Old 18th May 2005, 10:58   #16
gkrishn's Avatar
Thanked: 37 Times
no bass tube ...
no space will be left in the trunk.
gkrishn is offline   Reply With Quote
Old 18th May 2005, 11:11   #17
navin's Avatar
Thanked: 4,286 Times
ok substitute bass tube with 2 x 6" woofers on MDF parcel tray.
Old 18th May 2005, 11:13   #18
mohit's Avatar
Thanked: 125 Times
Thats the problem with us hatchback owners. If you go for the component approach, you'd have to supplement it with a bass tube/sub. My take would be to go for coaxials..... they are not up there when it comes to quality but they do a decent job. I'd say compromise a bit on space and put 6x9s in the back. An all JBL setup would be around 3.5K Front (these are 6 inchers) + 4.5 k Rear + 9k Amp + 2K Wiring + 1 K for plank. Should give you enough thump. You can go for a cheaper amp in case you want to put in tweaters.
mohit is offline   Reply With Quote
Old 18th May 2005, 11:31   #19
I used to be in bangalore till about a year ago.... there was shop at the lifestyle circle.. or rather in the road toward shoppers stop .. in the same bldg that houses hertz.... he used to have a fairly good music sys collection and option.... and the owner's son seemed a lil knowledgable and cud indulge in some intelligent conv... suggest u pay him a visit too...
vivaid is offline   Reply With Quote
Old 18th May 2005, 12:49   #20
gkrishn's Avatar
Thanked: 37 Times
Navin, mohit and vivaid,
Thanks a lot of suggestions...
Now i will go out and do some hunting... once the system is decided and installation is done, will let u know the details and feedback.
Thanks,
GK
Old 18th May 2005, 13:19   #21
Thanked: 11,110 Times
Car shrungar - he is quite good and his fitting is a lot superior to Hot Tracks. Hot Tracks prices are better
Old 18th May 2005, 13:40   #22
gkrishn's Avatar
Thanked: 37 Times
I was talking to hot track guy on monday. Was enquiring about 6990... and he quoted 5200Rs!!!
I asked him twice, got the same answer.
Old 18th May 2005, 22:23   #23
sparco's Avatar
dude 6990 here in bby costs 2800 bux
sparco is offline   Reply With Quote
Old 19th May 2005, 11:05   #24
navin's Avatar
I wont disagree with this but you could put a sub in the rear deck.
A seperate active sub has 2 disttinct advantages.
1. bass energy saps the power amp. a seperate active sub will reduce the chances of this. also when a power amp is stressed it distorts. much of this distortion is felt in the midrange where the ear is much more sensitive. haivng a seperate amp for the sub (as active subs do) ensures that a even is the bass amp is stressed and distorts the distortion does not reac the midrange since the midrange is driven by a different amp.
2. The laws of physics dictace that the Theil Small Parameters of woofers producing low frequency sounds be different from drivers producing midrange. This is espcially true of Compliance (Cms) and Mass (Mms). While there are many examples of drivers that are adept at doing both bass and midrange even these drivers deliver a higher level of sound if relieved of the lowest of bass.
Hence it helps if frequencies below 100 or 120Hz are managed by a seperate bass system (amp and driver).
Yes a sealed box sub or a bass tube will occupy trunk space but one can install the sub on a shelf jast as one does the 6x9s.
6x9 coax speakers do offer great VFM though. I have heard a few that were quite smooth. One was the Alpine (690? not sure). The JBL 6x9 I heard was a bit bright but that is JBL sound.
Bass is a function of volume of air moved. This means a big cone that moves a lot. The cone area of a 6x9 is equivalent to that of a 8" woofer (about 200-220cm2). The cone area of a 6" woofer is about 150cm2. However a good 6" dedicated to producing bass will be capable of more linear motion (Xmax) than most 6x9s and hence move the same ammount of air even having smaller cone area.
Old 19th May 2005, 11:19   #25
sir navin.. just wondering... are you an acoustics engineer or in a related occupation.... each of your replies are highly technical and theory based....
Old 19th May 2005, 15:01   #26
navin's Avatar
nope. and pleeeeeeease dont call me "sir" :-)
Old 19th May 2005, 15:11   #27
iceman91's Avatar
Thanked: 22 Times
ajmat sir, hot tracks is expensive.....anil is good for his variety and stock but prices are much more.
good system variety i would say the pitstop or car fancy and for installs nothing to beat anwar
iceman91 is offline   Reply With Quote
Old 19th May 2005, 15:14   #28
quite possible - I go s good price for the amp and the subs - his prices are different for different people.
Who is anwar and where is he located ?
Old 19th May 2005, 15:14   #29
navin's Avatar
sorry for the theory. I thought i was staying away from it and only stating what was practically applicable. If I bored anyone please accept my humble appologies.
Old 20th May 2005, 14:14   #30
hey navin.. just kidding.. chillax...cheers
Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! Sam Kapasi In-Car Entertainment 13668 22nd July 2018 19:18
OH NO!! Another Ferrari Enzo crashed.. and another... and another (w/ video) GTO The International Automotive Scene 72 26th May 2007 14:09
Another M800 Audio query abhibh In-Car Entertainment 26 15th March 2007 15:24
Another crash, another fire, another death in Delhi suman Street Experiences 7 15th December 2006 15:30
