Old 23rd March 2009, 22:56   #1
abhi182's Avatar
Thanked: 202 Times
Default Corsa - ReICEd
Most of it has already featured in show off already, but WTH, I just spent so much time and energy (not to mention the aching hands and fingers and a minor cut from the dremel that i just bandaged - or band-aided) installing everything together (and Rahul + 1 more friend too) that this deserves to be shown-off :devil2:
JBL GT5-A604 Amp
Boston s60 Front components (Only tweeter visible)
JBL GTO938 Rear coaxials
ICE Front-End
abhi182 is offline   Reply With Quote
Old 23rd March 2009, 23:22   #2
Infractions: 0/1 (10)
That's a neat install. I like the tweeter location.
What wiring you used?
cheers
bharti22shresth
bharti22shresth is offline   Reply With Quote
Old 24th March 2009, 00:28   #3
Thanked: 17 Times
Wow! You mean DIY??
That's good man. Keep it up.
You're using a Pioneer 2950 HU?
Old 24th March 2009, 01:41   #4
yayaati's Avatar
I see a car PC on the dash....
but why Pioneer 2950 HU????
yayaati is offline   Reply With Quote
Old 24th March 2009, 01:48   #5
abhi182's Avatar
Thanked: 202 Times
Q: but why Pioneer 2950 HU????
Ans:
Though seriously, the HU right now is nothing more than a glorified volume controller...
The source is the Car PC (which can also handle anything an uber expensive HU will do and more)
The amplifier is in the trunk
The HU just acts as an intermediary volume knob
I could remove the HU but:
a) It would leave an ugly gap in the DIN slot
b) I like changing volume using an ergonomic rotary knob rather than reaching out for a touchscreen each time I need to adjust the volume
Didn't feel a need to use premium cabling so used an earthquake make wiring kit worth roughly 1K or so
Old 24th March 2009, 02:06   #6
yayaati's Avatar
For that purpose you can use external USB sound cards like Creative XMOD
and for that black space where the HU is you can install a pocket...
Old 24th March 2009, 10:19   #7
abhi182's Avatar
Thanked: 202 Times
I am currently using an M-Audio Transit USB sound card
As for the HU, it is kinda pointless to take it out since it does not hurt me in any way and i do not gain naything by taking it out, do I?
Old 24th March 2009, 10:20   #8
navin's Avatar
Thanked: 4,286 Times
The tweeter location is stock. THe original grilll was cut out and the Boston grill was used.
How does the monitor stand up. Does it not vibrate like hell when the car is in motion?
Old 24th March 2009, 12:05   #9
abhi182's Avatar
Thanked: 202 Times
Yes, setting up the tweeter took less than 10 mins of dremelling
No, the monitor came with an industrial strength double sided tape mount
The mount was stuck on the dash while the monitor was attached to the mount over rubber grommets
The stand does not mount thanks to the padded mount while the rubber grommets prevent the monitor from vibrating
Another alternative (possibly better) is to use a rubber suction cup although the current method is holding up well for now
Opel Corsa 1.4 GSi/ Corsa Sail 1.4 dsrins Hatchbacks 2 8th August 2006 17:47
Corsa 1.4 GSI 20K second servicing pramods The Indian Car Scene 6 18th August 2005 13:21
Corsa Royale arijit Shifting gears 12 6th September 2004 13:47
Corsa sail kiran The Indian Car Scene 2 6th May 2004 03:08
New Opel Corsa amit The Indian Car Scene 5 3rd March 2004 13:01
