Old 20th March 2009, 22:06   #1
somubj's Avatar
Default Picture upside-down on JVC roof mounted screen
I installed a JVC roof mounted screen in my car 2 days back. Till yesterday, it was working fine but today, when i switched it on, the image was displaying upside-down! Initially, it was showing no-signal, which i figured out how to fix because AV1 was selected and screen was plugged into AV2. Headunit is a pioneer.
This screen is an old model (which i recently bought from blueraven) - some 2 years old and i don't even know the model number. Please help me in fixing this issue.
Please help!!!!!!
somubj is offline   Reply With Quote
Old 20th March 2009, 22:12   #2
navin's Avatar
Thanked: 4,282 Times
Since you bought the screen from blueraven why not approach him for the fix?
Old 20th March 2009, 23:27   #3
somubj's Avatar
I was wondering if i can get it fixed by tomorrow early morning since i am traveling out of station. It's too late to call him now.
Old 20th March 2009, 23:51   #4
DerAlte's Avatar
Thanked: 2,879 Times
The inversion is a soft setting. Check the settings menu. Somehow your unit must have got reset.
Old 20th March 2009, 23:54   #5
Sam Kapasi's Avatar
Thanked: 1,473 Times
Go to Menu and then picture settings. You will find the setting there. Various options are offered, depending on how the screen is mounted.
Old 21st March 2009, 00:09   #6
somubj's Avatar
There are just 4 options in the menu: brightness, contrast, saturation and source av1 or av2.
I changed my car battery today and since then, the picture is upside down. Should i try disconnecting and reconnecting the power?
But the default setting should be normal view when fixed on the roof...right? And this is how the image should be displayed once we reset to default?
Old 21st March 2009, 01:59   #7
Rehaan's Avatar
Thanked: 25,038 Times
If that is indeed the case (strange - do double check) -- then maybe there is a setting on the pioneer HU ?
Definitely the cause for this "soft setting" to get forgotten.
Reconnecting the power once again will probably not fix this issue.
cya
R
Old 21st March 2009, 02:43   #8
somubj's Avatar
The HU is DVH 5850 Pioneer. Do you have any idea where to look for external display settings?
Old 21st March 2009, 09:29   #9
DerAlte's Avatar
No, the problem is not with the HU, which will always send the video out the right way up.
If there is no menu setting in the monitor, then check if there is a switch setting somewhere, which could have been disturbed.
Old 21st March 2009, 10:54   #10
navin's Avatar
oops I forgot to notice it is a JVC roof mounted monitor. Check behind the screen on along the side edges there whould a switch your car clear might have switched while cleaning. Look for Inverted Image Function in your manual.
Old 22nd March 2009, 08:10   #11
somubj's Avatar
There is just one switch which is for switching on the lights, thats it :-(. I bought this as a used thing and there was no manual with it.
Old 22nd March 2009, 09:32   #12
navin's Avatar
have you gone though the settings options?
Old 22nd March 2009, 10:09   #13
tsk1979's Avatar
Thanked: 16,420 Times
Your monitor should have a settings button. click through it and explore all menu options. There you may find one called "invert/flip" etc.,
Old 22nd March 2009, 13:53   #14
nura's Avatar
You could also visit the JVC site, identify your model with the help of the pictures there & download the manual.
The manual may help you with future problems too.
nura is offline   Reply With Quote
Old 29th March 2009, 17:31   #15
somubj's Avatar
Issue resolved!
Image was upside down and apparently i could not find any way to get it right. So i did some basic DIY stuff.
Step 1: Remove the screen from the car
Step 2: Open the LCD screen casing
Step 3: Rotate the screen and put the casing back
Step 4: Install the screen back in the car.
That's it!
Tools used: nail filer and kitchen knife for unscrewing the casing, nail cutter for cutting the wires and a fork to open the smaller screws .
Pics attached:
Screen for rear passengers (mounted on the headrest) agnisumita In-Car Entertainment 29 25th November 2014 16:57
Driver ignorant of how ABS works; Turns Chevy Captiva upside down keyur Street Experiences 137 27th January 2012 15:30
Roof Mounted / Overhead Carrier for Swift, Santro etc vishnugs Modifications & Accessories 16 29th March 2010 17:41
Upside down 6*9 speakers? RAC In-Car Entertainment 26 29th March 2009 11:37
Roof Mounted AC - Safari Dicor navtejsingh Modifications & Accessories 7 10th January 2007 01:13
