Old 27th April 2009, 00:12   #16
ibm_jennifer's Avatar
Thanked: 7 Times
Route the power from one side and rca and speaker from another.
Agreed. Can I run the VGA cables and Rev camera RCA cable along with the power line. Will there anything called Video interference like Audio?
ibm_jennifer is offline   Reply With Quote
Old 27th April 2009, 00:30   #17
Thanked: 294 Times
Yes vdo can interference with audio...Try running the power and VDO together
low_bass_makker is online now   Reply With Quote
Old 27th April 2009, 00:43   #18
Thanked: 7 Times
Fine. will try my best. Thanks LBM sir.
Old 27th April 2009, 17:47   #19
Thanked: 381 Times
Originally Posted by ibm_jennifer View Post
No, Actually I dont have any space in left & right side foot panels(under the carpet) for this 4GA wire. Its all filled up by RCA, VGA, USB cables.
Is there any alternative like roof?
Just a suggestion in case you have already not done this ; In case you are running more then one USB cable from back to front just use one cable and then use a powered USB hub in the the from which you can mount somewhere on dash.
For headrest mounted LCDs for 2nd row you can run the video cable in the middle below the seat rather then from sides.
amitk26 is offline   Reply With Quote
Dupont Under Chassis coating in chennai knownstrangerr Technical Stuff 7 4th August 2011 22:51
DIY : Swift + Electra comps + Electra sub + havells power wire jithudigitised In-Car Entertainment 17 26th October 2009 16:38
power v/s chassis and the importance of handling normally_crazy Technical Stuff 17 8th March 2006 20:51
Teflon, Under chassis treatment etc sonic Modifications & Accessories 12 23rd February 2005 15:00
