Old 24th April 2009, 22:30   #46
karankapoor's Avatar
this is little difficult to make out which is better or not class AB or class D,as both have there own sound quality,take it like this,take any brand which has both ab and d models and compare them on the same sub ab running @4 ohms and d running @ 2 or 1 ohms i think the ab will sound better as sq wise and d will be more louder and will make the sub sound with more control as compared to class ab.but there will a difference but not everyone can judge it.
karankapoor is offline   Reply With Quote
Old 24th April 2009, 22:38   #47
greenhorn's Avatar
Thanked: 1,519 Times
i was saying so strictly on a theoretical basis. Sometimes one amp is better than 2
greenhorn is online now   Reply With Quote
Old 25th April 2009, 00:33   #48
govigov's Avatar
Thanked: 531 Times
guys, any suggestions for class D and class AB amps that can pump more than 500W on to a sub at 4 Ohm or 1 ohm?
govigov is offline   Reply With Quote
Old 25th April 2009, 09:52   #49
there are many,but how much your are ready to spend.
Old 25th April 2009, 12:47   #50
valhallen.282's Avatar
Thanked: 164 Times
I think what people sometimes forget about one important difference between the two is that a class D amp is designed for providing sustained power over a narrow field making them better suited for subs which require this power. whereas since the AB class are more widespectrum there is more leeway in the power circuit design. the AB class are meant for sustained power also but have a lower threshold. for basic application a class AB is fine. BUT for a higher power sub or a person who demands more from his sub should preferably go for class D. its the more sensible option.
valhallen.282 is offline   Reply With Quote
Old 25th April 2009, 13:33   #51
vikram18's Avatar
Thanked: 20 Times
Originally Posted by Steeroid View Post
Is there such a thing as a 3 channel amp?
Yes there IS! Audison made (makes?) 3 channel amps. They had a SRx 3 for sure and also an LRx 3 (maybe). Cannot recall a VRx 3 channel amp, but AFAIK, there was a VRx 6 channel amp!
vikram18 is offline   Reply With Quote
Old 25th April 2009, 13:39   #52
frankmehta's Avatar
Thanked: 2,334 Times
DLS makes 3 channel amps too. they have the current DLS A5 which does 85*2 +300*1@ 4 ohms.
this makes it a perfect amplifier for a lot of 2+1 setups.
the DLS XD-30 and the current CA-31 are also 3 channel amplifiers
Old 21st November 2011, 17:23   #53
amit_mechengg's Avatar
Thanked: 1,556 Times
Default Re: Difference between a Monobloc and 2 Channel Amplifier for the Subwoofer?
digging this old thread again.
after reading through the posts i am now quite not sure what difference will the mono make if i power the same sub that is currently being powered through a bridged channel on a 4 channel amp.
the amp here is JBL 75.4 which produces 284watts RMS @ 4ohms.
The subwoofer is Ground Zero MK2 300 watts RMS and is a 4 ohm single voice sub.
Whenever i switch the amp switch to mono mode the subwoofer doesnt sound musical and seems to miss out the bass at lower frequencies.
When i switch it back to stereo the sub becomes musical.
Now if i buy a mono class D amp, pumping out say same 284watts rms what difference will it make ?
Also if the class d mono amp is having a bit of less power like 250watts how will it score against the stereo amp above?
Needed Advice on Monobloc abhinav.gupta88 In-Car Entertainment 152 20th March 2009 11:31
alpine 2 channel amplifier and wire guage/properties query? makanaka In-Car Entertainment 18 10th March 2009 13:19
2 channel or 4 channel amp harry2223 In-Car Entertainment 14 19th February 2008 22:08
Sony 4 channel amp' and Pio subwoofer for sale rjstyles69 Shifting gears 10 14th August 2007 19:18
Blaupunkt Subwoofer and Kenwood Amplifier for sale general_neo Shifting gears 7 25th December 2005 13:32
