Old 9th April 2009, 18:23   #1
Default Need Advice - Audio Unit
Hi Guys
Need your expert Advice ...
I have installed a Pioneer 5050 Head unit with four c600c ( They also have a 60 rms output ) Component speakers installed of Audible Dynamics. I Also have a 4 Channel JBL amp with has a 60 rms per channel with have been attached. The Front Speakers are attached on the amp only ..and the next two channels have been briged to the 12' sub which is of 4 ohmps..!
BTW this is for a Mahindra Bolero.
Advise : Is this a good setup and how wud you rate this kind of setup out 10
I am planing to put a mono bloc amp at the later stage and attach teh rear speaker also to the older AMP.
Kindly Suggest
Rohan
rohanpimpley is offline   Reply With Quote
Old 10th June 2009, 22:15   #2
anilagdr's Avatar
Thanked: 59 Times
Rohan, how are the Audible Dynamics components. Looks like there are veryfew takers for them in this forum
anilagdr is offline   Reply With Quote
Old 10th June 2009, 23:28   #3
Sam Kapasi's Avatar
Thanked: 1,453 Times
I've read your post twice.
What expert advice do you want?
Audible Dynamics is an Indian brand with decent build quality. I didn't like the sound of the few speakers I heard.
You don't really need 2 pairs of components in any case, but you have them, so you have them.
And most car speakers are 4 ohmps.
Kindly Suggest
Rohan
Your want a rating from 1 to 10? Why?
Not really required. Save your money. Amping the front speakers and the rear sub is a decent enough system. Adding a mono would make the rears louder and give you better output from the sub.
Old 10th June 2009, 23:36   #4
abhinav.gupta88's Avatar
Thanked: 308 Times
Originally Posted by Sam Kapasi View Post
4 ohmps.
Damn this 2 smiley rule!
Old 11th June 2009, 06:49   #5
phamilyman's Avatar
Thanked: 3,452 Times
Sam,
And will pink/red car speakers be rated at 4 Oomphs?!
Old 11th June 2009, 09:11   #6
jkdas's Avatar
Thanked: 1,389 Times
A mono amp for a sub is a good upgrade. You will have to get your 4 channel amp tuned to be in sync with the sub once you power all four comps from the amp.
Please post pix if you can.
Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! Sam Kapasi In-Car Entertainment 13577 11th December 2017 18:05
Bluetooth pairing issues with Audio Head-Unit triedeverything In-Car Entertainment 12 16th June 2012 10:07
need help and advice - Car Audio install DIY patkim In-Car Entertainment 8 15th December 2008 20:52
Need some Advice on my Car Audio satishri In-Car Entertainment 11 15th February 2006 09:28
