Old 13th July 2009, 11:35   #46
shreyasma's Avatar
Wasn't the install done at Evo?? I remember the guys working on the car and the place.
They do get dirty with the job at times when Satya's not around.
shreyasma is offline   Reply With Quote
Old 13th July 2009, 11:50   #47
Yes, you guessed it right. Even though I did not mention it earlier, I realize that one of the pictures did have a clue in the form of their logo!
santosh.s is offline   Reply With Quote
Old 13th July 2009, 12:34   #48
shreyasma's Avatar
Actually, saw the clue only after you mentioned now.
How dumb! I forgot to say congrats. :-)
Well..Audition??
Old 13th July 2009, 13:21   #49
Thanks Shreyas. Audition- any convenient time, we can decide over PMs.
Old 13th July 2009, 17:54   #50
Thanked: 36 Times
Congrats on your install, I would like to hear to it too.
zaks is offline   Reply With Quote
Old 13th July 2009, 18:32   #51
Santosh,
congrats on the install. Thanks a lot for the detailed updates.
Originally Posted by santosh.s View Post
LBM (or should I say McLBM now)
McLBM?? Yeh naya naam kab aaya.? Did I miss something.
ameenmaj is offline   Reply With Quote
Old 13th July 2009, 18:56   #52
vikram18's Avatar
Thanked: 20 Times
Congrats on your install. Which CDT components are these? CL/HD/ES?
vikram18 is offline   Reply With Quote
Old 13th July 2009, 21:33   #53
Both components and sub are their entry level stuff I believe, CL-62 and EF-100 respectively. Regarding Kenwood amps, class-D mono is again entry level I suppose, but component amp is from a higher series (named Excelon). Idea was to take a very cautions leap into true hi-fi without blindly overspending. BTW, I think I did right thing by choosing 10" over 12". Because 10" itself goes pretty low and blends well (when dicky is closed and windows are rolled up, of course), which makes me think 12" would have been relatively boomy. After all, it was a recommendation by CDT itself.
Old 13th July 2009, 21:35   #54
Just that I saw somebody (probably DA aka DerAlte) renaming him like that
Old 13th July 2009, 23:51   #55
Invinsible's Avatar
Thanked: 60 Times
Congrats! Superb choice of equipment. That x20 kenny amp looks nifty. I suppose it does 180x2 at 4ohms. How much gain are you running on those comps?
And how much did it cost ?
Reg the XO setting, as everyone mentioned keep the amp setting to Flat / HPF off and make use complete use of the XO from HU. I am using the the HU xover for my front comps, rear coax and subs.
Invinsible is offline   Reply With Quote
Old 14th July 2009, 12:31   #56
Yes, @14.4V though! @12V it is still rated at 120Wx2 (4ohm, 20-20KHz; 0.05%THD). I didn't intend to use all that power. I could be wrong, but I have a general impression that using highly rated amps at low level would be better than low rated amps at full throttle (unless they are one of those usually expensive high-end models which are very conservatively rated).
Both amp gains are set to lowest (5V sensitivity). Relative gain between comps and sub is adjusted through HU using 3-way mode, comps running 6dB lower than sub.
USD exchange rate was on higher side when purchases were made, in spite of that here is approximately what I paid in Rupees:
Components- 7.6K
Compo amp- 6K
Subwoofer- 5.6K
Mono amp- 5.6K
Head Unit- 7.1K
BT Kit- 3.5K (This could be much cheaper but I had to choose little expensive shipping option because it was ordered at the last minute)
Total for all components- 35.5K
Installation- All inclusive with wires, box etc., basically everything apart from above- 9.2K making total ICE cost=44.7K
More details on materials used- Scosche 4GA wires and fuses for both amps, 14GA speaker wire from amp-to-xover and xover-to-mids, 12GA for sub (brand unknown, but Satya said it is good), I wanted to use thin 18-20GA for xover-to-tweeters but 16 or 17GA wires from Scosche kit were used for this purpose, 2 Hitron RCAs (seems to be very well shielded), one 3.5mm stereo to RCA cable for BT kit, harness adaptor, 4 MDF rings, carpetted MDF plank for amps, carpetted and fiber-glassed subwoofer box, + other minor accessories.
To be honest, I wanted to use the likes of Finolex for power and MX for speaker wires, while getting rest of the job professionally done as it has been. But that was not possible (at least in Bangalore), for that I would have to DIY which was impossible given the extent of work involved and this being my first time with ICEing!
That is what I would do ultimately, but I am bit overcautious about blowing mids. Let me do battery disconnection test first.
Old 14th July 2009, 15:18   #57
DerAlte's Avatar
Thanked: 2,879 Times
That's because he said "I'm loving it" somewhere. Name change application pending - LBM has not approved of it yet!
Old 14th July 2009, 18:09   #58
abhinav.gupta88's Avatar
Thanked: 310 Times
That's really a VFM setup.
Congrats.
Old 14th July 2009, 18:39   #59
live2drive's Avatar
Thanked: 25 Times
Congrats Santosh. Installation looks good.
Settings on the HU will not get reset on removing the battery. I figured this out today.
live2drive is offline   Reply With Quote
Old 14th July 2009, 18:42   #60
Just saw your posting in the other thread and responded too!
Clarion Vs Alpine Vs Pioneer Vs Kenwood EDIT - Its a Clarion DXZ 785 USB Invinsible In-Car Entertainment 797 2nd June 2012 20:49
ICE For Accent Viva-CDT Audio vgudale In-Car Entertainment 14 14th April 2011 14:25
Its Clarion's small brother with +bonus! ( Clarion 576 usb ) Dhams In-Car Entertainment 51 28th February 2010 23:25
ICE done for Getz. Got Clarion 785 Bapu In-Car Entertainment 26 4th December 2009 10:58
Clarion vs Kenwood: Help needed with ICE jonnyonline In-Car Entertainment 8 29th December 2007 15:56
