Old 8th April 2009, 12:44   #1
Default Component Speakers without Amplifier
Hi - would request some help here. I have a Pioneer 6050 UB 2 DIN system, along with Bull Audio Components (front) and JBL 6x9 (rear). No amplifier.
Give me quite a decent and powerful sound (considering there is no amp) Of late I have noticed that on certain 'thump' beats (Robert Miles 'Children' - the constant dum-dum-dum) the front components give a cracking after-sound. Similarly for other similar 'thump' sounds.
The installer said its due to lack of an amplifier, or they suggest that I put the HPF at 125 Hz. While the HPF idea reduces that sound, it kills all bass in the car because this Pioneer doesnt have separate settings for front and rear.
Will putting an amp to run the rear and compos solve this problem? Also, will there be any improvement in overall sound with the amp?
The recession has stalled all my plans of upgrading to a good quality woofer + amp, so an 'amp-only' workaround would suit my current spending plans.
Please advise. Much appreciated !
Abhishek
abhishek3030 is offline   (1) Thanks Reply With Quote
Old 8th April 2009, 14:49   #2
frankmehta's Avatar
Thanked: 2,334 Times
get a 4 channel amp and power the fronts and the rears. The Amp will allow you to HPF the fronts and LPF the rears. This will improve the sound by leaps and bounds and you will enjoy your music. The sub can be added later, and the rears can be run off the head unit then.
frankmehta is online now   Reply With Quote
Old 8th April 2009, 14:53   #3
nishantgandhi's Avatar
Thanked: 151 Times
Abhishek, as I mentioned to you the other day, go for a budget 4/2 channel for the time being. When you add a sub later, you can go for a dedicated mono (since you have a sedan) or if still on a budget, use 2 bridged channels of the amp for the sub.
KAC 8401/JBL GT5/Blaupunkt all are good, under ~5k budget 4 channels.
nishantgandhi is offline   Reply With Quote
Old 8th April 2009, 15:14   #4
Thanks for the note, Frank - sounds good. I guess an amp is the way to go if one needs good music
abhishek3030 is offline   Reply With Quote
Old 8th April 2009, 15:16   #5
Thanks Nishant - am gonna do just that. Spoke to a genuine (relatively) guy in Gurgaon about the Blaupunkt amp. 5700 with Bill + Warranty...hope to get it installed this week.
Old 8th April 2009, 15:47   #6
frankmehta's Avatar
go for the options Nishant mentioned. The Blaupunkt, or the JBL GT5-S644. The Kenwood 8401 is now defunct and out of production. The 8404 is not worth the extra cost. for that price you can get a 1004 in the grey market, which, for you is my choice of amplifer. the jbl gto1004. perfect amp for you. price in grey is 8.5k and with a warranty is 10.5k.
Old 8th April 2009, 16:03   #7
Are you sure that the sound is due to the lack of an amplified signal?
What kind of sound is that you get.Cracking type caused due to the door panels vibrating and Is it only during low frequency signals? Can be due to high volume levels also.
In what car is this installed and if installed on the doors, is that Damped?
Any way putting and amp will always make your compos sound more lively.
Nandan
Nandan is offline   Reply With Quote
Old 8th April 2009, 16:43   #8
Nandan
The car is a Corolla 2004, and to be true it could be due to the door panels vibrating. I plan on getting the front 2 doors damped as well...
Old 8th April 2009, 17:16   #9
Thanked: 151 Times
I think the price is slightly higher, unless its with B&W. Chandigarh people have been reporting it around 4.5k with B&W.
Infact, you could PM Nitin Dangayach. He also got that same quotation in Gurgaon.
Yes, thatsanother nice option. Spend a little extra right away and go for the 1004. That ways, you will be future proof, when you get your sub (which I believe should be GZMKII, in a sealed box, knowing your music tastes)
Old 10th April 2009, 22:56   #10
Installed the Blaupunkt GTA 4 Mk II - sounds good, but alternator whine on low volumes. Will get it checked tomorrow - hopefully the shop will get it rectified soon.
Old 11th April 2009, 03:41   #11
muneemmk's Avatar
Thanked: 18 Times
Why is this problem very specific to Blaupunkt Amplifiers ? almost everyone who have installed the same amp have complained regarding noise or alternator whine.
muneemmk is offline   Reply With Quote
Old 11th April 2009, 12:32   #12
superbhikari's Avatar
Thanked: 146 Times
Not me ! I never had any such problem of alternator whine or noise from the Blaupunkt GT4MKII Amp till date.
superbhikari is offline   Reply With Quote
Old 11th April 2009, 12:43   #13
karankapoor's Avatar
i had also used blau mkII and never had any problem,this looks like the grounding cable is loose.
karankapoor is offline   Reply With Quote
Old 11th April 2009, 13:52   #14
muneemmk's Avatar
Thanked: 18 Times
I have seen six cars installed with the same amplifiers and all of them faced more or less the same problem.
An ICE Technician in Mumbai explaining to his client about the Blaupunkt's noise issue "Saar the Blaupunkt amplifier is a very good and sensitive amplifier that it even picks up the small noises that your alternator makes"
Old 11th April 2009, 14:17   #15
bottle's Avatar
Thanked: 138 Times
Same problem here gta 2 mk2 and alternator whine
bottle is offline   Reply With Quote
Top 10 6.5" Component Car Stereo Speakers k_ajay In-Car Entertainment 66 9th May 2018 16:53
JBL Component speakers - Queries! gigatech2006 In-Car Entertainment 9 3rd March 2008 15:44
Lightning Audio 5.25" Strike Series Component Speakers for sale esteem_lover Shifting gears 2 15th August 2007 23:57
Lightning Audio Component Speakers blueraven316 Shifting gears 4 1st April 2007 14:55
