Closed Thread
Old 29th May 2009, 11:34   #121
It's good you want to try this stuff out, and it's your money, but IMO you would not get the end results (SQ) you are trying to achieve...
1. ARC & RTA are only good on paper (theoretically), real life results are much dismal. This is surely one of the most debated topic amongst audiophiles. While the proponents swear by it, the rest don;t give it a candle!
SQ wise you would anytime get better results with good quality speakers. Equalizers and DSPs can only help within limits of the speakers, which IS usually the weakest link in any decent audio setup.
2. With due respect to Tata, a diesel Safari is the last vehicle you should think about installing a SQ system, unless your primary objective is to listen to it with your SUV turned off. Else there is too much noise and rattling issue.
Again MAY BE active noise cancelling can THEORETICALLY help, but practically even if it is possible it would be too complex and prohitively expensive, I would just write it off.
Anyway I would be watching this thread and it would be nice to be proven wrong
R18A is offline
Old 29th May 2009, 14:24   #122
ibm_jennifer's Avatar
Thanked: 7 Times
Leave about ARC. Do you know whats RTA and what it does? have you ever tried Alphine 605 - Do you know where from they get their algorithm?
I agree with you and I am not using with any EQ or DSP for SQL.
Its True. But can you show me a Car speaker which reproduce the frequencies perfectly in a car environment?
Man, Do you have a Safari? See, I have a TCIC Safari and the money I have spent on my car is more than a Brand new DICOR. Don't discourage people unless you have listened or driven my car. I am not a fool to invest 3 lacks for a CarPC on a noisy or roaring mammal. I haven't hear any engine noise in my car and I don't let my car with a TATA design to cry with a low-pickup. I know What i am doing as I am living in a Film Studio and a car workshop.
Noise and rattling issue are trademarks of TATA and you need some brain and time to solve it yourself. if you don't have any of that, I advise you stay away from a Safari. And yes, my car used to stay in the workshop than with me and I am still fighting on my TCIC against this TATA trademarks for the last 4 years(!). Man, I am happy with my car and my setup. If you want to discourage me or make me stupid, you should first listen my car atleast.
Or if you tried to help me, Dont simply say ARC is wrong RTA is wrong. Provide me some proof atleast. The people who selling it for $$$$$ are not fool and I am not a fool to invest without trying the trial versions. And for your reference: ARC wont work well with the supplied Mic. You need to invest more than the cost of ARC to buy a professional Studio quality Omni dir True Condenser Microphone. I bought an AKG.
And in my world, a software is not a true RTA, if it wont support 1/24th octave resolution FR and 1/24th octave Phase Response with Magnitude & Coherenc and inbuilt professional mic and sound card calibration. Dont say RTA is bad by trying some $100 software.
And thanks for your advice, just take my reply fun.
ibm_jennifer is offline
Old 29th May 2009, 14:44   #123
Thanked: 7 Times
@ibm_jennifer: Im also using 5.1 setup in my scorputer but the volume control in centrafuse is not working properly, i.e, when i reduce the volume in centrafuse, only the front channels reduce, rear speakers volume remain unchanged. Is there some configuration in centrafuse for colume control for 5.1?
Man, you are lucky then, I wont even get the volume control to work for my front channels. I hope its based on the sound card and someone in Team-bhp already got the 5.1 control working in centrafuse.
Old 29th May 2009, 15:35   #124
frankmehta's Avatar
Thanked: 2,334 Times
you need some brain and time to solve it yourself if you don't have any of that, I advise you stay away from a Safari
typical ibm (in a good way!)
i appreciate your love for music and the enthusiasm of doing the best possible for your car. cheers man..
PS: a review on the new electras, if possible????
frankmehta is online now
Old 29th May 2009, 16:37   #125
COUGAR's Avatar
Thanked: 86 Times
absolutely brilliant!
i wonder about ne thing though: why did u mount one LCD in the dash? Couldnt you somehow integrate it into the dashboard or centre console?
COUGAR is offline
Old 29th May 2009, 16:45   #126
Thanked: 7 Times
Yes, its one of a wrong things I did here, but the reason is I have to tranfer my Car PC when I will buy a new Safari. And its not bad now as in the picture as I have managed to bring it down with low profile VGA and Right Angle USB Adapter.
Old 29th May 2009, 19:15   #127
ibm, I do not own a Safari, but my cousin does, and that's why my opinion.
I definitely do not want to discourage you, as I said, I would be happy to be proven wrong. Keep going
R18A is offline
Old 29th May 2009, 19:38   #128
DocG's Avatar
IMO the Safari is one of the best cars to ICE, the vast interior space gives you so much room to play with to get imaging right.
