Old 18th August 2010, 16:10   #136
garry.brant's Avatar
Thanked: 22 Times
Default Alternator whine...
Sorry i forgot to mention that after few days the alternator whine is back again. Let me mention what all steps we have already tried:
1. Changed the route of RCA and power cable, they are not going together anymore.
2. Changed the RCA Cables with branded ones.
3. Grounded the HU with Copper on RCA outs.
4. Already Isolated the AMP not being the point of failure by checking the AMP in a different car.
Please suggest what should i do get rid of the same.
garry.brant is offline   Reply With Quote
Old 19th August 2010, 10:58   #137
DerAlte's Avatar
Thanked: 2,879 Times
Redo the amp ground. Make sure the area where the washer / wire makes contact is scraped clean till the base metal shows. Alternately, if you can, get a copper / brass washer brazed at the place to improve the contact with the ground wire.
Old 19th August 2010, 12:58   #138
panky12345's Avatar
Thanked: 149 Times
Try the Pio HU RCA grounding technique. Else, change the amp!
Old 19th August 2010, 17:09   #139
Thanked: 22 Times
Thanks for the suggestions guys.
@panky: Like i mentioned i have already isolated that the amp is the not the problem. Pio techniques are already in place.
I will try to sand the screw for amp grounding.
Please give your inputs on the phase 2 upgrade as well.
Old 22nd August 2010, 09:03   #140
Thanked: 22 Times
Default Alternator whine... FIXED
Hi Guys,
Finally the alternator whine is gone, I changed the painted screw with a new screw (non painted) and the noise was gone for some time, when i drove the car for few KMs the noise came back agian.
I had a noise filter lying there in my car, so i tried it and IT WORKED.
The issue has been resolved successfully.
@Panky : I tried the tuning part yesterday. What i did is Moved all the HU settings to flat. Turned off the rear speakers and Tuned the front speakers then i did the same for the Rear speakers.
RESULTS: Now i have only Treble and Mid Range from the front speakers and The bass is coming from the Rear speakers.
Old 22nd August 2010, 14:37   #141
panky12345's Avatar
Thanked: 149 Times
Shift the fader to front..
Old 3rd March 2016, 13:48   #142
Thanked: 22 Times
Default Re: My New Hyundai Accent ICE
@MODS:
Please close this thread as the car is sold.
Cheap ICE for an Accent (7k or so). EDIT : ICE Review ADDED! Poitive In-Car Entertainment 23 7th September 2014 02:10
Used Baleno or New Accent Executive? EDIT - Its Accent lynx Sedans 34 8th April 2009 15:22
Ice For Hyundai Accent amitlead In-Car Entertainment 6 6th November 2007 15:52
modifying hyundai accent like the wrc accent kausu Modifications & Accessories 11 26th March 2006 14:20
