Old 17th September 2007, 18:22   #16
Sam Kapasi's Avatar
Thanked: 1,473 Times
I second Navin's question. Why the need for a retrofit power antenna?
Old 17th September 2007, 19:12   #17
Raja's Avatar
Thanked: 61 Times
Please note the thread was originally started in May 2005. I didn't want to start a new thread when one already existed. My problem is that the antenna is faulty and MAY need replacing, I wanted to check out my options so that I don't make an on-the-spot rash decision and buy a poor quality replacement.
Any recommendations you can make Sam through your experience?
Raja is offline   Reply With Quote
Old 17th September 2007, 19:39   #18
Sam Kapasi's Avatar
I can tell you that spending more and buying it from the company is pointless. I would recommend you keep a budget of under 1000 and get it replaced from a reputed aftermarket dealer, like poona motors.
Old 17th September 2007, 21:29   #19
Thanked: 44 Times
Originally Posted by Raja View Post
I think I need a replacement power antenna for my car. The antenna won't always fully retract and gets stuck. Are these things serviceable?
What high quality brands are available and at what cost?
I have a power antenna for the Baleno for the last two years. It makes groaning noises, and gets stuck on partial retract sometimes. I just extend the antenna by putting on the HU, wipe the antenna down with a cloth sprayed with WD-40, wipe again with a clean cloth. This works for about a month or 45 days when the process needs to be repeated.
filcord is offline   Reply With Quote
Old 26th December 2013, 11:48   #20
Thanked: 114 Times
Default Re: Power Antenna
Originally Posted by esteem_lover View Post
Cheap chinese ones are available for 400-500 Rs. Try to get a Japanese make (I dont know the name) which could last a little while.
So my esteems power antenna broke its nylon rack. Need a new one. Trouble is i just moved to chennai a month ago. Can you tell me where i can find one in this city and at a good price?
mycarhasablower is offline   Reply With Quote
Old 4th January 2014, 23:52   #21
esteem_lover's Avatar
Thanked: 451 Times
I am sorry I am not around here much these days which explains the delay in answering your question.
I would suggest you get it replaced with MASS. If you think they are too much, go to G.P Road, before that pray to your God and trust a good bloke will come along to do justice and charge you reasonably.
If all above fail, send me a PM, but dont expect me to respond immediately 'cos i rarely come here these days. Send me an email instead.
cheers
Old 5th January 2014, 08:58   #22
Thanked: 20 Times
I found MASS to be of little help in my case. They could only recommend that I replace the entire unit (I had a broken antenna), for about 3K.
Finally reached out to the Nippon guys in Bangalore. It cost me Rs 1500/- to replace just the antenna.
It has been working well for over a year now.
Please see if you can reach Nippon Chennai for help, before you go to the local shops.
rakirank is offline   Reply With Quote
Lancer Power Antenna issue Raj_d Technical Stuff 6 30th May 2013 12:09
Repairing a power antenna pramodkumar DIY - Do it yourself 7 13th August 2010 11:27
Someone Broke my Radio Antenna! amit The Indian Car Scene 7 15th October 2004 21:48