I also appreciate the work and research gone into your carputer project. I mean 2.5L is an enormous amount for ICE.
That being said, I do feel that the audio equipment is a big let down, and does not do justice to your high-end set up.
An analogy would be buying a high end Genesis, Steg, TRU or DLS amp and running entry level speakers. It just doesn't add up. I think a major upgrade in this department is the only thing which will redeem value to the amount of money spent...
DocG is offline
Old 29th May 2009, 19:52   #129
Thanked: 7 Times
Again I am not agree with you here. The High End stuff you are mentioning here will produce perfect sound with MP3 Music. There is no big difference bw this High End and my poor JBL 607 if I am playing Lossless 24 bit 192KHz samples.
The secret is where the Distortion happens, it happens at your source, for me its at the destination.
But as per your point, If there is no distortion, then we will get a perfect SQL setup.
But its impossible now because there is no High End Speakers available to reproduce the input with a Flat FR Curve.
There is no Cross-over available here without introducing Group Delay,
There is no Amplification/EQ available here with out Phase delay.
But I agree that it will be better if I had those High End speakers. But its not my Aim and the reason is "How much Delay, Noise, Reflections and Distortions are AUDIBLE - by my ear, because its not a competition setup!".
Old 1st June 2009, 21:34   #130
Thanked: 7 Times
And here is the update:
Just ordered an External Slim Blu-Ray Player and a PS2 Eyetoy for side-view(?). Will update you with photos once received it in hand.
Don't ask me with an uncontrollable laugher as 'Will your Car PC Blu-Ray Ready?' - Yes as per: CyberLink Blu-ray Disc Support
Also don't ask me Why a Blu-Ray in a Car if you don't know what is DTS-MA and TrueHD.
Also don't buy a Blu-Ray for your car if you dont know to bypass HDCP/AACS/BD+/region code.
Old 2nd June 2009, 14:08   #131
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by ibm_jennifer View Post
... Also don't ask me Why a Blu-Ray in a Car if you don't know what is DTS-MA and TrueHD.
OK, we promise we will not ask.
But, how about explaining us anyhow?
... Also don't buy a Blu-Ray for your car if you dont know to bypass HDCP/AACS/BD+/region code.
OK, we are not planning to buy.
Now that you have got us curious, how about telling us how to do that?
God bless you!
DerAlte is offline
Old 2nd June 2009, 14:13   #132
frankmehta's Avatar
God bless you!
ROFL!!
Yes, ibm. You will be one of the first few people in the world to have a blu ray player in your car, but you are not willing to explain? Naughty boy
Old 2nd June 2009, 14:21   #133
esteem_lover's Avatar
Thanked: 451 Times
Do you know what is DTS-MA & True HD ?
If not, you cannot ask, remember ?
ibm, please be merciful to us baba.
esteem_lover is offline
Old 2nd June 2009, 14:22   #134
Thanked: 7 Times
NO Friends, I know if I started to tell something from my stupid brain, you people will tease/rag me with a .
But as for as I know its possible to run Blue-Ray and break the stupid DRMs in the car as long you stay in Analog world with Sound and Video. But you cant enjoy 1080p (And we cant), but we can down sample upto 720p (1280*720 rescaled to 1024*720). Regarding Sound, yes its possible upto 192Khz TrueHD/DTS-MA as long as we deliver the sound in Analog format from PC.
I have already invested for the Blu-Ray and first let me prove myself whether its possible to brake DRM. But not a problem, If I failed, It will be in another Blu-Ray in my home.
Do you know what is DTS-MA & True HD ? If not, you cannot ask,
I am sorry, actually I tried or have to post: If you didn't hear True-HD or DTS-MA, don't ask me 'Why Blu-Ray in Car'?
Old 2nd June 2009, 14:24   #135
frankmehta's Avatar
on a more serious note? Why not a playstation 3? it has true hd and dts ma and all the other jargon (which you didnt allow us to ask about)..
why not a ps3?
Closed Thread
Santro v/s BMW X5 v/s Safari v/s Bolero v/s Volvo 5000 VictorSinha Street Experiences 17 4th December 2009 17:50
Tata Safari Dicor LX 4 X 2 or Safari Dicor EX 4 x 2 Digitalmafia SUVs, MUVs & 4x4s 55 1st June 2009 17:31
Safari EX 4x4 5000 km Review and Impressions THE-U- Long-Term Ownership Reviews 25 17th August 2007 08:22
Lilliput!!! - 5000 Kilometre milestone report (Safari LX) sumitsingh Long-Term Ownership Reviews 18 20th February 2007 09:41
suggest car for 5000 km per month Max Sedans 39 16th December 2005 13:38
