Old 30th March 2009, 22:13   #16
govigov's Avatar
Thanked: 530 Times
ok. wired the sub in series. now the sub seems to give more definition to the bass. however the bass is hard and kicks hard. i would like the bass to be softer, with the definition and the space around it to increase. does that make sense?
govigov is offline   Reply With Quote
Old 30th March 2009, 22:48   #17
nitrous's Avatar
Thanked: 285 Times
Get a 0.8 to 0.9 cu.ft sealed enclosure for the sub.
Old 30th March 2009, 22:49   #18
Check the gain setting once. If all correct, I think, now it needs some tuning.. You don't want your sub reproduce all the frequencies it can. Set the LPF (low pass filter) properly so that your sub it asked to reproduce the frequencies that you desire.
Raghu-A4U is offline   Reply With Quote
Old 31st March 2009, 23:04   #19
govigov's Avatar
Thanked: 530 Times
compos i am running are bull cs525.75
http://www.bullaudio.de/downloads/pd...sche_daten.pdf
you can find the same on page2.
@nitrous, i think have more like space 1.3 cu. ft. or more , but the velocity (i think) came with the box. it is a huge one and is very heavy.
edit: is there a thread or an article that teaches you how to tune the system? i dont want to mess up with the gain settings, (i think it is a tad too low, then again i dont want the sub to go all boomy).
after wiring it in series, i have not touched the amp settings, it is the same as before, when it was working with one coil.
Old 1st April 2009, 00:25   #20
karankapoor's Avatar
yes govi we have a thread on how to set gain.
http://www.team-bhp.com/forum/ask-gu...implified.html
karankapoor is offline   Reply With Quote
Old 4th April 2009, 23:46   #21
govigov's Avatar
Thanked: 530 Times
after going through the iceberg thread, i fianlly found my sub
Blaupunkt - 扬声器 - Velocity系列 - VXS 12 (新)
thats the one!
Old 5th April 2009, 00:30   #22
abhibh's Avatar
Thanked: 34 Times
thats the one!
Nice choice of sub-woofer. Which amp will drive it this baby ?
Old 5th April 2009, 00:33   #23
navin's Avatar
Thanked: 4,282 Times
max budget i can have is 7k for front components and rear fill.
Use all 7K for front componets and add rear fill later
@greenhorn, what to use for rear fill in that case. the rear has a 6*9 oval space for the speakers, where the company speakers are running at the moment.
perfect leave the rear speakers and run them of the HU.
ok guys, am in big TROUBLE!!!
purchased bull audio components, the components have good bass upfront, and really lacks a that good mid bass. as a result a lot of the vocals are drowned out. my car is now ideal for listenining to techno, which i dont :
Do you mean midrange. THere is very little vocal information in the "mid bass". if you can set the HPF of the amp (feeding the front speakers) to 80Hz or so to roll of the midbass and push the vocal out a bit more.
to small. this sub would need 1cu. ft. + even aperiodic.
are you using the original box? if not, why not?
Old 10th April 2009, 15:34   #24
govigov's Avatar
Thanked: 530 Times
Default Pics Added
@all, update:
here are some pics that will give you an idea of the box and the sub.
Help req - Alpine Ida X200, velocity and bull audio - pics added-dscn0996.jpg
Help req - Alpine Ida X200, velocity and bull audio - pics added-dscn0997.jpg
Help req - Alpine Ida X200, velocity and bull audio - pics added-dscn0998.jpg
Help req - Alpine Ida X200, velocity and bull audio - pics added-dscn0999.jpg
Help req - Alpine Ida X200, velocity and bull audio - pics added-dscn1000.jpg
What is the volume of this box? is it ideal to match the sub??? I have placed a ruler to give an idea of how big that thing is.
Help req - Alpine Ida X200, velocity and bull audio - pics added-dscn1002.jpg
Blau GTA 450 640W amp
Of which the 2 channels are bridged to drive the amp and the other 2 go for compos. aint the sub too much underpowered?
Help req - Alpine Ida X200, velocity and bull audio - pics added-dscn1003.jpg
Help req - Alpine Ida X200, velocity and bull audio - pics added-dscn1005.jpg
Help req - Alpine Ida X200, velocity and bull audio - pics added-dscn1010.jpg
Help req - Alpine Ida X200, velocity and bull audio - pics added-dscn1015.jpg
Bull CS 525.5 audio components
Help req - Alpine Ida X200, velocity and bull audio - pics added-dscn1006.jpg
Help req - Alpine Ida X200, velocity and bull audio - pics added-dscn1009.jpg
Help req - Alpine Ida X200, velocity and bull audio - pics added-dscn1014.jpg
Alpine Ida X 200
There is an issue now. some times the whole system stsrts screaming in a high pitched vail, that freaks the hell out of me. i have to turn down the volume to make it stop.
(How do i edit the thread title to read - "pics added"?)
Old 10th April 2009, 16:15   #25
how the sub is wired to the amplifier,i can see 2 input.
and for changing the title of the thread report it to mods they will help you with this
Old 10th April 2009, 18:30   #26
govigov's Avatar
Thanked: 530 Times
sub is wired in series.
Old 10th April 2009, 22:18   #27
but how,never seen anything like this can you post pics of the amp terminal.
Old 10th April 2009, 23:57   #28
govigov's Avatar
Thanked: 530 Times
@kk,
of the 4 terminals in the amp for output, 2 terminals are used for the front compos.
the other 2 terminals are bridged for the sub. The sub is wired as under.
Swift ICEd with Alpine iDA-X303 ranjitkodali In-Car Entertainment 7 29th December 2010 01:49
Bought an Alpine m500 and Type R sub, need advice on an all Alpine SQL setup. Astleviz In-Car Entertainment 1 23rd October 2010 23:46
Alpine IDA-X series launched in India greenhorn In-Car Entertainment 7 17th December 2009 19:12
Installed Alpine ida-X100 mishraak In-Car Entertainment 30 8th October 2008 10:14
