Old 19th April 2009, 11:08   #1
adityamunshi's Avatar
Default Problem with sub enclosure
I just bought a GZ Titanium MK2 12" sub and made a 1 cu ft enclosure for it. However, i cut the pieces of MDF before the sub arrived and made the hole on the box to exactly 12 inches.
But it turns out this is too big for the sub which measures quite a bit less than 12" at the level of the basket. The rubber gasket is just bigger than the whole and there isnt enough space to put in the screws.
What do i do now? It wont be possible to take apart the box and build it again.
adityamunshi is offline   Reply With Quote
Old 19th April 2009, 11:26   #2
abhinav.gupta88's Avatar
Thanked: 310 Times
You will have to change that part of the box.
different woofers have difference in the circumference. Some are exactly round but when compared to others they are not.
Old 19th April 2009, 11:37   #3
greenhorn's Avatar
Thanked: 1,519 Times
make a big spacer ring ?
greenhorn is online now   Reply With Quote
Old 19th April 2009, 11:48   #4
Thanked: 294 Times
Ya...You can put another mdf board on it the same side with smaller hole in it. It will help in bracing the box and will yield better results..
Old 19th April 2009, 11:50   #5
DjNik's Avatar
As you are going sealed it is necessary that the enclosure is made keeping every detail in mind.The best option for you will to remove that piece and put a new one in place.
DjNik is offline   Reply With Quote
Old 19th April 2009, 11:57   #6
Will this arrangement make it more difficult to seal the box ?
Old 19th April 2009, 12:07   #7
razor4077's Avatar
Thanked: 258 Times
Found this nice, easy to understand article on Crutchfield on how to build a subwoofer box. Have a look, it may be helpful.
How to Build a Subwoofer Box
razor4077 is offline   Reply With Quote
Old 19th April 2009, 12:14   #8
Thanked: 294 Times
Why..you are putting two flat MDF boards one with 12 inch hole and other will 11 inch hole. Put some solution between them before fitting, this will seal them perfectly.
Old 19th April 2009, 12:14   #9
karankapoor's Avatar
like other said you can remove the whole piece or can put a spacer ring.
or you can put a whole new piece on the cutout side covering the old with the new piece with a smaller size cutout,this will not cause any problem to enclosure and will not leak
edit:just saw lbm post go with the same as suggested by him that will be the best way to do it.
karankapoor is offline   Reply With Quote
Old 20th April 2009, 10:00   #10
navin's Avatar
Thanked: 4,286 Times
On the contrary. Sealed boxes are most tolerant of minor differences in enclosure volume.
Exactly. LBM is right. All you need to do is make a new baffle and attach the new baffle to the box.
Old 20th April 2009, 10:21   #11
DjNik's Avatar
to the fact that sealed enclosures are the most tolerant to minor volume differences, what i wanted to suggest is that whichever option he chooses, it is sealed as properly as possible to get the expected performance out of the sub.
Old 20th April 2009, 11:59   #12
Im doing what LBM suggested. Will buy some more MDF today and update the thread tonight.
Old 22nd April 2009, 22:03   #13
Fitted another piece of MDF with an 11 " hole onto the box. Works fine.
The cone takes around 3 secs to come back up after i push it down. Is this good ?
Old 22nd April 2009, 22:09   #14
Thanked: 294 Times
Ya very good.....how is the wire coming out..Are you using a terminal or direct hole ?
Old 22nd April 2009, 22:12   #15
Its a speakon connector. Does 3 secs mean there's a slow leak ?
my 15inch sub's enclosure issue! rider60 In-Car Entertainment 16 30th January 2008 09:12
Help wanted -- Building a Sub Enclosure WasavaTyres In-Car Entertainment 39 18th August 2007 21:51
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
Need info on Sub and enclosure Gtea In-Car Entertainment 30 22nd December 2006 14:31
Fiberfill for Sub enclosure madbullram In-Car Entertainment 18 5th November 2006 00:50
