Old 24th March 2009, 20:31   #16
DerAlte's Avatar
Thanked: 2,879 Times
If you really want to experiment, start with getting a suitable 4" coax first - something that you like the mid-range of. Disconnect the tweet in the coax and implement your HPF plan with non-polar caps, the value of which you can figure out with on-line calculators. Feed it off the main speaker signal without disconnecting the existing XO. With the coax's own tweeter out of action, only the mid will use the signal. Hopefully with a bit of EQ at the HU, it will sound decent.
Once you are familiar with the controlling variables, you should be able to design and implement a 3-way XO.
Old 24th March 2009, 20:42   #17
abhibh's Avatar
Thanked: 34 Times
Might be a bit off-topic but from where can we source good capacitors & inductors to build the XO ? Doesnt matter if it is Mylar of PP.
I have not came across a single place in Punjab where i can source good quality parts.
Old 25th March 2009, 14:21   #18
Bass&Trouble's Avatar
Thanked: 71 Times
@greenhorn - I agree with you. The sensible thing does seem to implement a 6x9 type 3-way, utilizing the natural roll-offs of the concerned drivers to make the most of it. Or DIY-ing a 3-way crossover.
Any Sat-Sub speaker setups for less than 15k? pranava999 Gadgets, Computers & Software 36 11th June 2009 22:12
40k for fronts and 2 subs - Car ford fiesta Magma In-Car Entertainment 31 18th March 2009 22:41
Looking for Tonally Matching Fronts with JBL Voice Center Channel pitchucold Gadgets, Computers & Software 1 30th August 2008 21:59
Pics of some Exotic, Sophisticated & Dream Audio Hifi System Setups in Car Nos007 In-Car Entertainment 11 9th May 2007 10:44
Wiring fronts and rears: A rookie's question! kvish In-Car Entertainment 12 4th May 2007 15:48
