermal Overload Protection Circuitry
Variable high-pass filter (40-300 Hz)
Variable low-pass filter (40-300 Hz)
CEA-2006 compliant amplifier
Frequency response: 5-60000 Hz
Wiring Kit:
Rockford Fosgate RFK8
8 Gauge Amplifier Power Installation Kit
100% Pure Crystal-Oxygen Free Copper (PC-OFC)
FULL spec cable - meets or exceeds AWG (American Wire Gauge) requirements
Includes appropriate wire termination hardware
17ft. 8-Gauge power cable
3ft. 8-Gauge ground wire
AGU fuse holder and fuse
20ft. Remote wire
40 Amp fuse
For a rough total value of $ 280
dr_know is offline   Reply With Quote
Old 3rd March 2009, 15:07   #2
abhinav.gupta88's Avatar
Thanked: 310 Times
Insted of Jenson (which i havent heard before), i would go in for a blaupunkt gt4 /mk2 which is for around 6-7k.
Its better to go for a tried and tested amp than one which has not been heard of before.
Old 3rd March 2009, 16:03   #3
navin's Avatar
Thanked: 4,282 Times
abhinav, I think the good doctor was getting the kicker+jensen as part of one deal for $280.
Old 12th March 2009, 11:19   #4
dr_know's Avatar
hey guys I wasn’t able to get that offer cos of some shipping restrictions.
But does anybody know if Boss Audio BV9995B is any good?? (retails for $350)
I have not heard of Boss Audio earlier, is it something good? I mainly am getting this for my 2 year old to watch Barney, so am not on the look out for the best. Something economical will do for me.
I was also thinking of getting pre-installed headrests with screens, is this a good idea will there be compatibility issues with the head unit and the screens?? The item I am talking about is this one: XOVision GX1569 (for a pair $ 300).
Thank you for your time.
Old 12th March 2009, 11:59   #5
navin's Avatar
For your 2 year olds needs even the stock system will do. get a DVD changer and 5-7" screen and she/he will be happy.
Old 14th March 2009, 01:58   #6
dr_know's Avatar
Hey Navin took your advice and bought this 'nextbase sdv685-am' and all needs met as of now.. nothing great but gets the job done.
Main unit with the DVD player also has a 8.5' screen (installed on the windscreen) and a slave (strapped on to the rear head rest), audio can be connected to car audio system via RCA or via FM. I am using FM right now audio quality aint good but will do, as I plan on moving this from car to car as needed. So this serves the purpose best.
Install time: 5 mins
Cost: $ 350
10 lakh budget. New car, used car or wait and increase budget? Tejas@perioimpl What Car? 59 2nd May 2014 12:03
Swift Audio Set Up - Rs. 100/- K Budget -- Options ? BHAGWAN In-Car Entertainment 35 19th March 2008 14:56
Car-audio fitter + Budget dilemma luvjascha In-Car Entertainment 3 4th July 2006 10:27
Budget Car Audio Advice Needed Guys thief In-Car Entertainment 22 26th January 2006 14:59
Budget of 20 k, but need a good audio system for my brand new xing capri_cap In-Car Entertainment 33 6th November 2005 23:50
